Stiffer motor mounts for 620
79datsun620
  • Replies 18
Poly mounts may transmit the vibration to the frame and rattle the car. How about a torque strap or damper? http://www.vertex-usa.com/catalog/product.php?productid=591
The idea is good just don't buy into all the HYPE about them. Basically, you just want a small shock absorber running from one side of the motor and bolted to the frame. Sure as fuck isn't worth $180... but stupid ricers will by any flavor of the month thing.
Here are 2 different ideas
http://www.celica-gts.com/forums/index.php?showtopic=12680
http://www.mckinneymotorsports.com/prod_DATSUN+510+SR+SWAP+PARTS
Both may raise or lower your engine but I'm sure with a little back yard engineering they will work just fine. I to have seen some L series do quite a dance at idle. Actually mine does to but it's more due to the fact that the carbs are fucked.
