jefe de jefes Posted February 19, 2012 Report Share Posted February 19, 2012 Last one left this morning....thanks Derrick!! :) I have a change or two in mind for this version, but I don't have any idea if and when I will do a setup similar to this again. Thanks to everyone that's bought my kits!!!! :) Damn! A day late. Link to comment
MantisX620 Posted April 17, 2012 Report Share Posted April 17, 2012 Are you making anymore kits? Im hoping to do my 620 up with disk brakes soon. Thanks MantisX Link to comment
mklotz70 Posted April 17, 2012 Author Report Share Posted April 17, 2012 Soon? In my shop, anything under a year seems to be soon. LOL!! I've got some control arms to finish up and then a couple of sets of kingpins to do.....then I'm going to start on a "tweak" to my brake kit. It may be a couple of weeks before I get that figured out. At that point, I'll decide if I'm actually going to make any more or not. From that point, it may take 2-6 mo for me to actually have another batch ready. Link to comment
Charlie69 Posted April 18, 2012 Report Share Posted April 18, 2012 Hi Mike, I need 2 pairs of the brake hose things. Please let me know how much shipped to 89820. Thank you. Link to comment
mklotz70 Posted May 10, 2012 Author Report Share Posted May 10, 2012 I'm installing the bearing adapters and modifying Wayno's spindles for my disc brake kit. I figured I shoot a bit of video during the process. I did both spindles without any heat on the inner adapters. I did use heat on the outers and they went on super easy. I've simple pasted the different clips together. Maybe one of these days, I'll go back and edit it to make it shorter and cleaner, but for now, it is what it is. http://youtu.be/Xd8AR1ii1dI Link to comment
mklotz70 Posted May 10, 2012 Author Report Share Posted May 10, 2012 ....and another for the spindle trimming Link to comment
a2lowvw Posted May 11, 2012 Report Share Posted May 11, 2012 need to make another batch of these... i really want disk brakes and stock steel wheels on my 521 Link to comment
mklotz70 Posted May 11, 2012 Author Report Share Posted May 11, 2012 no plans to any time soon, but we'll see. I need to get my wife's brake kit on her truck and the original disc kit from it shipped off to it's new owner. After that, I'm going to see about starting an new build that I think will create some interest. :) Link to comment
mklotz70 Posted September 16, 2012 Author Report Share Posted September 16, 2012 I'll put this up on my site when I get a chance, but we shot a quick vid on removing the wheel hub from a donor vehicle. I'm gearing up to do another batch of brake kits. I was going to make a couple of changes, but I've decided to go with the same setup as the last couple of batches. I did a bit more checking on the wheel spacer needed and an 1/8" will work, which means that longer studs won't be necessary. The other "new" build mentioned about is pretty much dead. I looked into using the same bracket for a dual piston caliper and a single piston caliper by using either the 720 rotor or the Hardbody rotor and possibly some spacers between the brackets and calipers. With what I found today with the HB rotor, that options is pretty much dead as a serious consideration. It's certainly possible, but it's not something I'd put out in any quantity. I guess I put all the info in this sale thread....probably should have done a build thread LOL Link to comment
mklotz70 Posted September 16, 2012 Author Report Share Posted September 16, 2012 There's a few pics here, but I don't think they completely cover the differences like the video will. I was considering using Hardbody rotors on the next batch. That's what I used on the NL320, which is why if would fit stock rims. The problem is that I would need to redo the inner bearing adapter and push the entire hub out about 2mm so that I could still fit a 3/8" thick bracket behind the rotor. That's easy enough, but I end up with a tight clearance between the rotor and bracket and have to go with a smaller cotter pin, as well. To help decide, I mounted up a stock 521 rim on both setups....720 rotor and HB rotor. The HB rotor does not need the wheel spacer. Turns out the 720 setup only needed an 1/8" spacer, which is good news because anything more would require longer wheel studs. This spacer is only needed with stock rims. All other 14" rims will clear without any issues. I took vid of the comparisons, so I'll post those up when they're done. The pics are in my PB here..... http://s88.photobucket.com/albums/k162/mklotz70/Brake%20Kits/Current%20Truck%20Kit/720%20vs%20Hardbody%20rotors/ Link to comment
mklotz70 Posted September 16, 2012 Author Report Share Posted September 16, 2012 Here's the vid covering the comparison between using the 720 rotor or the HB rotor with my setup. Link to comment
mklotz70 Posted September 19, 2012 Author Report Share Posted September 19, 2012 Checking the wheel offset between the stock drum hub and the disc hub. Short answer....9/16" Also looked into using the dust shield. I'm not going to pursue it any further, but it's certainly possible. More info in the vid when I get them done. Link to comment
mklotz70 Posted September 20, 2012 Author Report Share Posted September 20, 2012 Here's a vid with much, much more info on the fitting of the dust shield. Looks like it will work just fine, but if someone wants to use it on their setup, they'll have to deal with any cutting, drilling, fitting of the shield themselves. Link to comment
mklotz70 Posted September 20, 2012 Author Report Share Posted September 20, 2012 Spent the first half thinking I could move the caliper placement to eliminate the wheel spacer....then realized I couldn't. Link to comment
mklotz70 Posted September 20, 2012 Author Report Share Posted September 20, 2012 The brackets are on order and I've got things started with Datrod to do the cnc lathe work on the adapters. At least they're started :) Link to comment
mklotz70 Posted September 25, 2012 Author Report Share Posted September 25, 2012 Bracket plates/tabs are in. Hopefully, I can get the spacers made and these welded up by the time the adapters come in. Link to comment
a2lowvw Posted October 9, 2012 Report Share Posted October 9, 2012 i need a set badly. Link to comment
mklotz70 Posted October 9, 2012 Author Report Share Posted October 9, 2012 brake brackets or wheel spacers? PM me. Link to comment
mklotz70 Posted November 24, 2012 Author Report Share Posted November 24, 2012 Started working on the brackets by modifying the welding jig just a bit. The cnc'd parts came in. I'll see about getting the brackets welded and machined in the next couple of days so that I can drop them off at the platers next week. Link to comment
mklotz70 Posted December 9, 2012 Author Report Share Posted December 9, 2012 This is a fairly short vid showing the difference between the 620 spindle and the spindles on the earlier models. When I do a 620 kit, I have to re-machine the base of the inner bearing spacer to compensate for this difference. Link to comment
wayno Posted December 13, 2012 Report Share Posted December 13, 2012 They look so pretty sitting on the table. :wub: Link to comment
skyblue Posted December 13, 2012 Report Share Posted December 13, 2012 great vid mike. and awesome theme music. lol. Link to comment
