makya Posted February 17, 2009 Report Share Posted February 17, 2009 Not that kind! I need to find out what Datto trannies were the shortest for the l20 bell pattern. auto or stick can be used, so I'm not that picky. so, what do you know? Quote Link to comment
Llittle_Llama Posted February 17, 2009 Report Share Posted February 17, 2009 are you making a custom driveshaft and just need a short tranny? what is it going in? Quote Link to comment
Pacific coast Datsun Posted February 17, 2009 Report Share Posted February 17, 2009 Pure speculation here but...i believe most Datsun's that came with an L 20 motor & were stick shifts came w/ 5 speeds. & arent most 5 speeds considered "long tails" ? There are both "short" & "long" tail 4 speeds though. Datzenmike or Datsunaholic would know for sure. Quote Link to comment
makya Posted February 17, 2009 Author Report Share Posted February 17, 2009 It's for the 4x, I'm cutting the frame at the back of the cab & doing a 1 link front and rear w/ coils on 36" super swampers. I need a short transmission to allow for the engine to set back 4" and have enough room under the cab for the transmission and divorced dana 20 transfer case. I have a 4 speed now, I'm just looking to see if there is anything shorter. Quote Link to comment
datzenmike Posted February 17, 2009 Report Share Posted February 17, 2009 (edited) These are about 26" long and are considered short tails. STANDARDS F4W63 4spd '68-'73 510, not really strong enough for an L20B. F4W63A 4spd '74-'77 710, '78-'81 HLA10 ('78-'79 have the L bolt pattern, Z after '80) F4W71A 4spd '70-71 240z F4W71B 4spd '71-'76 240z, 260z FS5W63A 5spd '77-'78 200sx, '78-'81 HLA10 (option), stronger than the F4W63 but not as strong as the FS5W71B. FS5W71B 5spd '80-86.5 720s. often found on 4X4s, I don't know what years had them, the '80 would be an L bolt pattern, all other years would need the front half changed to an L bolt pattern. AUTOMATICS 3N71B '71-'73 510 ('68-'70 were Muncie built Borg Warner) Edited February 17, 2009 by datzenmike Quote Link to comment
datsunaholic Posted February 17, 2009 Report Share Posted February 17, 2009 Actually, Pac, even with the L20B the 4-speed was by far the more common transmission. The SHORTEST L-series transmission was the one used in cars, like the 510, 610, and 1st Generation 200SX (76-79). But they are significantly weaker than the 4-speed you have now. Not sure you want to put a transmission that's more likely to grenade on a 4X4. There is a hard-to-find option of using the "short" 4X4 transmission from the later-year 720s, but those would have the NAPS-Z front case so you would have to build a frankenstein tranmission (front case of a L-series 71-series 5-speed and the extension housing off the 720 4X4 5-speed.) Quote Link to comment
Pacific coast Datsun Posted February 17, 2009 Report Share Posted February 17, 2009 Actually, Pac, even with the L20B the 4-speed was by far the more common transmission. I stand corrected.;) Quote Link to comment
Jason Posted February 17, 2009 Report Share Posted February 17, 2009 How about this one ? http://seattle.craigslist.org/see/ers/1037543575.html Quote Link to comment
datto510 Posted February 17, 2009 Report Share Posted February 17, 2009 How about this one ? http://seattle.craigslist.org/see/ers/1037543575.html Oh........ you got me!:eek: Quote Link to comment
makya Posted February 17, 2009 Author Report Share Posted February 17, 2009 How about this one ? http://seattle.craigslist.org/see/ers/1037543575.html shorter.:fu: Quote Link to comment
]2eDeYe Posted February 17, 2009 Report Share Posted February 17, 2009 How long is the one in your truck? Good to see ya back at it :) Quote Link to comment
makya Posted February 17, 2009 Author Report Share Posted February 17, 2009 2eDeYe;132205']How long is the one in your truck? Good to see ya back at it :) 'bout this long[---]:lol: It's a standard 4 speed about 26" IIRC Thanks, I've been on pirate too long, and the fab is wearing off on me. Quote Link to comment
hang_510 Posted February 17, 2009 Report Share Posted February 17, 2009 How about this one ? i didnt know you were pimpin'!?! i shoulda known thats what the van was for! Quote Link to comment
Jason Posted February 18, 2009 Report Share Posted February 18, 2009 LOL, I looked up "tranny" on craigslist and found that somehow! Quote Link to comment
makya Posted February 18, 2009 Author Report Share Posted February 18, 2009 There is a hard-to-find option of using the "short" 4X4 transmission from the later-year 720s, but those would have the NAPS-Z front case so you would have to build a frankenstein tranmission (front case of a L-series 71-series 5-speed and the extension housing off the 720 4X4 5-speed.) So if I build another LZ22 I could use the "short" 720 5speed? did the later year 720's have a divorced transmission? Even If I change over to a Nissan Transfer Case, I need the ability to run it flat so the bottom of the truck can have a full belly skidplate. With a Divorced transfer case I can do that easily. Quote Link to comment
datzenmike Posted February 18, 2009 Report Share Posted February 18, 2009 All I have is this spare long one: Quote Link to comment
sdsurf Posted February 19, 2009 Report Share Posted February 19, 2009 Ok I was going to start my own but I will piggy back here... What was the 4spd in a 72 truck (521)? F4W63? Also I heard there is a 5spd non dogleg, short transmission that will be a direct swap for the 521 4spd. Is this true or was he confused? Quote Link to comment
datsunaholic Posted February 19, 2009 Report Share Posted February 19, 2009 The 521 used a F4W63 with a bolt-on flange output. The 5-speed non-dogleg short transmission was probably a 720 4X4 transmission (which means it would have no speedometer drive). But it's not a direct bolt in, and all I've seen were NAPS-Z (the 720 had a L20B in 1980, but all the transmission I saw in those were long). There is no such thing as a direct bolt in 5-speed for a 521, because all 5-speeds have the rear mount in a slightly different (further rearward) position vs the stock 4-speed. Quote Link to comment
kwoo510 Posted February 19, 2009 Report Share Posted February 19, 2009 (edited) The 521 used a F4W63 with a bolt-on flange output. The 5-speed non-dogleg short transmission was probably a 720 4X4 transmission (which means it would have no speedometer drive). But it's not a direct bolt in, and all I've seen were NAPS-Z (the 720 had a L20B in 1980, but all the transmission I saw in those were long). There is no such thing as a direct bolt in 5-speed for a 521, because all 5-speeds have the rear mount in a slightly different (further rearward) position vs the stock 4-speed. You can bore out the tail housing and insert the speedometer gear. http://i296.photobucket.com/albums/mm179/kwoo510/65%20L320/Progress/720%20Tranny%20Mod/DSCN2132.jpg[/img]"] http://i296.photobucket.com/albums/mm179/kwoo510/65%20L320/Progress/720%20Tranny%20Mod/DSCN2152.jpg[/img]"] Edited February 19, 2009 by kwoo510 Quote Link to comment
datzenmike Posted February 20, 2009 Report Share Posted February 20, 2009 (edited) That's beyond my skill set. Doug my info shows the 521 with a long tail F4W63 Edited February 20, 2009 by datzenmike Quote Link to comment
