TimmyG Posted August 24, 2019 Report Share Posted August 24, 2019 Does this look like a key number to you? It's inside the glove box. No idea. 1 Quote Link to comment
datzenmike Posted August 24, 2019 Report Share Posted August 24, 2019 Usually stamped, I think. That looks more like a ... "for a good time call..." 1 Quote Link to comment
john510 Posted August 24, 2019 Report Share Posted August 24, 2019 6 minutes ago, datzenmike said: Usually stamped, I think. That looks more like a ... "for a good time call..." Except it's missing a number. 1 1 Quote Link to comment
bilzbobaggins Posted August 24, 2019 Report Share Posted August 24, 2019 I would guess its a gate entry number. 1 Quote Link to comment
TimmyG Posted August 24, 2019 Author Report Share Posted August 24, 2019 14 minutes ago, bilzbobaggins said: I would guess its a gate entry number. Yeah I was just thinking it looks like a gate code. 1 Quote Link to comment
720_Jeff Posted August 25, 2019 Report Share Posted August 25, 2019 (edited) The codes for the 720 run from 1 thru 8000. You can find the code on the right hand door key cylinder, on the zinc plated cam, if that is what it is called in the auto industry. The cam is the part that moves to actuate the lock levers when turning the key. If you need the key cuts, I have the Curtis book with all the codes/key cuts Edited August 25, 2019 by 720_Jeff 1 1 Quote Link to comment
TimmyG Posted August 25, 2019 Author Report Share Posted August 25, 2019 1 minute ago, 720_Jeff said: The codes for the 720 run from 1 thru 8000. You can find the code on the right hand door key cylinder, on the zinc plated cam, if that is what it is called in the auto industry. The cam is the part that moves to actuate the lock levers when turning the key. If you need the key cuts, I have the Curtis book with all the codes/key cuts Thank you! 1 Quote Link to comment
Whatarush720 Posted January 11 Report Share Posted January 11 I have a 1983 720 and the numbers i found on the pass door lock cylinder were 32050? Supposedly there is supposed to be a letter as well? Any help would be appreciated. Quote Link to comment
KELMO Posted January 11 Report Share Posted January 11 There should be an "X" in front of the numbers and there should only be 4 digits. Possibly a replacement cylinder? Does one key work door locks and ignition? Quote Link to comment
720_Jeff Posted January 17 Report Share Posted January 17 On 1/10/2024 at 4:35 PM, Whatarush720 said: I have a 1983 720 and the numbers i found on the pass door lock cylinder were 32050? Supposedly there is supposed to be a letter as well? Any help would be appreciated. The Curtis code book that I have, the key numbers don't go up past 8000, so probably some kind of replacement cylinder, not OEM. Maybe a further refinement of what @KELMO asks, does the key even fit in the ignition? if it does, does it work. If both, doors and ignition have been replaced. Quote Link to comment
777AIA Posted January 18 Report Share Posted January 18 Formatted like a gate key entry for a Self Storage unit... * number #. Quote Link to comment
