jrock4224 Posted May 4, 2009 Report Share Posted May 4, 2009 So got the 32/36 on and it runs much better but now its got this sweet whistle when you accelerate. not at idle just upon throttle input it really whistles....anybody had this happen to them. checked all lines and gaskets and cant figure out where its coming from. never did it on the mazda it came off of. willpost pics later toady and maybe a vid. of the whislting, lmk.... Quote Link to comment
jrock4224 Posted May 4, 2009 Author Report Share Posted May 4, 2009 twelve people looked and not one had a whistler huh...that sux...... Quote Link to comment
Lozer Posted May 4, 2009 Report Share Posted May 4, 2009 my side drafts do that, It's probably at the base. (if you dident take the carb apart) the whistling is air being sucked in through a very small hole. check your bolts on the base and vacuume hoses for a small hole Quote Link to comment
datto510 Posted May 4, 2009 Report Share Posted May 4, 2009 twelve people looked and not one had a whistler huh...that sux...... I have heard people complain about the whistle before. I have it myself. Without hearing it its hard to say if its a normal normal or not. Post a vid w/ sound!:D Quote Link to comment
jrock4224 Posted May 4, 2009 Author Report Share Posted May 4, 2009 tryin to get it off my blackberry as we speak(type).....man does it run way better with a weber on it then the stock carb.........so good my buddy tried to put it in the ditch for me. my drum brakes are miss adjusted the rears lock up way before the fronts.....kinda fun but scary when you need to brake hard.... Quote Link to comment
jrock4224 Posted May 4, 2009 Author Report Share Posted May 4, 2009 hopefully this works you'll know cause you'll here the referee blowing the ------for a penalty.. Quote Link to comment
jrock4224 Posted May 4, 2009 Author Report Share Posted May 4, 2009 man that shit makes me laugh everytime....perfect for chicks i guess.....sorry about the profanity at the end..... Quote Link to comment
Lozer Posted May 4, 2009 Report Share Posted May 4, 2009 tighten the screws on the top of the carb and double check all the visable nuts and screws. also pull the air cleaner and make sure the throttle plate screws are in tight. other then that it's possibly coming in through the linkage. Quote Link to comment
jrock4224 Posted May 4, 2009 Author Report Share Posted May 4, 2009 :lol::lol::lol::lol::lol::lol::lol::lol::confused: Sorry but it made me laugh then and it still does.......does sound like a leak if you ask me but we double checked everything.......its loud husbands watch out im not whislting at your lady ...its my carb. Quote Link to comment
datto510 Posted May 4, 2009 Report Share Posted May 4, 2009 Wow, you do have a whistle. I'm no expert but that don't sound normal,(kinda cool though:D). Get a can of carb cleaner and spray around the intake, when it revs up, you have found your leak. Quote Link to comment
jrock4224 Posted May 4, 2009 Author Report Share Posted May 4, 2009 tighten the screws on the top of the carb and double check all the visable nuts and screws. also pull the air cleaner and make sure the throttle plate screws are in tight. other then that it's possibly coming in through the linkage. checked the air cleaner and the base plate all seemed tight dunno maybe a day later it will be different......u know how late nights sometimes dont allow you think clearly...(read after several beers):mellow: Quote Link to comment
jrock4224 Posted May 4, 2009 Author Report Share Posted May 4, 2009 Wow, you do have a whistle. I'm no expert but that don't sound normal,(kinda cool though:D). Get a can of carb cleaner and spray around the intake, when it revs up, you have found your leak. tried that too but it didn't pick up the rpms at all leading me to believe that base gasket is still ok......funny though.... Quote Link to comment
datzenmike Posted May 4, 2009 Report Share Posted May 4, 2009 Get a short length of garden hose and hold one end to your ear and the other at different places around the base plate and also at the car top. Have someone rev it and try to narrow down the location. Quote Link to comment
Phlebmaster Posted May 4, 2009 Report Share Posted May 4, 2009 Is it possible you have shaft wear on your primary?? Quote Link to comment
Lozer Posted May 5, 2009 Report Share Posted May 5, 2009 what i meant was make sure the flat head screws on top of the carb arew tight (under the air filter housing) they have a tendancy to walk after a long time and can cause vacuume leak http://www.piercemanifolds.com/34DFT.pdf in the diagram all the screws that hold down #1 Quote Link to comment
datzenmike Posted May 5, 2009 Report Share Posted May 5, 2009 Vacuum is highest at idle, dropping when the throttle is opened. You would think that the whistle would be loudest at high vacuum and get quieter when throttle opened. Venturi vacuum would increase with air flow. Might there be a leak in the vacuum operated secondaries? Quote Link to comment
datsunaholic Posted May 5, 2009 Report Share Posted May 5, 2009 Webers don't have vacuum secondaries, Mike. I had a massive whistle with my 38DGAS after the engine backfired while starting. I'd managed to blow off the ventuii vacuum port cap on the back of the carb. I've never seen that vacuum port on a 32/36, but it's possible for it to exist. Quote Link to comment
yello620 Posted May 5, 2009 Report Share Posted May 5, 2009 Something looks different about that weber. The choke stand sticks out really far compared to most that i have seen. And it appears to be a DFV, not a DGV. Do you have any good pics of this carb? Maybe it is just the video that makes it look weird to me. That whistle is definently not normal, but funny.:D Quote Link to comment
datzenmike Posted May 5, 2009 Report Share Posted May 5, 2009 Webers don't have vacuum secondaries, Mike. I had a massive whistle with my 38DGAS after the engine backfired while starting. I'd managed to blow off the ventuii vacuum port cap on the back of the carb. I've never seen that vacuum port on a 32/36, but it's possible for it to exist. ..... :o Quote Link to comment
banzai510(hainz) Posted May 5, 2009 Report Share Posted May 5, 2009 whts that thing on the side of that weber???????? Never seen thaT BEFORE. GET RID OF THAT.UNHOOK IT ,THE LINKAGE OR SOMETHING Quote Link to comment
jrock4224 Posted May 5, 2009 Author Report Share Posted May 5, 2009 is the electric choke hanging off the side and yes it's a dgv or it was when i ordered it...came off my mazda pick up..... Quote Link to comment
banzai510(hainz) Posted May 5, 2009 Report Share Posted May 5, 2009 here is what Im used to as a aftermarket weber eleltric choke. Quote Link to comment
jrock4224 Posted May 5, 2009 Author Report Share Posted May 5, 2009 yeah i ordered mine two years ago and again its was a weber then it wasn't according to the people i bought it from ....redline weber..... Quote Link to comment
banzai510(hainz) Posted May 5, 2009 Report Share Posted May 5, 2009 maybe look on Webercarbsdirect and ck ou the photos on there of all the carbs. I heard someone say there are some chinese clones but havent actually seen them. Maybe its a Emission CARB(Calf Air Res Board)tyep weber???? Quote Link to comment
datsunaholic Posted May 5, 2009 Report Share Posted May 5, 2009 The photo is so blurry I can't tell what it is. I can't get to the video (blocked here), but the blurry photo looks like maybe it's a DFV or a Holley 5200. Quote Link to comment
