Socalman Posted Monday at 01:32 PM Report Share Posted Monday at 01:32 PM I am having low pressure at Idle, I haven't driven since I am waiting on a driveshaft. but idle is about 15- 20psi, I had read somewhere an oil pump from a different model can be used and is higher pressure....I tried to search but had no luck.. Quote Link to comment
russaroll Posted Monday at 02:05 PM Report Share Posted Monday at 02:05 PM you can take the plug off the oil pump and put a small washer in there under the spring. that should increase your pressure a bit. 1 Quote Link to comment
Crashtd420 Posted Monday at 02:23 PM Report Share Posted Monday at 02:23 PM Hitachi OUP0023 Engine Oil Pump https://a.co/d/07bUafOJ 1 Quote Link to comment
banzai510(hainz) Posted Monday at 02:37 PM Report Share Posted Monday at 02:37 PM I recently did both my L motors last year with the above mention pump. Quote Link to comment
Socalman Posted Monday at 03:05 PM Author Report Share Posted Monday at 03:05 PM Thank you! Quote Link to comment
Stoffregen Motorsports Posted Monday at 03:06 PM Report Share Posted Monday at 03:06 PM Yeah it's not a high pressure pump, but high volume, which does increase the pressure. Used to be the L28 turbo pump was the only one, but KA24E pumps are the same. Quote Link to comment
mainer311 Posted Monday at 07:28 PM Report Share Posted Monday at 07:28 PM 15-20psi at idle is completely fine for an L-series. I’m running the OUP0023 pump mentioned above and my pressure at idle while hot is only 25psi. Quote Link to comment
datzenmike Posted Monday at 08:28 PM Report Share Posted Monday at 08:28 PM Oil 'leaks' more and more past the rod and main bearings as they wear. The oil pump simply can't keep up and the pressure drops with age. Shimming would not improve idle and low speed because the volume is the same. Get a KA24E or KA24DE oil pump from a D21 Hardbody. The internal rotors are 13% longer so they move more oil per turn. My tired L20B was 17 PSI at hot idle. With no other change than a used junk yard KA pump it jumped to 29 PSI. Maximum pressure remains the same at 50-55 PSI but it gets there sooner. 2 Quote Link to comment
mainer311 Posted Monday at 10:25 PM Report Share Posted Monday at 10:25 PM 8 hours ago, russaroll said: you can take the plug off the oil pump and put a small washer in there under the spring. that should increase your pressure a bit. Not at idle it won’t. Quote Link to comment
Socalman Posted Monday at 11:58 PM Author Report Share Posted Monday at 11:58 PM Once I get the fans wired in I’ll let it idle a bit. This engine did sit for over a year even though everything looked good and clean inside when I dropped the oil pan and removed valve cover, maybe I’ll even do a compression test. Quote Link to comment
banzai510(hainz) Posted Tuesday at 01:03 PM Report Share Posted Tuesday at 01:03 PM Mine is at about 35 pounds at idle. with 15/40 20/50 oil. just depends what idle is aI guess. so as I come off idle the pressure is 80 Quote Link to comment
datzenmike Posted Tuesday at 01:11 PM Report Share Posted Tuesday at 01:11 PM Pressure goes up immediately as you come off idle. Each turn shoves 13% more oil into the engine and that soon adds up. Maximum pressure is reached sooner and at a lot lower RPM. You can't tell if it's a high volume pump if mounted on the engine, all the differences are internal. Essential if you have a turbo or spray bar. Quote Link to comment
Socalman Posted Wednesday at 12:10 AM Author Report Share Posted Wednesday at 12:10 AM So this is where my concerns are or is it normal? The 1600 was much higher. Quote Link to comment
Socalman Posted Wednesday at 12:11 AM Author Report Share Posted Wednesday at 12:11 AM That’s idling at around 600 Quote Link to comment
mrbigtanker Posted Wednesday at 01:31 AM Report Share Posted Wednesday at 01:31 AM Im going to say yes. Also what oil weight you running, my Robello runs low until you bring it on. No problems. 1 Quote Link to comment
datzenmike Posted Wednesday at 02:08 AM Report Share Posted Wednesday at 02:08 AM 600 is a little low for me, what does it read at 700??? I know you, and I would like more oil pressure, more is better right? but just how much HP is any engine making at idle??? That's right just enough to spin the engine at 600 or whatever RPMs. Can't be that much as you can spin the engine by hand. I looked up starter power and on average around 1 HP. So lets double that as starters don't spin engines at 600 RPMs So if making 2 hp I think 12-15 PSI is plenty of lubrication. 3 1/2 hp lawn mowers rely on splash oiling at 3,500 RPMs. Put a KA oil pump on bet it goes up at least 10 PSI 1 Quote Link to comment
