Rusty Dawg Posted February 15, 2022 Report Share Posted February 15, 2022 Howdy, Can anyone help ID this carb I recently picked up? I have looked high and low for a number and only find the number "4-7" stamped on the base of this carb. From what I've read, the model number is usually printed on the side of the bowl, but this one has nothing. Thanks! Quote Link to comment
datzenmike Posted February 15, 2022 Report Share Posted February 15, 2022 Usually identified by what it's on or was on. Single barrels were early E engine, later were 2 barrel. A rebuild kit is mostly gaskets that are reusable anyway. Jets and bleeds don't wear out. The accelerator pump is the hardest to find and replace. Biggest thing you can do is take apart carefully (protect and save gaskets) and clean it. Then set all adjustments to factory settings. 1 Quote Link to comment
Stoffregen Motorsports Posted February 15, 2022 Report Share Posted February 15, 2022 Do a google search for "Nikki Industrial Carburetor". I found one that is a single barrel carb in a two barrel carb body (but one bore is not machined out) and it looks very similar to your single barrel carb. Chances are good that some parts are interchangeable, like gaskets and such. Quote Link to comment
Rusty Dawg Posted February 15, 2022 Author Report Share Posted February 15, 2022 2 hours ago, datzenmike said: Usually identified by what it's on or was on. Single barrels were early E engine, later were 2 barrel. A rebuild kit is mostly gaskets that are reusable anyway. Jets and bleeds don't wear out. The accelerator pump is the hardest to find and replace. Biggest thing you can do is take apart carefully (protect and save gaskets) and clean it. Then set all adjustments to factory settings. The one I have is a two barrel. Quote Link to comment
wayno Posted February 15, 2022 Report Share Posted February 15, 2022 That appears to be a Datsun 320 carb(2 barrel), but mine is missing the throttle cable connection piece yours has. 1 Quote Link to comment
Rusty Dawg Posted February 16, 2022 Author Report Share Posted February 16, 2022 2 hours ago, wayno said: That appears to be a Datsun 320 carb(2 barrel), but mine is missing the throttle cable connection piece yours has. I see what you are saying. So given that it is a carb off of a 320, were there different model numbers or was there only one series used on all 320 model years? Quote Link to comment
320 Newb Posted February 16, 2022 Report Share Posted February 16, 2022 I believe there was only one series used on 320s 1 Quote Link to comment
Rusty Dawg Posted February 28, 2022 Author Report Share Posted February 28, 2022 On 2/15/2022 at 1:16 PM, Stoffregen Motorsports said: Do a google search for "Nikki Industrial Carburetor". I found one that is a single barrel carb in a two barrel carb body (but one bore is not machined out) and it looks very similar to your single barrel carb. Chances are good that some parts are interchangeable, like gaskets and such. I've never had to do any modifications on the linkage on any of my carburetors, so having said that, is it usually not advisable to go with a carburetor that doesn't match your particular set up? I might be giving this single barrel Nikki a shot since my Hitachi once again spilled over with fuel yesterday and I don't think I can trust it any longer. I am within a week of using the carb as a door stopper. 1 Quote Link to comment
Stoffregen Motorsports Posted February 28, 2022 Report Share Posted February 28, 2022 Linkage isn't tough. If you can cut and weld, and are good with basic geometry, you can make any linkage work on any carb. 1 Quote Link to comment
difrangia Posted February 28, 2022 Report Share Posted February 28, 2022 A little shade-tree engineering and whackin' & Jackin' on a motorcycle cable that I dug out of the 'junk box' in the parts counter at a local bike shop (two or three bucks and they were happy to thin out the junk box of something that would probably have eventually ended up in the dumpster) produced a purpose made cable for the Weber 32/36 grafted onto our E1. Same holds on rod-type linkages. In many instances on these old vehicles, there's just not some off-the-shelf widget to get from point-A to point-B. 1 Quote Link to comment
Rusty Dawg Posted March 1, 2022 Author Report Share Posted March 1, 2022 12 hours ago, Stoffregen Motorsports said: Linkage isn't tough. If you can cut and weld, and are good with basic geometry, you can make any linkage work on any carb. Well crap, if that's all I need to know how to do, I guess I'll have to find me someone in town to rig up some linkage to make work on my truck😄 As difrangia mentioned, there's no carb out there that is just a plug and play, but I am not giving up on finding something that even I can make work. Quote Link to comment
wayno Posted March 1, 2022 Report Share Posted March 1, 2022 (edited) If you look at my post with the 4 photos you can see the cable bracket you are missing in the last 2 photos, what does the carb your having issues with have for a bracket, maybe you can use that one, making a bracket is not that hard to make/do, it doesn't even have to be connected to the carb. Edited March 1, 2022 by wayno 1 1 Quote Link to comment
320 Newb Posted March 1, 2022 Report Share Posted March 1, 2022 If anyone needs Nikki carb parts or that cable bracket hit me up. 1 1 Quote Link to comment
Rusty Dawg Posted March 4, 2022 Author Report Share Posted March 4, 2022 On 3/1/2022 at 1:16 AM, wayno said: If you look at my post with the 4 photos you can see the cable bracket you are missing in the last 2 photos, what does the carb your having issues with have for a bracket, maybe you can use that one, making a bracket is not that hard to make/do, it doesn't even have to be connected to the carb. There is a rod/link from the foot pedal to this set up which is on the right side of the carb if sitting in the driver's seat. Quote Link to comment
difrangia Posted March 4, 2022 Report Share Posted March 4, 2022 Kinda looks to me like your 222 pickup has a rod type throttle linkage and the 320's have a cable operated linkage. Our 320 is cable operated. Quote Link to comment
wayno Posted March 4, 2022 Report Share Posted March 4, 2022 I would have to be there to make suggestions, Datsuns are works in progress and get upgrades all the time, maybe you can use a 720 gas pedal assembly, or maybe someone has a 320 pedal/cable assembly, but you will have to figure out the firewall connection. 1 1 Quote Link to comment
Rusty Dawg Posted March 4, 2022 Author Report Share Posted March 4, 2022 3 hours ago, difrangia said: Kinda looks to me like your 222 pickup has a rod type throttle linkage and the 320's have a cable operated linkage. Our 320 is cable operated. That is 100% correct. 1 Quote Link to comment
