tdaaj Posted November 10, 2008 Report Share Posted November 10, 2008 anybody know anything about them? i picked up a pair from a 620 in the tacoma pull a part a couple years ago and found them again in my parts room. should i run these in my datsun? any one know what the wattage is? what kind of amperage they draw? Quote Link to comment
1lo620 Posted November 10, 2008 Report Share Posted November 10, 2008 They are just basically aftermarket lights like Hellas etc...I know Steroid bought a 620 over the summer that had a pair. Maybe PM him and see what he says... Quote Link to comment
Cuts metal like mad Posted November 10, 2008 Report Share Posted November 10, 2008 I think they are Hainz's favorite H4 conversion lights! :D Since they are a domed lense instead of flat like the hellas, they look stock. Run'em, but as always, I suggest upgrading the headlight harness since they will draw more power than the old sealed beams. Quote Link to comment
DanielC Posted November 10, 2008 Report Share Posted November 10, 2008 I think the high lows are 55 and 60 watt, and the high only are 55 watt. There is also a 100 watt option for the highs. Quote Link to comment
banzai510(hainz) Posted November 10, 2008 Report Share Posted November 10, 2008 Cibies, Are they the outer lights ? I run them. As for bulbs open them up and should say right on them like 55/60 or 80/100 ect. I would run a H4 harness myself and not to stress the datsun wiring. Quote Link to comment
tdaaj Posted November 10, 2008 Author Report Share Posted November 10, 2008 2 prong bulb so high beam i'm guessing. Quote Link to comment
banzai510(hainz) Posted November 10, 2008 Report Share Posted November 10, 2008 if they are the 2 prong bulb in there I would assume they are the inner High beam lamps(you never said which location u got them out of) and also assume they have a high beam type refector housing not that you could put a H4 bulb in there and use it that way. anyway take rubber cover off and unlatch the bulb from the housing. Look at the from part of the bulb it will say the wattage. If its a 55 watt bulb then yes you can use it on your stock inner high beam loacation as the stock inner lamps are 55watts any way . Quote Link to comment
yello620 Posted November 10, 2008 Report Share Posted November 10, 2008 I have a set for my high beams, cant remember what wattage bulb they have in them, but they are way brighter than stock. Quote Link to comment
tdaaj Posted February 17, 2009 Author Report Share Posted February 17, 2009 these are now for sale, hows @$20 sound? Quote Link to comment
yello620 Posted February 17, 2009 Report Share Posted February 17, 2009 $20 shipped? to 97132 Can i get a better pic of the front of the lenses? I cracked a lense last month. Quote Link to comment
thisismatt Posted February 17, 2009 Report Share Posted February 17, 2009 $20 is a deal - they're like $75/each new, I think. Quote Link to comment
