COOCHaDAMus Posted August 29, 2017 Report Share Posted August 29, 2017 i replaced pistons & rings in 80' 210 A14 engine to A15 pistons & rings, found that pistons at TDC don't reach top of bore. pics are #1 & #4 at TDC Is this gonna cause any issues. http://s1203.photobucket.com/user/COOCHaDAMus/media/image1_zpszofotyxt.jpg.html http://s1203.photobucket.com/user/COOCHaDAMus/media/image2_zps1bepzn1c.jpg.html Quote Link to comment
wayno Posted August 29, 2017 Report Share Posted August 29, 2017 You need to find another photo hosting service, Photolame isn't going to work anymore. The Jason Grey info doesn't include A series engines, so you will have to wait for someone that knows A blocks to tell you if it will work or not. Quote Link to comment
Cosmonaut Posted August 29, 2017 Report Share Posted August 29, 2017 That year should be a common block, but the crank is different...the length of throw. I would venture to guess that A15 pistons n rods need to match up with an A15 crank.....I guess The issue is a significant loss of compression. Edit: Info from the net "A15 runs 30mm pin height where A14 is 32.5 so by using the UC piston the top of the piston would be a fair bit down the bore." Quote Link to comment
wayno Posted August 29, 2017 Report Share Posted August 29, 2017 If the A15 has a different crank(longer stroke), and the rod is the same, then the wrist pin location would likely be higher in the piston, you would then likely need to use the A15 crank also. Compression ratio loss could be significant, Dmike might know the answer to this, hopefully he will read this and reply. What head do you have, open or closed chamber? 1 Quote Link to comment
Cosmonaut Posted August 29, 2017 Report Share Posted August 29, 2017 Wow, that is a serious gap, I would bet you would b down to difficult starting and significant loos of power. Quote Link to comment
datzenmike Posted August 29, 2017 Report Share Posted August 29, 2017 I would need the combustion chamber and the piston dish volume but yeah that's some serious loss. Flattops would help, but... A14 stroke is 77mm and A15 is 82. This is 5mm and 1/2 that is 2.5mm. Would not the longer A14 rods fix this? 1 Quote Link to comment
datzenmike Posted August 29, 2017 Report Share Posted August 29, 2017 Thought about this on way to work. If A15 pin height is 30 and A14 is 32.5 then they both use the same rod length??? 1 Quote Link to comment
G-Duax Posted August 29, 2017 Report Share Posted August 29, 2017 Either buy the correct pistons, or an A15 crank. Quote Link to comment
angelmanuel Posted September 2, 2017 Report Share Posted September 2, 2017 i think the combination is A15 crank with A14 pistons/rods. Also, use the A15 oil pan Quote Link to comment
