jesusno2 Posted March 15, 2009 Report Share Posted March 15, 2009 Well I have 2 510 wagons now and big "too do lists" so here's mine KA goon Get running correctley Mount battery in rear (have parts) Finish fuel tank (almost done) Shorten driveshaft for longtail trans. All new seals everywhere New seats sound deadning carpet and dash pad cap and cleaning and painting interior parts. Install new rebuit heater stuff (have parts) Finish tc rods (have parts) Install all my new steering components (have parts) Rear brakes and hard line to it. Wheels tires. Work out the kinks from a car that has sat for a long time Eventually paint My orange goon "too do list" Dogleg 5 speed New seats Fix rust around window this summer and re seal (had viynl top) Fix crappy heater Stiffer suspension Install drivers side ball joint and rebuit strut (already did pass side) New bushings tc rods control arm bushings Fix oil leaks (have parts) Wheels and tires (have zx turbo wheels New door seals Non smashed front valance Paint car original orange color Install front grill pieces (have parts) Ok so maybe this might be a almost "wish list" lol! Who else has got one of these never ending lists? Quote Link to comment
Skib Posted March 15, 2009 Report Share Posted March 15, 2009 lol yup i gotta drop the L28et in in 6 days get the wiring in redo the fuel lines install urethane bushing kit and therse a whole list of more shit to buy lol Quote Link to comment
808DA6 Posted March 15, 2009 Report Share Posted March 15, 2009 Every car guy I know has a list. Next weekend's list (complete list would be too long.): 1. Design and build trans x-member. 2. Cut out old trans x-member. 3. Pull motor and prep engine bay: -remove stock LCA/front x-member. -remove remaining stock front suspension. 4. Re-install engine to design front suspension and steering. That's a crap ton of shiet. -Brian Quote Link to comment
bonvo Posted March 15, 2009 Report Share Posted March 15, 2009 (edited) Datsun to do list Body: Finish removing surface rust prime/ paint- started Fill dents and dings prime/ paint Remove taillights Clean taillight lenses and paint housings Transfer locks -75% done Interior: clean Amoral dash and related parts-50% clean Bed line interior- 90% done Pressure wash trunk Bed line trunk Transfer carpet and interior panels from Shelly Transfer pedal assemblies Trim back tray for 6x9s Replace cardboard cover with carpeting Install 6x9s Replace passenger seat Steering wheel adapter Cut hole for shifter Remove “umbrella handle” emergency brake Cut hole for new e brake Transfer e brake Carbon fiber dash work-75% done Undercarriage: Pressure wash undercarriage Bed line undercarriage Drive train: Transfer motor Transfer transmission Transfer rear sub frame Transfer radiator and mounts Transfer electric cooling fan reinstall battery tray Buy new battery Brakes/hydraulics: Transfer brake master and booster Transfer clutch master and line Transfer calipers and rotors Bleed clutch/brake systems Electrical: Reinstall wiring harness Fix wiring harness in some spots Transfer ignition switch and wiring Transfer headlight/foglight assemblies Transfer fog light relay/switch/wiring Transfer electric fan wiring Transfer and relocate tach Buy then wire in stereo Run new wiring for amp and speakers this is just to get this car up to where shelly was to begin with i plan on adding a mild cage while i have the interior stripped Edited March 15, 2009 by bonvo Quote Link to comment
moparvwfreak Posted March 15, 2009 Report Share Posted March 15, 2009 yup. its bigger now but most of the stuff i would have had to do anyway.... stuff to pull front bumper radiator wiring both masters booster steering column doors windows dash seats wiring brake and clutch lines wiper assembly heater box can ya tell i am stripping a cab to replace it??? headliner cut off nose of new cab and whatever else needs to be pulled. welding fix hole in floor pan on the DS of new cab PS is in good shape weld on new core support install EVERYTHING..... transfer over whatever is good replace what needs to be replaced repairmodify 4 wheel disck brakes (eventually) 5spd trans new bed (eventually) console (maybe a VW console if i can make it work) different seats (maybe) Quote Link to comment
az_rat210 Posted March 16, 2009 Report Share Posted March 16, 2009 Too get the car in my sig on the road. Needs: 1) Brakes Bled 2) Seats 3) Grill 4) Bumpers 5) Remount front windshield 6) Double Check Torque of Transmission Mount 7) Register/Insure Once it is on the road. 1) TAKE A BREAK!!! For a few weeks anyways. 2) Finish Interior 3) Install Air Conditioning back in [summers coming]:eek::blink: Quote Link to comment
djlotus Posted March 16, 2009 Report Share Posted March 16, 2009 I really should make a to do list. I kinda just tackle things as I think about them or when they pop up while I'm doing something else. I do have a basic outline though: Get KA mounted Modify/make transmission mount Finish mounting steering column Run wires for engine Get s13 pump into stock 510 tank Finish stripping and bedline the floorboards Fix the dents where the deer ran into my shit Spray bomb the car for the summer :) Get radiator/electric fan Shorten driveshaft Get 2 more steelies to complete the look I want And after its running i need to organize the garage/install garage door opener/line the floor. Quote Link to comment
