Madkaw Posted August 11, 2019 Report Share Posted August 11, 2019 Bought Redline GL-4 and 5 for my truck. I used the GL4 in my transfer case but my NEW output seal was throwing the oil out ;(. This oil is not cheap. Can I get away with 5 in the transfer case ? I have a lot of it left and I could use it for the transfer case. I believe my flange seal area was corroded just enough that it wouldn’t hold this slippery oil, but maybe seal was not correct either. See the wear on the seal area? This is the seal that leaked This a stock seal . I took the flange off this spare transfer case to use upload imagem 1 Quote Link to comment
datzenmike Posted August 11, 2019 Report Share Posted August 11, 2019 I don't see why you couldn't use GL-5 in the trans case. I don't think there are any copper alloys used in it. Dress the seal surface with some really fine 500 grit paper or replace it. Definitely use a new seal with any synthetic. I learned this also. 1 Quote Link to comment
Madkaw Posted August 12, 2019 Report Share Posted August 12, 2019 Yep- new seal , but seal surface had micro pitting to allow oil out. Funny thing is that my brand new motor smoked at first and smelled like burnt oil. Well the smoke went away but the truck still smelled like burning oil. Well it was the gear oil being slung on my exhaust. I dressed both and picked the best one , which wasn’t the one I had on. Ordering a Nissan seal. 1 Quote Link to comment
CicliDevotion Posted August 14, 2019 Report Share Posted August 14, 2019 The only Redline GL-4 I can find is 75w-90... Its been pointed out that I want 80w-90. Find something other than Redline that’s 80w-90? Or run the 75w-90? 1 Quote Link to comment
Madkaw Posted August 14, 2019 Report Share Posted August 14, 2019 I think it was 75/90, but out of town so I can’t verify 1 Quote Link to comment
datzenmike Posted August 14, 2019 Report Share Posted August 14, 2019 Ginger or Mary Anne? If rated like engine oil the w is a winter viscosity rating in that it's 'thinner when cold so it flows easier but still has the higher temperature 90 viscosity when hot. 1 Quote Link to comment
CicliDevotion Posted August 15, 2019 Report Share Posted August 15, 2019 So either will be fine in hot, sunny SoCal? 1 Quote Link to comment
