B-210 GX Posted October 15, 2016 Report Share Posted October 15, 2016 Wondering if anyone knows how to set proper timing for the A13. Car won't start and this is my best guess why. Quote Link to comment
datzenmike Posted October 15, 2016 Report Share Posted October 15, 2016 There are many reasons for not starting. Timing isn't very high on the list. Timing doesn't change very much by itself, mostly from points wear. As you haven't mentioned taking the distributor out and messing up the timing or any things you have tried, here's a few ideas. For an engine to run you need two things. Spark and fuel Spark Pull a coil wire off and put an old spark plug in the end and lay on a grounded surface. Have someone crank the engine over with the starter. Is there spark???? Fuel Look on the front of the carburetor, there is a sight glass with the fuel level marked. Is there gas??? Let me know which one is missing You might also look at what was the last thing you did to the engine that might have causes this. Like did you have the plug wires off? Was the rotor removed? Coil wire off ? things like that... 1 Quote Link to comment
B-210 GX Posted October 15, 2016 Author Report Share Posted October 15, 2016 Thanks mike, I'll let you know when I get back to the old girl tomorrow. I realize now that it might have been useful to mention that the guy I bought the car from replaced the distributor. I've replaced the fuel pump and filter, along with the coil and plugs. The stock carb was also replaced with a Weber 32/36 by the previous owner. Bit of a project Quote Link to comment
datzenmike Posted October 15, 2016 Report Share Posted October 15, 2016 Well the replaced dizzy has now moved to the top of the list. I'm more familiar with the L series and the distributor only goes in one way. The A series has a gear that must mesh with the cam so the engine should probably be at a known position like top dead center. I'm going to let someone more knowledgeable supply the answer. 1 Quote Link to comment
B-210 GX Posted October 15, 2016 Author Report Share Posted October 15, 2016 Yeah, that's the fun part. Also why I'm considering an L18 swap if I can't work this out. Thanks for the timely and knowledgeable responses. Quote Link to comment
Doctor510 Posted October 16, 2016 Report Share Posted October 16, 2016 Put the motor on #1 TDC compression stroke. Use your thumb or finger to verify this. Install the dist so the lock down plate has adjustment AND the rotor is pointing at the #1 terminal and the points are open. Quote Link to comment
Tom1200 Posted October 17, 2016 Report Share Posted October 17, 2016 It's been awhile but a B210 should have a matchbox style electronic unit, all of the ones I've dealt with had an A14. If the A13 is the same pop the cap, spin the motor round till the ignition rotor is pointing the number one, look down at the timing marks and see where they are. Confirm #1 is at TDC. Static timing shoul be around 7 degrees BTDC, 35-40 degrees at 4000 RPMs. Naturally double check the book, if you don't have a manual go to Datsun1200.com it will have the specs. Tom Quote Link to comment
racerx Posted October 17, 2016 Report Share Posted October 17, 2016 B-210 Gx, there's a guy here that downloaded tons of manuals and may have yours. Basically, setting timing is similar across the board with various cars..difference is timing mark and degrees and/or some people will also set their ttl advance, up to you. Quote Link to comment
racerx Posted October 17, 2016 Report Share Posted October 17, 2016 Forgot to mention it's under General discussion and look for manuals. Quote Link to comment
Stoffregen Motorsports Posted October 17, 2016 Report Share Posted October 17, 2016 Not all caps have #1 marked on them, so if you don't know which one is #1, you may be in trouble. Either way, it ultimately doesn't matter where #1 is on the cap. As long as you have the distributor phased to match and the timing is properly set. Quote Link to comment
datzenmike Posted October 17, 2016 Report Share Posted October 17, 2016 Other than California, all '78 and up Nissan/Datsuns had EI ignition. All were remote igniter to '78 and all were matchbox '79 and on Quote Link to comment
Dguy210 Posted October 18, 2016 Report Share Posted October 18, 2016 74 is a points distributor. Also, remember 74 had the evil seatbelt interlock device and won't start unless a weight is in the seat and the seatbelt closed. I'm the manual guy and I own a 74 B210 too. Unfortunately I don't have a 74 B210 manual up, 75 I do, but 74 had a lot of 1 year only weirdness. See here to set timing, for the a12 but extremely similar with the a13. http://datsun1200.com/modules/mediawiki/index.php?title=Ignition_Timing Quote Link to comment