mainer311 Posted Wednesday at 03:31 PM Report Share Posted Wednesday at 03:31 PM 600rpm. Thing sounds like it’s struggling to idle. No wonder it’s low. 1 Quote Link to comment
datzenmike Posted Wednesday at 07:13 PM Report Share Posted Wednesday at 07:13 PM 100 more RPMs is 100 more pumps of oil. Quote Link to comment
banzai510(hainz) Posted Wednesday at 08:01 PM Report Share Posted Wednesday at 08:01 PM Your most likely fine if it was bad your motor would have went bad already If your comfortable at swapping a pump I say 70$ is a good investment esp if you have a cam with stronger springs. with that Pump above Mine would read low once warmed up really good. In mosrning it will be higher with the oil still thick. I would maybe ajust the speed screw and get the speed up or both mixture and speed screw adjustment Quote Link to comment
Socalman Posted Wednesday at 08:18 PM Author Report Share Posted Wednesday at 08:18 PM 11 minutes ago, banzai510(hainz) said: Your most likely fine if it was bad your motor would have went bad already If your comfortable at swapping a pump I say 70$ is a good investment esp if you have a cam with stronger springs. with that Pump above Mine would read low once warmed up really good. In mosrning it will be higher with the oil still thick. I would maybe ajust the speed screw and get the speed up or both mixture and speed screw adjustment 18 hours ago, datzenmike said: 600 is a little low for me, what does it read at 700??? I know you, and I would like more oil pressure, more is better right? but just how much HP is any engine making at idle??? That's right just enough to spin the engine at 600 or whatever RPMs. Can't be that much as you can spin the engine by hand. I looked up starter power and on average around 1 HP. So lets double that as starters don't spin engines at 600 RPMs So if making 2 hp I think 12-15 PSI is plenty of lubrication. 3 1/2 hp lawn mowers rely on splash oiling at 3,500 RPMs. Put a KA oil pump on bet it goes up at least 10 PSI 4 hours ago, mainer311 said: 600rpm. Thing sounds like it’s struggling to idle. No wonder it’s low. I don't claim to know anything about Datsuns, but I love the 521, thus I come and ask questions. I took the advice and also went a step above, I set timing to 14* and idle to 800, everything seems normal, it even sounds preppier on throttle with the dual Dcoe 45s. This is a new install, I havent drove it since I am waiting on a one piece driveshaft...I dont however like the way the 5speed ended up, but that will be added to another post with pictures...Maybe I went the wrong direction somewhere....lol Quote Link to comment
Socalman Posted Wednesday at 08:19 PM Author Report Share Posted Wednesday at 08:19 PM Thanks for the help... Quote Link to comment
banzai510(hainz) Posted Wednesday at 09:33 PM Report Share Posted Wednesday at 09:33 PM (edited) yeah if you have duals I would do 14/15 deg anyways on initial adv. My manual on SU carbs for L1666SSS was 14 Edited Wednesday at 09:33 PM by banzai510(hainz) Quote Link to comment
mainer311 Posted Wednesday at 10:23 PM Report Share Posted Wednesday at 10:23 PM 15 is fine since there’s no vac advance. Quote Link to comment
datzenmike Posted Wednesday at 11:56 PM Report Share Posted Wednesday at 11:56 PM There are 3 types of timing. Initial... set with a timing gun... 12 degrees Mechanical, AKA centrifugal... this timing increases with engine RPM and is designed into the distributor ... about 20 degrees Vacuum advance.... load dependent, light throttle higher advance added, heavy throttle (WOT, wide open throttle) low intake vacuum basically no advance. At full throttle and above 2,500 RPMs the L 4 engines seem to like to run best at 32 degrees total advance That's initial and mechanical added together. Forget vacuum advance you are at WOT. If you increase the initial advance from 12 to 14 it's fine at low throttle and RPMs but at WOT 14 +20 = 34 degrees and you may encounter detonation which is not good. Just listen to your engine when floored above 2,500 and if you hear anything go back down to 12 degrees. Quote Link to comment
Socalman Posted yesterday at 12:02 AM Author Report Share Posted yesterday at 12:02 AM True, I need to check total as well. It’s just really loud with open headers at the moment. lol….. Quote Link to comment
