all510 Posted October 25, 2023 Report Share Posted October 25, 2023 Looking to race in vintage racing in Datsun 510 in canada and usa. Question: How does a flowbench built from plans cpompare to a store bought unit. Assuming a competent person is operating the bench? Thanks Quote Link to comment
datzenmike Posted October 25, 2023 Report Share Posted October 25, 2023 Your cfm numbers from a home made one will probably not be comparable to a bought one which is properly calibrated but it will show gains and losses on your work and that is good enough for pointing you in the right direction. Quote Link to comment
Stoffregen Motorsports Posted October 25, 2023 Report Share Posted October 25, 2023 I think if you're porting for yourself, a relative measurement is good enough. L20B? Most vintage run groups want to see an L18 or L16. What group are you going to run with? Quote Link to comment
Icehouse Posted October 25, 2023 Report Share Posted October 25, 2023 Build a L head like Darren down under. Scoot the intake valve over 2mm and run a 4mm bigger intake valve. He made 50hp more then the next guy. Beat everyone so bad they changed the rules. haha. 1 Quote Link to comment
all510 Posted October 26, 2023 Author Report Share Posted October 26, 2023 Thank you every one for responding. let me explain; I am retired now and would like to get back into racing. At my age (74) vintage would be just right. I still have my full race 510 (1800cc long rod motor with cosworth pistons ,dat comp head, Isky cam -close ratio box). What I am looking for in a flow bench is repeatability and changes because I would be measuring any changes against my racing head. Thank you again. Please contact me if anyone would like old pro info from the 1970-80 area . I got my help frrom the best in the usa at the time. 3 Quote Link to comment
iceman510 Posted October 26, 2023 Report Share Posted October 26, 2023 I'm running a 1970 510 vintage car in Michigan and other venues in the midwest. Just restarted this summer. Also running an L18. Vintage is a blast. Enjoy! When you said Dat comp head, do you mean the FIA head or some other version? I know Ermish runs an FIA head with the 50mm Mikunis. Quote Link to comment
datzenmike Posted October 26, 2023 Report Share Posted October 26, 2023 The stock A87 head is ok but the U67 has wider ports. While the A87 is an open combustion chamber there are some closed ones around. The ultimate stock head is the 219 (L16/18SSS) or the re-issued 912* which is the only one with 1.5" intake ports. edit... I had 912 and 219 reversed. Quote Link to comment
Stoffregen Motorsports Posted October 26, 2023 Report Share Posted October 26, 2023 18 hours ago, all510 said: Thank you every one for responding. let me explain; I am retired now and would like to get back into racing. At my age (74) vintage would be just right. I still have my full race 510 (1800cc long rod motor with cosworth pistons ,dat comp head, Isky cam -close ratio box). What I am looking for in a flow bench is repeatability and changes because I would be measuring any changes against my racing head. Thank you again. Please contact me if anyone would like old pro info from the 1970-80 area . I got my help frrom the best in the usa at the time. Good to hear you're back in the game. Not many of the younger generation understand how to build a proper race car anymore using the old tricks. I've recently got back into racing too. We bought a Huffaker built MG Midget last year and have been racing that. I am also building a '62 Sprite for my kids tro race, and my brother and I just picked up a 510 to build for BS/2.5TA racing. Our hiatus was a mere 25 years... Quote Link to comment
RLJ Posted October 27, 2023 Report Share Posted October 27, 2023 What is a 912 head or did you mean 219? Quote Link to comment
all510 Posted October 27, 2023 Author Report Share Posted October 27, 2023 8 hours ago, iceman510 said: I'm running a 1970 510 vintage car in Michigan and other venues in the midwest. Just restarted this summer. Also running an L18. Vintage is a blast. Enjoy! When you said Dat comp head, do you mean the FIA head or some other version? I know Ermish runs an FIA head with the 50mm Mikunis. Hi everyone; I must say that I read forums before but I am not familiar on how to answer or click in the right place. So please advise if don t respond incorrectly. My race head is not an fia head. My dat. head was purchased from dat.comp in 1981 and forwarded directly to a porting service here in canada. The code I will have to look but it is not a 912 head; it is a closed chamber comp head. I raced that head with 1600 motor. Went to 1800 cc in 3 yr later but head was moded for 280z valves with hardened seats. FIA heads came in two types: early and late. Early FIA type were not as successful as planned. The later FIA head worked well but they are rare as hens teeth. I talked to the fellow at rebello in Ca about 5 years ago and he said the old fia heads had too big an intake port and too small exhaust valve and port. He also told me a fairly good race could be made by using an L20b head (W58 I believe). The open chamber head could be plained also. Sorry to be so long winded Quote Link to comment
datzenmike Posted October 27, 2023 Report Share Posted October 27, 2023 2 hours ago, RLJ said: What is a 912 head or did you mean 219? (yeah I had them reversed) The closed chamber 219 casting was a Japanese market head only and used on the L16SSS and the L18SSS in the 510 Coupe. It was never exported but a few would have found their way here as scrapped import engines. They are a highly sought after item for competition and any spares would have been used up by attrition. But, the demand was there, so Nissan reversed the numbers and re-issued them as the 912 casting. These could be ordered with a variety of port and valve sizes. 11041-U8880, a SSS with 32mm (1.25”) intake ports 11041-U0600A, a SSS head with 38mm (1.50”) intake ports 99996-D1160, a race head with factory port and polish work 99996-D1161, a SSS head with the 280ZX P90 Turbo 44mm (1.73”) intake valves and factory port and polish They may still be available in the NSMO catalogue? Some 219 heads are cast with A87 on the side but have a small 219 cast on the lower left front. Quote Link to comment
Stoffregen Motorsports Posted October 27, 2023 Report Share Posted October 27, 2023 the V912 head was a factory repop of the A87/219 head, but it was purposely cast with small ports so racing engine builders could port them how they wanted to. They are pretty rare. In stock form, they don't work that well, because of the small ports. Quote Link to comment
iceman510 Posted October 27, 2023 Report Share Posted October 27, 2023 Yes, the early FIA head has sewer pipe size ports and does not work so well as mentioned. Late head is the ticket for the highest L performance. I have a couple 912 heads. They have both been ported (by someone prior to me), and a couple A87 closed-chamber versions. Not to mention numerous U67 open-chamber heads. 1 Quote Link to comment
Stoffregen Motorsports Posted October 28, 2023 Report Share Posted October 28, 2023 I'd like to get my hands on an FIA head, but just for the novelty factor. Quote Link to comment
all510 Posted October 31, 2023 Author Report Share Posted October 31, 2023 Good evening iceman, my head is an A87. Later on it was modified with slight intake port work in bowl area and 280z valves with hard seats. I found with the 1800 +dome cosworth pistons+1600 rods (longer) it would turn easily to 7500 to 8000 rpm. Have fun Racing. 1 Quote Link to comment
RLJ Posted November 1, 2023 Report Share Posted November 1, 2023 Here you go Matt. https://www.ebay.com/itm/126122209747?mkevt=1&mkpid=2&emsid=e90001.m2368.l2649&plmtId=700009&mesgId=3041&mkcid=8&ch=osgood&bu=43162866692&trkId=94c08671-9698-4441-a9ee-edbc495431a1&cnvId=700003&recoId=126122209747&recoPos=1 Quote Link to comment
Crashtd420 Posted November 1, 2023 Report Share Posted November 1, 2023 Did you see the intake with it.... I bet that would be hard to find by itself.... 1 Quote Link to comment
