fisch Posted October 16, 2007 Report Share Posted October 16, 2007 Finally picked up a weber 32/36 DGV! As a bonus it came with a Offenhauser intake. (And is already set up for the cabled throttle of a 521) But I don't know enough to know if an Offy really matters! For all I know a tube is a tube. (But the geek in me digs the kookie factor.) As to jetting, it came off a 521 w/ a L16, BUT, is set up for a Hi-performance L16 w a medium Racer Brown Cam. (Greek to me) Does it make a difference over stock? Will I have to switch jets? AND, my stupid question of the day. I've never replaced an intake or an exhaust manifold. I was hoping I could just replace the gasket on the intake ports, but every gasket I see also had the exhaust holes built in. Will I have to take off both manifolds, and replace the whole gasket, or can I cut the intake gasket out and just replace that? Seems like alot of extra work if I am not messing with the exhaust manifold. I couldn't find any info on this in Haynes (I guess they figure I should already know the answer.) Rember a guy has to learn! Quote Link to comment
69FJWagon Posted October 16, 2007 Report Share Posted October 16, 2007 yes its a one piece gasket also depending on your head drain your coolant too the intake (stock) some (???) have a water passage in them (you can see it in your first pic) the first time I changed my exhaust I filled the the cylinders up with water/coolant. had to pull all the spark plugs and crank the engine over to clear out the water... dont have to worry about that with my FJ20's :D Quote Link to comment
fisch Posted October 16, 2007 Author Report Share Posted October 16, 2007 yes its a one piece gasket also depending on your head drain your coolant too the intake (stock) some (???) have a water passage in them (you can see it in your first pic) the first time I changed my exhaust I filled the the cylinders up with water/coolant. had to pull all the spark plugs and crank the engine over to clear out the water... dont have to worry about that with my FJ20's :D Thanks 69 FJ! The coolent issue is something I would have never thought of! You totally just saved me some hassle. Quote Link to comment
Fineline Posted October 16, 2007 Report Share Posted October 16, 2007 Sweet. It even came with the high rise adaptor! Quote Link to comment
banzai510(hainz) Posted October 16, 2007 Report Share Posted October 16, 2007 YOu can make this ez for your self and not change the intake and exhast gasket and just bolt the carb on the stock manifold YOu can do this so you can get the truck running first then later in summer if you feel you just got to have the OFFY manifold on there then swap it out with a new gasket. remeber if you have a stock 210 cast head(has small 1.125 ports) on there it isnt going to go much better with that manifold. Most improvent will be the DGV itself. Quote Link to comment
fisch Posted October 16, 2007 Author Report Share Posted October 16, 2007 YOu can make this ez for your self and not change the intake and exhast gasket and just bolt the carb on the stock manifoldYOu can do this so you can get the truck running first then later in summer if you feel you just got to have the OFFY manifold on there then swap it out with a new gasket. remeber if you have a stock 210 cast head(has small 1.125 ports) on there it isnt going to go much better with that manifold. Most improvent will be the DGV itself. I wondered about this Hainz. Question, will the hi-rise adapter bolt up to the stock manifold? I assumed it was only for the Offenhauser as I've never seen an adapter like this. (Don't have it in my hands yet so I can't go out and measure it.) Quote Link to comment
banzai510(hainz) Posted October 16, 2007 Report Share Posted October 16, 2007 To me it looks like the adapter will bolt to the stock manifold.Its the standard old model tall adapter. Look at my photo. The stock carb should have the same bolt pattern as the offy manifold.then the adapter is used cause the boltpattern is wider on the DGV series. You might have to get taller studs in case the stock ones are not long enough on the stock intake, but at least you dont have to remove the intake and exhaust if you dont have to. maybe get it cheaper by saying you dont want the manifold Lets just get this running first. It should least fire with the oold carb on there by pouring a little gas in there. Have you even tried this yet? Quote Link to comment
Fineline Posted October 16, 2007 Report Share Posted October 16, 2007 Yes, it will fit on a stock manifold. I had mine like that before I got my Edelbrock. Quote Link to comment
fisch Posted October 16, 2007 Author Report Share Posted October 16, 2007 To me it looks like the adapter will bolt to the stock manifold.Its the standard old model tall adapter.Look at my photo. The stock carb should have the same bolt pattern as the offy manifold.then the adapter is used cause the boltpattern is wider on the DGV series. You might have to get taller studs in case the stock ones are not long enough on the stock intake, but at least you dont have to remove the intake and exhaust if you dont have to. maybe get it cheaper by saying you dont want the manifold Lets just get this running first. It should least fire with the oold carb on there by pouring a little gas in there. Have you even tried this yet? I just got the new fuel pump and filter on there last night. I plan seeing if it will fire this evening. Fingers crossed! I figured down the road if I upgrade the head I will already have the neat-o manifold. And at the minimum if I didn't want it, I could try to sell the Offenhauser to recoup some carb cost. Quote Link to comment
