DARIN 510 Posted December 19, 2018 Report Share Posted December 19, 2018 (edited) I’m looking to replace my 510 68-73 drag link (center link, cross rod, etc. ) I’m trying to find the part number for a three five (555). I don’t want that cheap china crap. I know normally Moog repackages 555 suspension parts as well as many other brands all of which have different part numbers. I’ve searched all over the internet and I keep coming up with the same shit. So hopefully you guys can give me a direction. I’m super picky when it comes to where my parts are made and I want it made in the home land. Nissan part number- 48560-U5200 Centric- 626.42308 I think China Dorman- 523-140 I think China Rare Parts- 26259 is 555 for sure but for $100? Edited December 19, 2018 by DARIN 510 Quote Link to comment
Duncan Posted December 19, 2018 Report Share Posted December 19, 2018 (edited) I found the Nissan Part number for my RHD 510 Center link and actually found one from this seller in Texas, Mine was a TRW part, but it was made in Japan. I would try emailing these guys and ask them about the Country of Origin on this one... https://www.ebay.ca/itm/183318699303 I tried the usual overseas sources for weeks with no luck, I couldn't believe a seller in Texas had a new, M.I.J. piece for a RHD model that was made in Japan for $90.00 Here's a photo of the one I bought. I would bet their's is from the same manufacturer, only the LHD model. If you look closely at their picture, mine had the cotter pin taped to it in the same location. I removed it before this photo.. They might not know since it's out of the box, but I'd give it a shot... Edited December 19, 2018 by Duncan Quote Link to comment
DARIN 510 Posted December 19, 2018 Author Report Share Posted December 19, 2018 Sweet thank you man. Your a life saver ! Quote Link to comment
DARIN 510 Posted December 21, 2018 Author Report Share Posted December 21, 2018 Here is a pic. If you zoom in you can see it’s stamped made in Japan and the 555 logo. Also they use the correct rubber seal just like the factory. Quote Link to comment
datzenmike Posted December 21, 2018 Report Share Posted December 21, 2018 Is there really a difference between RHD and LHD???? It would make sense to make the pitman arm and the idler arm connections the same so only one part would be needed. Quote Link to comment
thisismatt Posted December 21, 2018 Report Share Posted December 21, 2018 Yes, they are different. Fixed ball joint at the pitman arm. If you helicopter it around the tie rod tapers are backwards, and if you roll it at that point the pitman ball joint is upside down, the idler taper is upside down, and the bend of the rod is upside down. 1 Quote Link to comment
Tedman Posted December 21, 2018 Report Share Posted December 21, 2018 McQuay Norris DS849 used to get you a Moog 555 centerlink. Last time I bought a DS849 it was from Autozone, but I can't recall if it was 555. Worked fine, though. Autozone currently has them in stock for $31.99. Quote Link to comment
datzenmike Posted December 21, 2018 Report Share Posted December 21, 2018 9 hours ago, thisismatt said: Yes, they are different. Fixed ball joint at the pitman arm. If you helicopter it around the tie rod tapers are backwards, and if you roll it at that point the pitman ball joint is upside down, the idler taper is upside down, and the bend of the rod is upside down. Got it. The pitman taper is from the bottom while the idler arm is from the top. Quote Link to comment
RandyWanger Posted February 27, 2019 Report Share Posted February 27, 2019 On 12/19/2018 at 6:40 AM, Duncan said: I found the Nissan Part number for my RHD 510 Center link and actually found one from this seller in Texas, Mine was a TRW part, but it was made in Japan. I would try emailing these guys and ask them about the Country of Origin on this one... https://www.ebay.ca/itm/183318699303 I tried the usual overseas sources for weeks with no luck, I couldn't believe a seller in Texas had a new, M.I.J. piece for a RHD model that was made in Japan for $90.00 Here's a photo of the one I bought. I would bet their's is from the same manufacturer, only the LHD model. If you look closely at their picture, mine had the cotter pin taped to it in the same location. I removed it before this photo.. They might not know since it's out of the box, but I'd give it a shot... What's the part number for the RHD one? Quote Link to comment
datzenmike Posted February 27, 2019 Report Share Posted February 27, 2019 It's a center link, there is no drag link on a 510. Drag links never connect to an idler arm. Quote Link to comment
Duncan Posted February 28, 2019 Report Share Posted February 28, 2019 On 2/27/2019 at 12:49 PM, RandyWanger said: What's the part number for the RHD one? It was a TRW Centerlink p/n ES2454. 1 Quote Link to comment
