Lozer Posted January 8, 2017 Report Share Posted January 8, 2017 So I finally got my ka24e/de running and dialed in. This thing rips. 11.1 compression using e pistons with the de head, running Rx1 carbs and a l series single pickup distributor, 280zx 5 speed trans LOL. Parts list. e block de head e pistons e lower timing chain ( had to massage the chain guide on the passenger side to accomadate the wider de head) de upper timing chain ( i used a frontier set but a 240sx set works also) e rods or de rods are fine E crank E front cover E water pump E crank pulley E oil pump L series (l20b) distributor shaft L series el dizzy E oil pickup E pan 240sx de throttle cable 240sx alternator Had to fabricate a small part to gap the distance between the de head front cover and the e lower timing cover. Quote Link to comment
flatcat19 Posted January 8, 2017 Report Share Posted January 8, 2017 Good info. Quote Link to comment
datzenmike Posted January 8, 2017 Report Share Posted January 8, 2017 I like where this is going. Velocity stacks... Quote Link to comment
Lozer Posted January 8, 2017 Author Report Share Posted January 8, 2017 I would love to do velocity stacks but I only have about 1.5" on room between the carb face and the strut tower. I'm thinking of doing a tube style intake to a filter jammed in the pass side high beam. 1 Quote Link to comment
datzenmike Posted January 8, 2017 Report Share Posted January 8, 2017 1.5" damn! Quote Link to comment
Lozer Posted January 8, 2017 Author Report Share Posted January 8, 2017 ^ thats what she said. Quote Link to comment
Stoffregen Motorsports Posted January 8, 2017 Report Share Posted January 8, 2017 The intake tube with the filter on the end of it is a great idea. I see those tiny filters on the inlets of sidedraft carbs so often, it's too bad the users don't realize that they suck. 1 Quote Link to comment
Dolomite Posted January 8, 2017 Report Share Posted January 8, 2017 If you want those carbs to run their best, find out the airbox volume from the bike they came off of and do your best to replicate. Motorcycle carbs are designed for a still air charge, even a tube style plenum will probably improve performance. Quote Link to comment
That4doorKiD Posted January 8, 2017 Report Share Posted January 8, 2017 But no headers Quote Link to comment
Lozer Posted January 11, 2017 Author Report Share Posted January 11, 2017 [/url This was not the final setup for the timing lower tensioner. I ended up having to shave some of the face and upper bit of the actual tensioner and cutting down and shaving the guide to have enough clearance. ] Child labor Almost final mock up. This had the upper front timing cover from a frontier. It did not work the area where the de distributor hits and the frontier cover mate there is a tiny and i mean tiny gap that was shooting oil at me whenever i gave it gas. Quote Link to comment
q-tip Posted January 11, 2017 Report Share Posted January 11, 2017 I don't know how the r1 carbs are attached to each other but would it be possible to space them apart so you could get them closer to the head? Does this then run on pump gas with that compression? Quote Link to comment
Lozer Posted January 12, 2017 Author Report Share Posted January 12, 2017 not a bad idea spacing them out more. I'll research but i have a feeling the internal linkage is gonna be the bitch. 91 octane @ 15* runs like a raped ape. I also have a 4.44 rear end so traction is a problem. Quote Link to comment
q-tip Posted January 12, 2017 Report Share Posted January 12, 2017 I have future plans of a high comp de with itbs, the only thing holding the itbs together is the hard fuel lines but I will have to extend the linkage between, I was just curious if the r1's were similar in set up. Quote Link to comment
Lozer Posted January 16, 2017 Author Report Share Posted January 16, 2017 Got the header and exhaust done. Got it out and running. Had to take the timing down to around 10* and I definitely need to lock the mechanical advance. Also 2mm main jets are to big so i now need to order 180 and 190 main jets. Needles are perfect and base setting is good. Made some quick pod style air filters and found out they are too restrictive. Wow this thing sounds mean at wot. 1 Quote Link to comment
