1970 S30 Nissan FairladyZ "S30 LDY"
five1oh
Installed the fuel rail last night and hooked the AC belt back up.  Loving how it is turning out.  My carb insulators arrived today so I hope to get the carbs and heat shield mounted and on the car.  So far I need to finish the following and then it should be ready to put on the ground and fire up.  CAN'T WAIT to hear it now with the triples and exhaust.
- mount carbs and finalize linkage
- remove factory choke cables
- figure out block breather and valve cover breather
- fill radiator with fluid
- change engine oil and filter
- bleed brakes
- adjust alignment to be somewhat straight and set ride height
- install strut tower bars
- install headlight covers
- replace headlight wiring harness
- rebuild headlight switch
- install finished tail panel and rear hatch (once finished)
The goal is to drive this car to Datslocos in Manteca on 5/18.
33935012308_e3ce6075f0_k.jpgUntitled by five1oh2010, on Flickr
  • Replies 322
Because I have a new hatch coming I had to make sure I got the proper badges for the spoiler (432) I will be installing.  The following Nissan badge is not made and is unobtanium.  Used ones regularly trade for north of $500 when you can find them and that is with pitting/damage.  I am super thankful my car still adorns its original on the hatch but I did not want to risk removing it and using it on the spoiler.
Thankfully a couple of good friends care about the community and made a SUPER limited run of remakes that were preorder only.  Hung from vintage dashes commissioned the project and my friend Brian has a machine shop and made the badges.  Boy does it look good!!!
47819258921_ddfb406b4f_k.jpgUntitled by five1oh2010, on Flickr
  • Like 3
So last night while my wife was at the gym I was in charge of feeding the kids dinner so I took the liberty to use the dinner table to assemble my carbs!!!!!!!!!!!
46902856615_ef3cb98e90_k.jpgUntitled by five1oh2010, on Flickr
40852756703_6100536cf2_k.jpgUntitled by five1oh2010, on Flickr
47766972562_ae8741d5c9_k.jpgUntitled by five1oh2010, on Flickr
46902856695_7da18e4fc7_k.jpgUntitled by five1oh2010, on Flickr
40852756773_46dbd132ef_k.jpgUntitled by five1oh2010, on Flickr
32875366237_57b909bb00_k.jpgUntitled by five1oh2010, on Flickr
47819259651_2868dacde8_k.jpgUntitled by five1oh2010, on Flickr
33941890478_c97cf28550_k.jpgUntitled by five1oh2010, on Flickr
46902856495_68989b9260_k.jpgUntitled by five1oh2010, on Flickr
47029656924_b7e381368a_k.jpgUntitled by five1oh2010, on Flickr
47819259671_a5b43d81e8_k.jpgUntitled by five1oh2010, on Flickr
46902855825_34a964b3c2_k.jpgUntitled by five1oh2010, on Flickr
  • Like 3
Installed the air horns and tightened the manifold bolts from underneath the car.  What a pain but got it done.  I need to figure out how to keep the plug wires from contacting the throttle linkage.
33979818578_62529bb738_k.jpgUntitled by five1oh2010, on Flickr
47857165641_39adeafb8f_k.jpgUntitled by five1oh2010, on Flickr
32912988367_0910396039_k.jpgUntitled by five1oh2010, on Flickr
So I have had new trim for the taillights for months but have been super nervous about pulling them apart to replace it.  I finally gathered enough courage to dive in and followed WoodworkerB's blog online.  I soaked them in super hot water and was slowly able to peel the lens from the backing.  Once the lens was off I broke off the old tabs to remove the trim.
47857181161_d5f95d2c28_k.jpgUntitled by five1oh2010, on Flickr
47857181351_46cfb57966_k.jpgUntitled by five1oh2010, on Flickr
47804861582_b69556bc2a_k.jpgUntitled by five1oh2010, on Flickr
32912988477_fdead34072_k.jpgUntitled by five1oh2010, on Flickr
47804862022_6d9641a224_k.jpgUntitled by five1oh2010, on Flickr
47804861432_7b981e9e5f_k.jpgUntitled by five1oh2010, on Flickr
40890592343_415727c247_k.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
Once apart I took the lenses to my friend Pavel to polish them using a couple different compounds.  The rear of this car is going to be AMAZING!!!
47857165461_76e225d32b_k.jpgUntitled by five1oh2010, on Flickr
47804862112_120e819ebf_k.jpgUntitled by five1oh2010, on Flickr
40890604803_b5b5ad7905_k.jpgUntitled by five1oh2010, on Flickr
33979818738_24df23b5f8_k.jpgUntitled by five1oh2010, on Flickr
40890604903_991139830c_k.jpgUntitled by five1oh2010, on Flickr
47804913642_093cd1bb70_k.jpgUntitled by five1oh2010, on Flickr
40890604973_4d9ff2d06f_k.jpgUntitled by five1oh2010, on Flickr
33979809548_613c2248c4_k.jpgUntitled by five1oh2010, on Flickr
47857180391_0bd360e611_k.jpgUntitled by five1oh2010, on Flickr
  • Like 3
No "low carb" diet for that kid! : )
Beautiful work all through this thread.  I love how you continue to enjoy it as you make improvements.
I cleaned up my battery tray finally 🙂  It just had some surface rust NO cancer which I was happy about.  Would have been easier to do it with the carbs and header off but I managed ok lol.
