Veraciousreasoning Posted October 22, 2022 Report Share Posted October 22, 2022 Hey all So i found a radiator online to replace my old one ( picture below). Ive power washed it and let clr sit in it for 24 hrs and yeah its shot. Took it to a place that does recore and its about $375 to recore it. Which to be honest is insane. So i went online and found a radiator on ebay that is $190. It says it will fit the l20B but my radiator is 22 inches and this one is 18 inches. Has anyone with a l20B bought a new radiator? Here is the radiator https://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=264458755599&category=33602&pm=1&ds=0&t=1567997316000&ver=0&cspheader=1 If you bout one foe the L20B can you send me a link? 1 Quote Link to comment
datzenmike Posted October 23, 2022 Report Share Posted October 23, 2022 Probably for a car with lower hood line. Run it in the 720 and just block off the other 2". Assuming the width works. 1 Quote Link to comment
Veraciousreasoning Posted October 23, 2022 Author Report Share Posted October 23, 2022 34 minutes ago, datzenmike said: Probably for a car with lower hood line. Run it in the 720 and just block off the other 2". Assuming the width works. Yeah on reddit.com/r/datsun abother guy with a 720 said he runs it and it does wonders. I just trust you and ratsun more then the site. Quote Link to comment
bottomwatcher Posted October 23, 2022 Report Share Posted October 23, 2022 Well at this stage with lack of parts you are probably going to have to run something like that. The problem is if the hose necks are only an inch off it causes coolant lines to contact fan ect. You will have to make some kind of adapter for mounting bolts. Anyways not rocket science but we are going to have to substitute parts to keep these old trucks on the road. Quote Link to comment
Ooph! Posted October 23, 2022 Report Share Posted October 23, 2022 Here the thing about aluminum radiators - most shops can't / won't fix them the best you'll get is someone willing to pinch off a passage to stop a leak and the last shop I took one too wouldn't even do that. That stock radiator if it fits, after its re-cored is repairable, you can even do so yourself its like soldering copper plumbing. 2 Quote Link to comment
Veraciousreasoning Posted October 23, 2022 Author Report Share Posted October 23, 2022 13 minutes ago, Ooph! said: Here the thing about aluminum radiators - most shops can't / won't fix them the best you'll get is someone willing to pinch off a passage to stop a leak and the last shop I took one too wouldn't even do that. That stock radiator if it fits, after its re-cored is repairable, you can even do so yourself its like soldering copper plumbing. I went with a different seller and it comes with decent warranty. I plan on getting the old one recored just cant swing the money right now and the local company has mixed reviews 1 Quote Link to comment
Stoffregen Motorsports Posted October 23, 2022 Report Share Posted October 23, 2022 A recore is straightforward and difficult to screw up. Basically all they re-use is the upper and lower tanks. The cost is in the core itself. They are expensive. 2 Quote Link to comment
Veraciousreasoning Posted October 23, 2022 Author Report Share Posted October 23, 2022 1 hour ago, Stoffregen Motorsports said: A recore is straightforward and difficult to screw up. Basically all they re-use is the upper and lower tanks. The cost is in the core itself. They are expensive. Yeah sadly the local spot ive seen a ton of reviews that the weld job and overall quality of work is not worth the money. 1 Quote Link to comment
Thomas Perkins Posted October 23, 2022 Report Share Posted October 23, 2022 (edited) Is your 720 a automatic or stick shift.2WD OR 4WD.Here is a Nissan site showing radiators for the 1980's,which one is your's.https://www.nissanpartsdeal.com/parts-list/1980-nissan-720_pickup/exhaust_cooling/radiator_shroud_inverter_cooling.html Edited October 23, 2022 by Thomas Perkins 1 Quote Link to comment
Crytek89 Posted October 23, 2022 Report Share Posted October 23, 2022 (edited) I grabbed a Mishimoto 240sx radiator for my KA swap; the outlets are a bit off for an SR20 version but if you drill two holes in your front frame cross-member with rubber bushings it can work. https://www.enjukuracing.com/products/isr-performance-aluminum-radiator-nissan-s14-240sx-95-98-sr20det-swap.html 14"x25" Edited October 23, 2022 by Crytek89 2 Quote Link to comment
Veraciousreasoning Posted October 24, 2022 Author Report Share Posted October 24, 2022 I got a direct fit radiator from ebay...will be here thursday 2 Quote Link to comment
