BoostinBen Posted April 3, 2009 Report Share Posted April 3, 2009 Are any of you guys running a steering box brace like the one from datsport? Are there other companies that make a brace like this that are in the US? I was wondering if anyone has installed one? .. Notice a difference? Also If anyone has a picture of one installed that would be cool im trying to get an idea if it would cause additional clearance issues with the downpipe from my exhaust manifold. my downpipe is already really close to the steering box. Quote Link to comment
Wharf Rat Posted April 3, 2009 Report Share Posted April 3, 2009 Got any pics of it Ben? Quote Link to comment
sssr20det510 Posted April 4, 2009 Report Share Posted April 4, 2009 not in the us but here you go http://www.maddat.com.au/1600.php Quote Link to comment
slohan Posted April 4, 2009 Report Share Posted April 4, 2009 Design Products Racing They sell a brace, and are in the states. Quote Link to comment
djlotus Posted April 4, 2009 Report Share Posted April 4, 2009 Design Products Racing They sell a brace, and are in the states. They also used to be only 25 bux there :mad: Still.... would be quicker and cheaper than a Maddat piece. Quote Link to comment
Guest DatsuNoob Posted April 4, 2009 Report Share Posted April 4, 2009 wonder if those would work for a 620, anyone know? Quote Link to comment
motavated Posted April 4, 2009 Report Share Posted April 4, 2009 But why a 620? Different frame design man. Would this even work? Quote Link to comment
Guest DatsuNoob Posted April 4, 2009 Report Share Posted April 4, 2009 Not sure, I'm away from my garage. I was just curious because I was thinking of doing something similar to brace up some of my "clunky" steering components. Quote Link to comment
Icehouse Posted April 4, 2009 Report Share Posted April 4, 2009 We put one in Hainz's car, I can't imagine doing it with the engine in though... I'd think the trucks frame is much more rigid than a 510 sheet metal frame rail.. Quote Link to comment
Guest DatsuNoob Posted April 4, 2009 Report Share Posted April 4, 2009 for sure Icey, much more rigid. I forgot what mine looked like for a sec. I still plan on doing an idler arm brace though. I've noticed that's my weak link in my steering system, and I've seen it get a little shifty on other dattys as well Quote Link to comment
defdes Posted April 5, 2009 Report Share Posted April 5, 2009 I made my own on my track car out of stainless 3/16" bar stock: Quote Link to comment
vgwagon Posted April 5, 2009 Report Share Posted April 5, 2009 (edited) We put one in Hainz's car, I can't imagine doing it with the engine in though...I'd think the trucks frame is much more rigid than a 510 sheet metal frame rail.. I can imagine, I did it with my VG30 in place. Took forever, and I had to file the holes to fit after drilling at I was a little bit off. Edited April 5, 2009 by vgwagon Quote Link to comment
510six Posted April 6, 2009 Report Share Posted April 6, 2009 Putting the MAD DAT steering brace and the Experimental Engineering idler arm kit did wonders for the steering. The steering brace also makes a nice place to mount a aluminum heat shield around the steering box ( for the forced induction guys). Injecting chassis stiffening foam in the frame rails made a huge difference as well. http://www.vg30.com/510parts.html http://foamseal.org/automotive.htm Quote Link to comment
hang_510 Posted April 6, 2009 Report Share Posted April 6, 2009 kelvin had these plates avail that mount from the wheel well. http://datsun510.com/photopost/showphoto.php?photo=10728 i have this on the sedan and will combine it w/the brace, when the motor comes out. the wagon will have the same set up as well. Quote Link to comment
BoostinBen Posted April 6, 2009 Author Report Share Posted April 6, 2009 What does the Idler arm kit consist of? I want to give my dat all of the steering / handling goodies that I can throw at it. I guess I am just going to pick up the steering brace and see what I can do as far as installing it with the swap already in my car. If I remove my downpipe off the back of the turbo I might have just enough room to bust my knuckles around it. Putting the MAD DAT steering brace and the Experimental Engineering idler arm kit did wonders for the steering. The steering brace also makes a nice place to mount a aluminum heat shield around the steering box ( for the forced induction guys). Injecting chassis stiffening foam in the frame rails made a huge difference as well. http://www.vg30.com/510parts.html http://foamseal.org/automotive.htm Quote Link to comment