Edz280zx Posted March 16, 2009 Report Share Posted March 16, 2009 Yeah..I got a list too 280ZX: replace intake/exhaust gasket re-tune carbs install cross-drilled rotors paint wheels black get a front strut tower bar poly the suspension replace old dash cap hook up/rewire stereo The 620: Everything....lol Quote Link to comment
Bleach Posted March 16, 2009 Report Share Posted March 16, 2009 I have a "to buy" list ...and I still need to install the other stuff I already bought. ;) oh, and move my Datsun to my new garage so I can actually work on it. Quote Link to comment
qwik510 Posted March 16, 2009 Report Share Posted March 16, 2009 I really should make a to do list. I kinda just tackle things as I think about them or when they pop up while I'm doing something else. I do have a basic outline though: Get KA mounted Modify/make transmission mount Finish mounting steering column Run wires for engine Get s13 pump into stock 510 tank Finish stripping and bedline the floorboards Fix the dents where the deer ran into my shit Spray bomb the car for the summer :) Get radiator/electric fan Shorten driveshaft Get 2 more steelies to complete the look I want And after its running i need to organize the garage/install garage door opener/line the floor. I may have your steelies Quote Link to comment
bagged_datsun Posted March 17, 2009 Report Share Posted March 17, 2009 i think my "to do list" would take to long to list lol and.... its not even all for me, THANKS AARON! Quote Link to comment
LAYEDOUTB2K Posted March 17, 2009 Report Share Posted March 17, 2009 here goes nothing fix bodywork find tailight + bezel move bumpers closer to match body paint figure out what wheels + tires i want to run hids suicide doors support cab behind doors remove roof balljoint + disk swap mount 12a get weber sidedraft run dual 2" exhaust mount fuel cell bags bodydrop 4 link sheetmetal bed get seats reupholstered make door panels + carpet rechrome bumpers + grill shave misc body parts sheetmetal center console flowing from dash Quote Link to comment
motavated Posted March 17, 2009 Report Share Posted March 17, 2009 Fix paint hood hood bumper stops replace all the gauges replace clutch upgrade brakes fix suspension bushings intake spacer clean and primer floor rhino line the floor cab and bed fix wiring electric fan new higher voltage alternator exhaust etc etc etc Quote Link to comment
6l320datsun3 Posted March 21, 2009 Report Share Posted March 21, 2009 List... List?... yeah it's one hell of one to. Take Cab off frame take apart running gear get everything media blasted find a bench seat rewire entire truck (damn rats) send bed out to get lining refurbish tank put body together fix dents and dings find all trim find steering wheel emblem so on and so on as it goes... Quote Link to comment
Skib Posted March 21, 2009 Report Share Posted March 21, 2009 remove motor and trans. rip out old fuel hardline bend new fuel hardline and install clean trans and reinstall clean engine bay and repaint drop in L28et long block run wiring harness install manifolds hook up electronics ect wait for TB spacer to come - then instal wait for FMIC set up to come - then instal tripple check everything and cross my fingers it starts Quote Link to comment
///FiveOneOh Posted March 22, 2009 Report Share Posted March 22, 2009 (edited) K I'm just gonna hit the magor stuff here... 1969 4 door Finish wireing on KA swap Install fuel pump/surge taank re-assemble body work install carpet cover tranny tunnel cover re-install lighting reprep body paint car 1972 510 wagon stripped to bare shell Install CA18 Wire Ca Make new turbo mani Plumb turbo system mod and install LSD rear end (rx7?) New drive shaft..agian.... install rear disk assy install bucket seats finish recovering and stall new interior panels finish and install rear bench seat paint interior prep and paint engien bay hand flare fender to clear 16s prep and paint body fab and install new exaust 1968 4 door stripped to shell Install interior Install engine (KA?) fix moded frame rails install glass Ratsun up the exterior (its already 4 colours) install exaust Drive 1987 AE86 install exterior lights fix water leak in sun roof install new coil overs get car through VI prep and paint exterior 1989 suzuki Carry tune up engine fab and install new exaust wire up flood lights fix interior leak VW 1993 golf prep and paint bumper and RF fender 1995 golf Fix clutch/tranny issue Thats a very vauge list of my own cars to do list.. theres still more :( Edited March 22, 2009 by ///FiveOneOh Quote Link to comment
Bugeye Posted March 22, 2009 Report Share Posted March 22, 2009 1. Keep truck running...thats about all I have for the 79, as for the 72 the list would be way too long, but if it doesnt sell come next summer its going to the college body shop Quote Link to comment
datrod Posted March 23, 2009 Report Share Posted March 23, 2009 Pay someone to install the new engine in my Z. :D Quote Link to comment
