datzenmike Posted December 4, 2022 Report Share Posted December 4, 2022 You no longer have the choice. They are made overseas and that's that. 1 2 Quote Link to comment
KELMO Posted December 4, 2022 Report Share Posted December 4, 2022 Well fiddlesticks. I have been using Wix on the 411. It seems to me I ran across an OEM # at Solvang this year that may still be available through Nissan. I think the # is 15208-H8920. Filters for the A and L motors that I have are still available OEM. Almost makes me wish I still had that job, almost. 2 Quote Link to comment
angliagt Posted December 4, 2022 Report Share Posted December 4, 2022 I just bought a NAPA Gold filter.They WERE made by WIX. There was a note in the bottom of the box that said something like "Because of supply issues,it was made by MANN". Quote Link to comment
datzenmike Posted December 4, 2022 Author Report Share Posted December 4, 2022 I don't really see a big loss or even a small loss of defectiveness here. I switched to WIX after the local Canadian Tire changed to China for there manufacture. There are only one or two styles (maybe more now but obviously different) I select the one for my L20B then compare the ends, mostly the rubber seal position, the threads are all the same, and select a larger (longer) one for Ford 300 IL six, 318 or SBC. These hold more oil and they are up to half the price. I have no intention of not using the new WIX. I would have if I hadn't seen this video and saw the label on the box. Would like to see how well that 'thinner' filter medium works. Quote Link to comment
Ooph! Posted December 4, 2022 Report Share Posted December 4, 2022 To me its just that they moved production at all and that it moved to China. I'm a believer of the ABC doctrine meaning Anywhere but China. I also think that most of the offshoring done isn't because the US production isn't making money its because they can make more by offshoring. Let's hope they keep the quality level the same. 3 Quote Link to comment
john510 Posted December 4, 2022 Report Share Posted December 4, 2022 Well I wouldn't buy it just because they went with China to manufacture it. 2 Quote Link to comment
datzenmike Posted December 4, 2022 Author Report Share Posted December 4, 2022 There's the rub. At any time the quality may change for the worst. Have to keep on top of this. 1 Quote Link to comment
bottomwatcher Posted December 5, 2022 Report Share Posted December 5, 2022 Bigger problem is trying to filter out the fakes. If the real stuff and the fakes come from the same place good luck getting the real thing. 2 Quote Link to comment
datzenmike Posted December 5, 2022 Author Report Share Posted December 5, 2022 Well to a point you can filter out most by NOT using anything from Amazon or WallMart. Stick to main auto parts vendors like NAPA. They should know their suppliers source and the correct ones. Anyone remember the Iran Hostage event? Dragged on for months. The US sent is 8 helicopters (Operation Eagle Claw*) and special forces troops but two of them broke down in the desert and a third one was deemed unfit for use... the mission was scrubbed. Turned out that some simple critical parts were counterfeit. After that the military tightened up it's parts supply chain. *Eagles have talons. 2 Quote Link to comment
datzenmike Posted December 5, 2022 Author Report Share Posted December 5, 2022 1 Quote Link to comment
john510 Posted December 6, 2022 Report Share Posted December 6, 2022 9 hours ago, datzenmike said: Well to a point you can filter out most by NOT using anything from Amazon or WallMart. Stick to main auto parts vendors like NAPA. They should know their suppliers source and the correct ones. Anyone remember the Iran Hostage event? Dragged on for months. The US sent is 8 helicopters (Operation Eagle Claw*) and special forces troops but two of them broke down in the desert and a third one was deemed unfit for use... the mission was scrubbed. Turned out that some simple critical parts were counterfeit. After that the military tightened up it's parts supply chain. *Eagles have talons. That Iran thing was a lot longer than months.444 days. 1 Quote Link to comment
datzenmike Posted December 6, 2022 Author Report Share Posted December 6, 2022 444 days was longer than 14. 73 months????? Was it longer than 1.21years? Six of one, half dozen of the other. Tomato tomahto Quote Link to comment
datzenmike Posted December 7, 2022 Author Report Share Posted December 7, 2022 I'm hearing that Rotella has reduced ZDDP levels mandated now but will keep checking. This video is a year old. ZDDP levels over 1,000 should be fine for old Datsuns. Most regular oils are under 800 so I wouldn't buy them. Quote Link to comment
