boomstickracing Posted June 9, 2009 Report Share Posted June 9, 2009 git-er-don =) Quote Link to comment
610SSS Posted June 10, 2009 Report Share Posted June 10, 2009 To start off the exhaust is not squished even though for some reason it looks that way... Must be the angle of the picture. The fuel pressure is going to be set at 3.5psi but is supposed to raise with boost since the carb is in a pressurized box. So basically the fuel pressure needs to be 3.5psi higher than the box pressure at all times. The design is the same way Keith has had his car for longer than I have been alive! He hasn't had any problems I just think the Volvo pump is a little on the powerful side. This week we are going to do some more experiments to find out exactly the problem. Are u using a rising rate fuel reg??? Iv been thinking about doing the same setup as i already have everything needed:cool: Quote Link to comment
Icehouse Posted June 10, 2009 Author Report Share Posted June 10, 2009 Yeah it is rising rate, we are going off of what Keith in Canada did. After more testing on the Volvo turbo pump we have came to the conclusion that the pump is just to much for the regulator, so we are going to try and find a ZX unit. The ZX pump is a much weaker pump. Quote Link to comment
610SSS Posted June 11, 2009 Report Share Posted June 11, 2009 Cant u use a holley blur fuel pump? Quote Link to comment
Icehouse Posted June 11, 2009 Author Report Share Posted June 11, 2009 Cant u use a holley blur fuel pump? We only use pull a part pieces to keep cost down :D Pull a part pump 8 bucks :D That added with a few cheep ebay parts which makes the project pretty cheap in retrospect. The main problem with the Volvo turbo pump is that it moves a HUGE volume of fuel. Since we only need 3.5psi at idle so much has to be returned to the tank it's just impossible for the regulator to flow enough fuel. I think with a pump with less pumping power we should be good. Quote Link to comment
lynchfourtwenty Posted June 11, 2009 Report Share Posted June 11, 2009 try a b13 ga16 sentra pump, that should be pretty low.. or does it have to be from a turbo? Quote Link to comment
Icehouse Posted June 11, 2009 Author Report Share Posted June 11, 2009 try a b13 ga16 sentra pump, that should be pretty low.. or does it have to be from a turbo? It just needs to be inline not intank. Dave picked up a zx one from Pull A Part today so we should be good :D Quote Link to comment
lynchfourtwenty Posted June 11, 2009 Report Share Posted June 11, 2009 ahh duh.. heh cool man, u gunna make it to the auto-x friday? Quote Link to comment
610SSS Posted June 11, 2009 Report Share Posted June 11, 2009 Any fuel pump from a FI motor will flow too much fuel. Is the pressure reg a malpassi carby rising rate?? Quote Link to comment
Icehouse Posted June 11, 2009 Author Report Share Posted June 11, 2009 Any fuel pump from a FI motor will flow too much fuel. Is the pressure reg a malpassi carby rising rate?? Keith has been using an EFI pump for 20 years. The pump just needs to flow a bit less so the regulator can handle it. Since the carb is in the box the fuel pressure will always need to be 3.5psi above the box pressure. Example if the boost is at 15psi the fuel pressure will need to be 18.5psi if not the bowl will run dry. So basically a carb pump won't work. Quote Link to comment
boomstickracing Posted June 11, 2009 Report Share Posted June 11, 2009 anxious to see some turbo burnouts :D Quote Link to comment
Icehouse Posted July 12, 2009 Author Report Share Posted July 12, 2009 Here are a few pics of Dave cruising the car down the freeway. He came up to Franks place then we headed down to the car wash. Even though it's a Ratsun it needs to cleaned :D It was cool the see the car from a different perspective. The sound that thing makes is unruley!!! Just cruising down the freeway it sounds like a semi truck!!! The turbo is SO LOUD!!! Just wanted to share some pics with you guys. Soon it will have an IC behind the drivers side headlight and if Keith doesn't mind helping explain methanol injection it will have that too :D O and the clutch that used to chirp second when it was NA is toasted!!! Gotta do some clutch research then see if we have any decent ones in the clutch pile :D Quote Link to comment
SIXTY-NINE-DIME Posted July 12, 2009 Report Share Posted July 12, 2009 wolfman i have to see this in person! Quote Link to comment
DISLEXICDIME Posted July 12, 2009 Report Share Posted July 12, 2009 is it a l16 0r 18 if so you should grab a old clutch disk and have it relined with kevlar and use a rodster pressure plate Quote Link to comment
Icehouse Posted July 12, 2009 Author Report Share Posted July 12, 2009 wolfman i have to see this in person! Dude it roles out pretty good too!!! Way better than I expected. I can't wait to see how good it goes with some more boost :D Quote Link to comment
stilltwisted Posted July 12, 2009 Report Share Posted July 12, 2009 what brand riseing rate fuelpressure reg are you useing ,, im have problems finding lo pressure one,, they all seam to be built for FI not carbs thanks for the help Quote Link to comment
Icehouse Posted July 12, 2009 Author Report Share Posted July 12, 2009 what brand riseing rate fuelpressure reg are you useing ,, im have problems finding lo pressure one,, they all seam to be built for FI not carbs thanks for the help Are you doing the "carb in box" setup? If so I got all my info from Keith on the 510 realm. He told me that using a holley low pressure regulator with the "high" pressure spring and use a return line with a restrictor. The system seems to work pretty good for what it is. I could take a few more pics if you need them. Quote Link to comment
stilltwisted Posted July 12, 2009 Report Share Posted July 12, 2009 (edited) please ,,take some more pics of the reg ,,it could really help me out thanks not a box but a carb hat ,,very similar Edited July 12, 2009 by stilltwisted Quote Link to comment
610SSS Posted July 13, 2009 Report Share Posted July 13, 2009 How much boost is it running??? Im keen as for more pics:D Quote Link to comment
lynchfourtwenty Posted July 13, 2009 Report Share Posted July 13, 2009 i need videos!!!!!!!!!!! Quote Link to comment
Pedro Posted July 13, 2009 Report Share Posted July 13, 2009 Completed Engine bay pics and video ftw! Quote Link to comment
Icehouse Posted July 13, 2009 Author Report Share Posted July 13, 2009 Okay guys I will try and steel my GF camera and get a good vid and some new pics :D Quote Link to comment
Icehouse Posted July 23, 2009 Author Report Share Posted July 23, 2009 Got the intercooler welded up for Dave the other day. With a few Pull A Part items it was hooked up. Quote Link to comment
72240z Posted July 23, 2009 Report Share Posted July 23, 2009 If thats not ratsun idk what is lol.:thumbup: Quote Link to comment
bonvo Posted July 23, 2009 Report Share Posted July 23, 2009 If thats not ratsun idk what is lol.:thumbup: considering one of the charge pipes has volvo writen on it :P Quote Link to comment
