72 CnC_WaGon Posted December 16, 2008 Report Share Posted December 16, 2008 I have a 71 wagon with an l18 and i was wondering if someone could explain the benits of a u67 head and if i could use it on my motor or what else i can do in terms of performance. I dont want something to crazy.all i know about the head is that it has a soild liftercam i think. Where does it come from? Quote Link to comment
Guest DatsuNoob Posted December 16, 2008 Report Share Posted December 16, 2008 Well, to explain the benefits, we'd have to know what we're comparing it with. What are you swapping out for the new u67? I think all the head specs are on the620.com. Guys, is this right?:confused: Quote Link to comment
gen4maxima536 Posted December 16, 2008 Report Share Posted December 16, 2008 http://www.olddatsuns.com/html/tech/head_ID_2.htm scroll down to the U67. Quote Link to comment
bonvo Posted December 16, 2008 Report Share Posted December 16, 2008 from what i know the u67 head is the square port "non smog" head for the l20b its an open chamber and if im remembering correctly the valves are some of the biggest that cam stock on a 4 cylinder Quote Link to comment
banzai510(hainz) Posted December 16, 2008 Report Share Posted December 16, 2008 solid lifter cam? They all are!!!!!!!!!!!!! better read up on olddatsuns.com!!!!!!!!!!!! Quote Link to comment
datsunaholic Posted December 16, 2008 Report Share Posted December 16, 2008 The only L-series that had hydraulic lifters were 6-cyls in very, very late 280ZXs. There never was a hydraulic lifter 4-cyl in a production vehicle (there may of course been prototypes that never saw production) Quote Link to comment
hang_510 Posted December 16, 2008 Report Share Posted December 16, 2008 from what i know the u67 head is the square port "non smog" head for the l20b its an open chamber and if im remembering correctly the valves are some of the biggest that cam stock on a 4 cylinder sounds 'bout right. ports are already 1.5" too. Quote Link to comment
DISLEXICDIME Posted December 17, 2008 Report Share Posted December 17, 2008 what head do you all ready have because if you have a closed chamber head and you switch to a open chamber head like the u67 you will loose compression Quote Link to comment
datzenmike Posted December 17, 2008 Report Share Posted December 17, 2008 (edited) Stock L18 with stock 4.3cc dish pistons and open chamber head.... 8.37 compression Same as above but with closed chamber head..... 9.002 compression Edited December 17, 2008 by datzenmike Quote Link to comment