DatDoug Posted October 16, 2007 Report Share Posted October 16, 2007 Dude its not that hard to take off the exhaust mani with the intake mani. Then you can replace the gasket and clean up the exhaust mani and paint it with the manifold paint and it really cleans up the motor appearance. Remeber: "If something is worth doing, its worth doing right" Quote Link to comment
fisch Posted October 16, 2007 Author Report Share Posted October 16, 2007 Lets just get this running first. It should least fire with the oold carb on there by pouring a little gas in there. Have you even tried this yet? IT RUNS!:D:D:D:D:D:D:D:D:D:D:D For the first time in 10 years. (Running on the old stock carb at the moment.) Quote Link to comment
kiznook Posted October 16, 2007 Report Share Posted October 16, 2007 YAY!! congrats! Quote Link to comment
banzai510(hainz) Posted October 16, 2007 Report Share Posted October 16, 2007 Good to hear. Im sure you put GOOD anti freeze in there already. If you dont have to dont be changing stuff around quite yet untill everything works good on there.. is this a dual point distributor? Up grade to a Pertronix (use a single point distributor) But if you know points its OK for awhile. But its a good upgrade to a eleltronic ignition of some sort. But if everything is running good I would LOWER that Bad boy this weekend!!!!!!!!!!!!! Get some new tires case the old ones are hard already! Datdoug said change the gasket. I say NO!!! if your new to Datsun dont be fucking with stuff unless you really have to. Yes the L16 emission exhaust is ez to pull out. The L20 laterr vehicle is a bitch!!! ewhat you reaaly want to use this rig for. Just driving .then leave it. Buty some rubbing compund and polish it up. Quote Link to comment
fisch Posted October 16, 2007 Author Report Share Posted October 16, 2007 Good to hear. Im sure you put GOOD anti freeze in there already. If you dont have to dont be changing stuff around quite yet untill everything works good on there.. is this a dual point distributor? Up grade to a Pertronix (use a single point distributor) But if you know points its OK for awhile. But its a good upgrade to a eleltronic ignition of some sort. But if everything is running good I would LOWER that Bad boy this weekend!!!!!!!!!!!!! Get some new tires case the old ones are hard already! Datdoug said change the gasket. I say NO!!! if your new to Datsun dont be fucking with stuff unless you really have to. Yes the L16 emission exhaust is ez to pull out. The L20 laterr vehicle is a bitch!!! ewhat you reaaly want to use this rig for. Just driving .then leave it. Buty some rubbing compund and polish it up. I used the prestone (I think) half and half. I still have to figure out the brakes and clutch. (Pedals go to floor, and cups are empty) before I can drive. Not to mention eventually fixing the gas tank (leak), and finding out why the blinkers and horn do not work (will need that to pass inspection.) I haven't even started looking into those yet. But I will shout if I need some help! Tonight I smile for it has a heartbeat! Quote Link to comment
fisch Posted October 16, 2007 Author Report Share Posted October 16, 2007 is this a dual point distributor? Up grade to a Pertronix (use a single point distributor) But if you know points its OK for awhile. But its a good upgrade to a eleltronic ignition of some sort. I think it is a dual points. But I am not sure how to tell? It seems to run fine, but the choke has to be pulled out a tad, or it dies. But I haven't run it more than a few minutes at a time yet. Might need to warm up more, or who knows, it has been sitting for 10 years, and I've never had a manual choke. Quote Link to comment
datzenmike Posted October 17, 2007 Report Share Posted October 17, 2007 Remeber: "If something is worth doing, its worth doing right" Also: "There's never enough time to do it right...... .... but always time to do it over" Quote Link to comment
banzai510(hainz) Posted October 17, 2007 Report Share Posted October 17, 2007 open up the dist cap and if you see to contack sets of point then you know, the red blk wire is the main set i believe. Get to know these as these will give you the trouble in the future. if in the back woods if in dought always pull the center coil wire and put close to ground turn key and if it fires then you know the points is opening. If not fire the points are closed and cjaring the coil but not dischargin or you have the power wire not hooked up to ballast resistor thru to coil ect.... wire falls off sometime Quote Link to comment
uieluck Posted August 11, 2011 Report Share Posted August 11, 2011 Hey I have the same setup for my 1975' 620 where were you getting your gaskets from for the Offenhauser? Besides: http://www.offyparts.com/index.php Thanks, T— Quote Link to comment
fisch Posted August 11, 2011 Author Report Share Posted August 11, 2011 I actually never used the Offy manifold so I am unsure! Quote Link to comment
racerx Posted August 11, 2011 Report Share Posted August 11, 2011 make sure you have enough hood clearance.... Quote Link to comment
ggzilla Posted August 11, 2011 Report Share Posted August 11, 2011 Fisch, a tube is a tube ... but the Offy manifold has a split-tube. I've heard it doesn't work any better than a stock manifold. But it definitely looks cool. You get the gaskets from Nissan or from any parts store. It uses stock intake/exhaust gasket, stock Carb gasket. Quote Link to comment
banzai510(hainz) Posted August 12, 2011 Report Share Posted August 12, 2011 Offy manifold has a split-tube??? "Public Enemy" said Dont Believe the Hype!!!!!!!!!!!!!! Quote Link to comment
ggzilla Posted August 12, 2011 Report Share Posted August 12, 2011 Yes, look carefully. The Offy manifold is famous for the dual level runners: Quote Link to comment
Laecaon Posted August 12, 2011 Report Share Posted August 12, 2011 Mine has the split tube. Thought it was weird when I pulled my manifold. Quote Link to comment