69FJWagon Posted April 6, 2009 Report Share Posted April 6, 2009 Hey Ben come on down to Troys we / he is down there most days until 7pm at least check out all the stuff he has available including the steering box brace that you were looking for and it would give me the chance to see your car :D Troys shop is right off the freeway in Fremont about 15-20 minute drive from San Jose Clayton Quote Link to comment
Lozer Posted April 6, 2009 Report Share Posted April 6, 2009 the foam thing got me thinking. Im deffinitly going to foam the frame and the a and c pillar. http://www.grainger.com/Grainger/wwg/itemDetailsRender.shtml?ItemId=1611574493 Quote Link to comment
Icehouse Posted April 7, 2009 Report Share Posted April 7, 2009 Putting the MAD DAT steering brace and the Experimental Engineering Injecting chassis stiffening foam in the frame rails made a huge difference as well. Does the foam absorb water? Would it work for us Washington dudes? Quote Link to comment
510six Posted April 7, 2009 Report Share Posted April 7, 2009 What does the Idler arm kit consist of? I want to give my dat all of the steering / handling goodies that I can throw at it. I guess I am just going to pick up the steering brace and see what I can do as far as installing it with the swap already in my car. If I remove my downpipe off the back of the turbo I might have just enough room to bust my knuckles around it. The idler arm kit is a stainless sleeve with a delrin bushing, it really smooths out steering play. As for the foam , I have had it in the car since 2003 and no rust problems so far. Quote Link to comment
BoostinBen Posted April 7, 2009 Author Report Share Posted April 7, 2009 I was just up there in Fremont after work today picking up some eyebrow trim for the front grille... Id be glad to come by there any time man.. I work in milpitas so its not far for me at all.. let me know what day and Ill swing by. Hey Ben come on down to Troys we / he is down there most days until 7pm at least check out all the stuff he has available including the steering box brace that you were looking for and it would give me the chance to see your car :D Troys shop is right off the freeway in Fremont about 15-20 minute drive from San Jose Clayton Thanks for the detail on the idler arm kit ... I think Ill pick one up. The idler arm kit is a stainless sleeve with a delrin bushing, it really smooths out steering play. As for the foam , I have had it in the car since 2003 and no rust problems so far. Quote Link to comment
Beau M Posted April 7, 2009 Report Share Posted April 7, 2009 Does the foam absorb water? Would it work for us Washington dudes? This is my question also. Very interesting... Quote Link to comment
bonvo Posted April 9, 2009 Report Share Posted April 9, 2009 the foam thing got me thinking. Im deffinitly going to foam the frame and the a and c pillar. http://www.grainger.com/Grainger/wwg/itemDetailsRender.shtml?ItemId=1611574493 make things stiffer yes but a huge fire hazard better have an extingisher handy Quote Link to comment
mike Posted April 9, 2009 Report Share Posted April 9, 2009 Regarding the foam from grainger, is that just the regular expanding foam or does it harden up? Spray foam and the structural stuff are two different birds. Also, as far as flammability, is the denser structural stuff more fire retardant than the expanding stuff? It seems to me that it would be a slow burn/smolder as compared to a quick burst of flame/minor explosion due to less air pockets/trapped oxygen/and surface area of the flammable material. Also the harder/structural stuff is "sealed" in side the frame rails/a-pillars/wherever and I would think that if it were to burn at worst it would be like lighting a jar with a couple inches of gas in it. It will burn on top where the oxygen is but it wont explode... unless you use it for target practice:lol: Has anybody done any real world tests on this stuff for example taking a couple chunks of each both by themselves and enclosed in metal and lighting them on fire? Id be curious to see the results. Oh yeah... Good info in the availability of steering box braces too:rolleyes: Quote Link to comment