47965763893_9f700e205a_k.jpgUntitled by five1oh2010, on Flickr
47965737562_2f2d029c77_k.jpgUntitled by five1oh2010, on Flickr
47965737337_5acc4b1914_k.jpgUntitled by five1oh2010, on Flickr
47965763508_a686f8f003_k.jpgUntitled by five1oh2010, on Flickr
47965790226_c755eafd52_k.jpgUntitled by five1oh2010, on Flickr
47965760528_64f63ae217_k.jpgUntitled by five1oh2010, on Flickr
Finished the taillights and got them installed.  Put in all brand new bulbs.  Also cleaned up my inner tail panel and installed.  Getting closer 🙂
47965761178_8de6ef8b05_k.jpgUntitled by five1oh2010, on Flickr
47965759408_652e34233d_k.jpgUntitled by five1oh2010, on Flickr
47965760203_8246e31a64_k.jpgUntitled by five1oh2010, on Flickr
47965759858_4a083e77c1_k.jpgUntitled by five1oh2010, on Flickr
47965790336_c4a36d8eb3_k.jpgUntitled by five1oh2010, on Flickr
47965764133_32372a5580_k.jpgUntitled by five1oh2010, on Flickr
47965737872_8565e764a6_k.jpgUntitled by five1oh2010, on Flickr
47965738147_ba97d77b49_k.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
IT RUNS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  Click picture for video, and fyi you can see the painted brake drum in the video.
The list of "to do" is getting shorter!  Changed the clutch slave and bled last night, downsized the fuel return line to 1/4" because it was too big and leaking during this run video, changed the engine oil.  Tonight the goal is to install the headlight relay harness, headlight covers, and adjust the suspension for ballpark alignment and ride height and maybe just maybe put it on the ground!!!!
47965796811_4f49216759_z.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
  • Like 4
So on Sunday I decided to finally get this car on the ground.  Prior to now I had already set my ride height to tucking about 2 inches of tire in the rear and an inch in the front.  You must remember that this is only my second Z so I am not aware of what that translates to on the ground LOL.  I also knew my exhaust hung pretty low so that was what I was worried about.  My plans were to lower it onto blocks of wood (my normal procedure since I haven't really owned a low jack before and it was experience to drive my cars up stairs of stacked 2x6's and then jack them.
So yesterday I went through my LCA's and TC's and adjusted them to get close to a a good alignment and camber.  Once they were tightened down I put the wheels on:
47993978618_18f1cde687_o.jpgUntitled by five1oh2010, on Flickr
47993980867_d166632d78_o.jpgUntitled by five1oh2010, on Flickr
Since the car was sitting on the 6th notch of the jack stands I decided to lower it in stages.  First I jacked up the front cross member and lowered the jack stands down to the lowest setting.  After that I went to the rear and gently set the car down on a two high stack of 2x6's (again this is my normal procedure).  I found that the jack was stuck so I had to raise the car up and add a 3rd layer of wood.  Once done I was able to get the jack out.....
So I made a little error and I am SUPER thankful it didn't prove to be costly.  Again my plan was to get the car sitting on the blocks of wood and then measure for clearance before driving it "down the stairs".  Well I wasn't able to do that because I am an IDIOT.  I never put the car in gear OR applied the e-brake.........WHOOPS!!
As I started to jack the front of the car up and remove the jack stands the car started rolling back off the rear steps! 😨 Thankfully it moved VERY slowly and the front jack stayed under the front cross member and rolled with the car (a total of two feet.  I was able to scramble to the back of the car to stop it from going out into the driveway.  Also the car was so low the blocks of wood helped the car slow down.  Again this happened very slowly but could have been VERY bad.  I am SO thankful nothing but happened but please learn from me lol.
Here are the pics once I got it off the front jack and onto the "stairs"
47993978428_411845a809_o.jpgUntitled by five1oh2010, on Flickr
47993963368_41cb6fd83c_o.jpgUntitled by five1oh2010, on Flickr
So the next step was to get it fully on the ground.......................WHOOPS
So because of my idiot move above I was not able to measure and adjust should the car be too low:
47994008306_b79bcc5301_o.jpgUntitled by five1oh2010, on Flickr
47994007566_a90cb701d3_o.jpgUntitled by five1oh2010, on Flickr
47993961988_a09300dc47_o.jpgUntitled by five1oh2010, on Flickr
47993961938_eea2741a9d_o.jpgUntitled by five1oh2010, on Flickr
So once it was "on the ground" 😂 I had to figure out how bad it was and figure out how to get it in the air again.....
You will see that I kind of scraped up my driveway backing it out into the street realizing I better get it back in the garage ASAP.
So I am very thankful my dad gave me a low jack (at least in the front) and I was able to wedge it in behind the rear tire and get it under the rear LCA without hitting the body.  I jacked it up there first and then got a normal jack under the rear end to get both wheels off the ground and adjust the rear coilovers.
This picture is actually once it was "lifted" but I wanted to show the marks on the driveway.
47993963202_f0509f3a73_o.jpgUntitled by five1oh2010, on Flickr
I ended up raising the rear 1 inch and I feel like I can live with this height (once exhaust is tucked obviously)
47993960858_399466e09b_o.jpgUntitled by five1oh2010, on Flickr
