engine color, has anybody found a powdercoat that's a close match to Datsun blue?
pdp8
Just like that, I'm planning to powder-coat the block and several other parts small and large and thought it would be nice if I could come up with something like the original color.
  • Replies 16
43 minutes ago, iceman510 said:
For which model?
Seems to me anyone who has the color guards the info so they can charge $30 for a spray can of the paint.
There were pretty much just two blues used for a huge range of models and years.  In my case, I'm doing a 1500 A-series engine.
What Mike said. I have also used Ford blue for blocks. I think the Pontiac blue is the lighter shade and Ford is the darker.
I think that is the way it works, I could be wrong, and it should be the other way around.
I'm pretty over enamel for it's smell, the mess it makes in the shop, and it's relative softness (both mechanical and chemical).  Powdercoat has held up really well on engine applications for me so was going to do this little motor in that manner.  Thing about powdercoat colors is while you can blend different ones to tint, they don't typically have the same pallet and naming convention as automotive paints, hence the question.
British Standard BS 4800 18 C 39 - Fathom blue / Deep river / Dolphin / #3e5b69 Hex Color Code
#3e5b69 Paint Chip
The hexadecimal color code #3e5b69 is a medium dark shade of cyan.
In the RGB color model #3e5b69 is comprised of 24.31% red, 35.69% green and 41.18% blue
Should be able to get anyone to mix it up for you. Maybe someone has a close powder?
I ordered a few cans from
https://www.myperfectcolor.com/
Turned out great
  • Like 3
You're going to have the block powder coated? That means it will be blasted too. Not a bad way to go I guess, but I've never had an engine block powder coated. I just recently powder coated a cast iron transfer case. That came out nice.
20230510_185355_vdb4KJcUAHNJgbTwfMJ5x1.j
20230511_124341.jpg?width=960&height=720
Edited by Stoffregen Motorsports
It's helpful, but not necessary to blast before PC.  Old school hot-tanking would have been a good prep, but we can't do that in CA anymore.
I'm still debating blasting with aggressive media and cleaning really thoroughly vs. blasing with crushed walnut hulls (or even crushed CO2) so I don't have to fear for a stray bit of errant grit getting into the oil galleries.  In retrospect, it might have been good to blast the motor before disassembly, but here we are.
Cleaning the oil galleys is not rocket science, and any builder knows how to do it. Remove all the galley plugs and scrub with long thin brushes. Every blown up race motor I've ever seen had metal in the oil galleys. which was cleaned out with brushes.
I use American Stripping for all my blasting and powder needs, and they have trained me on proper prep for a long lasting finish. They insist that blasting with garnet and purging with heat is the only method to ensure a long lasting finish. I've used other shops in the past that did not always blast before powder and a few of those finishes have failed over the years.
#3e5b69 Paint Chip
Turned out great
Wow, the sample you posted and the color in the photo look completely different to me on the screen.  the actual block looks nice.
The sample card may look different depending on your screen, same with the pic. The actual color is somewhere in between.
This should get you what you need from any good coating/paint shop
British Standard Color: BS18C39 Deep River
