79datsun620 Posted June 30, 2009 Report Share Posted June 30, 2009 What options do I have as far as a stiffer motor mount for my 620 with a L20b can i look for Z mounts,it looks like there is more available for them but will they fit? Thanks Quote Link to comment
Z-train Posted June 30, 2009 Report Share Posted June 30, 2009 They are all the same construction,just slightly re-arranged to fit the particular model. Quote Link to comment
79datsun620 Posted June 30, 2009 Author Report Share Posted June 30, 2009 I've got a cam and it just seems to flop around lot at idle,and it just seems like it would be better i don't know? Maybe i'm crazy:blink: Quote Link to comment
sssr20det510 Posted June 30, 2009 Report Share Posted June 30, 2009 dont know if they make it but look into a poly mount Quote Link to comment
79datsun620 Posted June 30, 2009 Author Report Share Posted June 30, 2009 Yeah I think they make them for Z's and they look close enough to work.i've got some old 280 mounts i might try them to see if it works. Quote Link to comment
stilltwisted Posted June 30, 2009 Report Share Posted June 30, 2009 some of the small oval race track guys just rap high quality hose clamps like {gates} brand ,,around new rubber mounts ,,it adds just enugh stiffness Quote Link to comment
Llittle_Llama Posted June 30, 2009 Report Share Posted June 30, 2009 you can always buy new ones and fill the gaps with urethane, not a bad upgrade for a couple of bucks :) Quote Link to comment
DISLEXICDIME Posted June 30, 2009 Report Share Posted June 30, 2009 i have this same problem with my dime when my cam lopes my ekgine just flops around like the mounts are busted but they are new ! Quote Link to comment
datzenmike Posted July 1, 2009 Report Share Posted July 1, 2009 Poly mounts may transmit the vibration to the frame and rattle the car. How about a torque strap or damper? http://www.vertex-usa.com/catalog/product.php?productid=591 The idea is good just don't buy into all the HYPE about them. Basically, you just want a small shock absorber running from one side of the motor and bolted to the frame. Sure as fuck isn't worth $180... but stupid ricers will by any flavor of the month thing. Quote Link to comment
ggzilla Posted July 1, 2009 Report Share Posted July 1, 2009 Just go to the JY* and get a honda accord engine damper. Small shock absorber to cut down on the engine rocking. * jewel yard Quote Link to comment
datzenmike Posted July 1, 2009 Report Share Posted July 1, 2009 Just stretch the bungee from the battery over and hook onto the fuel pump. :D Quote Link to comment
lynchfourtwenty Posted July 1, 2009 Report Share Posted July 1, 2009 advance timing an or idle lol Quote Link to comment
datzenmike Posted July 1, 2009 Report Share Posted July 1, 2009 A fifty lb flywheel. Quote Link to comment
DISLEXICDIME Posted July 1, 2009 Report Share Posted July 1, 2009 A fifty lb flywheel. no way i already have a starion with 35 pound fly wheel no thank you Quote Link to comment
DISLEXICDIME Posted July 1, 2009 Report Share Posted July 1, 2009 they sell those dampener's for $25.00 on ebay Quote Link to comment
79datsun620 Posted July 1, 2009 Author Report Share Posted July 1, 2009 Thanks,those are some great ideas......well most of them especially the bungee:lol: Quote Link to comment
Llittle_Llama Posted July 1, 2009 Report Share Posted July 1, 2009 Just go to the JY* and get a honda accord engine damper. Small shock absorber to cut down on the engine rocking. * jewel yard I think it's jewelery...... Quote Link to comment
Icehouse Posted July 1, 2009 Report Share Posted July 1, 2009 Here are 2 different ideas http://www.celica-gts.com/forums/index.php?showtopic=12680 http://www.mckinneymotorsports.com/prod_DATSUN+510+SR+SWAP+PARTS Both may raise or lower your engine but I'm sure with a little back yard engineering they will work just fine. I to have seen some L series do quite a dance at idle. Actually mine does to but it's more due to the fact that the carbs are fucked. Quote Link to comment
