Rocky671 Posted December 8, 2015 Report Share Posted December 8, 2015 I am thinking about putting a sr20det into my 85 720 king cab st.Will i have to do alot of mods to my engine bay for a sr20det???? 1 Quote Link to comment
Rocky671 Posted December 8, 2015 Author Report Share Posted December 8, 2015 anydobody happen to know where i can get a sr20det????thats not to pricy lol 1 Quote Link to comment
banzai510(hainz) Posted December 8, 2015 Report Share Posted December 8, 2015 The Classifieds here ,Craigslist wait long enough you WILL t find a KA/SR installed in a Datsun and not running just figure the wiring and you can still drive your truck 1 Quote Link to comment
Draker Posted December 8, 2015 Report Share Posted December 8, 2015 Use the search. 1 Quote Link to comment
Draker Posted December 8, 2015 Report Share Posted December 8, 2015 Ebay? Foreignengines.com? You're going to have to tear them down and inspect everything. Probably going to at least need rings and bearings. By that time.. it's pricy. Just find a KA? 1 Quote Link to comment
TENDRIL Posted December 8, 2015 Report Share Posted December 8, 2015 anydobody happen to know where i can get a sr20det????thats not to pricy lol 2500-3500 is a average price to get one to your door harness and all, or wait to find one locally, keep in mind you cant just get the rebuild parts from any parts store 1 Quote Link to comment
Lockleaf Posted December 8, 2015 Report Share Posted December 8, 2015 Since they are still trendy, they are still decently pricey regardless of condition. As for install, it will likely take the same work a 240sx KA engine would take. I would start by researching that some, as I believe it's more common in 720s than SRs. Basic issues I expect you will run in to: Modify engine mounts Front sump engine, rear sump likely needed Transmission mount may be custom, but then again may bolt in fine. Physically, it will likely clear everywhere but the oil pan, but it's possible you will have turbo clearance issues with the brake booster. 1 Quote Link to comment
datzenmike Posted December 8, 2015 Report Share Posted December 8, 2015 All RWD SRs are imported from Japan so there aren't any just laying around in wrecking yards or back yards. Any SR for sale I would be suspicious of as it's probably been abused to shit. As stated, parts for it won't be found at NAPA or cheap. Your best bet is to save up and go to a shop that specializes in low mileage imports that will have some kind of warranty. You will need the transmission and all the EFI wiring for it too. If you do the work probably 4-5K will do it. An SR20DET in a 720 is like using a race horse to pull a semi trailer. I would go will a larger displacement VG30 or 33 from a domestic vehicle, something with way more shove at low RPMs. 1 Quote Link to comment
RedSquare Posted December 10, 2015 Report Share Posted December 10, 2015 ..... An SR20DET in a 720 is like using a race horse to pull a semi trailer. I would go will a larger displacement VG30 or 33 from a domestic vehicle, something with way more shove at low RPMs. What? Not that I think the OP is going to follow through with this swap. But, I think your analogy is way off. My 720 weighs the same as my S14, despite lightening mods done to the S14. 1 Quote Link to comment
datzenmike Posted December 11, 2015 Report Share Posted December 11, 2015 So it will accelerate about the same but handle a lot worse. 2 Quote Link to comment
RedSquare Posted December 11, 2015 Report Share Posted December 11, 2015 Will handle no worse than your beloved VG33, which is still beside the point. 1 Quote Link to comment
datzenmike Posted December 11, 2015 Report Share Posted December 11, 2015 It's just opinion. Small displacement turbo engines are only fun when revved up. Or swapped into in a smaller light car. Larger displacement engines pull hard right from the start, will do it all day and last forever. 99.999% of driving is at low speeds. 2 Quote Link to comment
Stoffregen Motorsports Posted December 12, 2015 Report Share Posted December 12, 2015 This debate is a good one - torque vs hp. It is an old debate too. You guys should all read the story of the development of the GM Vortec LS V8. At the time, GM was considering dropping the pushrod V8 completely and focusing it's efforts on the multi-valve, multi-cam arrangements. Two guys, on their own time, started the development of the LS to get it to the point where it could be mocked up. They then convinced GM to fund the prototypes. When working prototypes were ready to go, they put one in a ZR1 Corvette and put it alonside a stock ZR1 Corvette. They had GM execs run the cars at Willow Springs raceway without telling them which was which. The results were unpredictable as the majority felt that the ZR1 (LT5) was more fun to drive, but they all agreed that the torque of the LS was actually a faster package. Moral of the story - sometimes, we just want to feel the punch of the turbo kicking in, even though the torque of a N/A engine may actually be the better choice. Quote Link to comment
datzenmike Posted December 12, 2015 Report Share Posted December 12, 2015 Torque is what gets the job done. Period. Torque is a twisting force. HP is a mathematical calculation using torque and RPMs. They are not the same but indicate each other. If you have torque and RPM you can work out the HP. If you have HP and the RPMs you can calculate the torque. There is no way to measure HP directly only calculate it. Torque = HP X 5252 / RPMs. HP = T X RPM / 5252 The more HP you have, the more torque you have. You could say that HP gets the job done but as the HP is derived from the torque so it's better to just say torque. Torque is always higher than HP below 5,252 RPMs HP is always higher than torque above 5,252 RPMs. HP and torque are always the same at 5,252 RPMs. 100 HP at 5,252 RPMs... solve for torque using Torque = HP X 5252 / RPMs 100 X 5252 / 5252= 525200 / 5252 = 100 ft lbs. If your torque remains constant (flat) your HP will double every time the RPMs double. Example 200 HP at 3K will be 400 HP at 6K, will be 800 at 12K. The Z24 makes 130 ft lb at 2,800 RPMs what's the HP at 2,800? HP = T X RPM / 5252 or 130 X 2800 / 5252= 364000 / 5252 = 69.3 HP. ANY engine that makes 69.3 HP at 2,800 RPMs has 130 ft lbs of torque. 1 Quote Link to comment
84720FourWheel Posted December 13, 2015 Report Share Posted December 13, 2015 As the owner of a Pathfinder with the vg30 in it, it's a way better truck engine. Good low end grunt, plus Turbo parts can be adapted from a Z31. Find a later one with the round tooth timing gears and you're set. Pulls the heavier Pathfinder around really nicely. But it does have 4.375s rather than the 4.11s in my pickup. Quote Link to comment
