620 troubles
  • Replies 50
Ok so I'm not sure if it should do this or not but when the starter wire is disconnected and the battery is attached when I put a wrench on the starter I hear it just spinning... Is it supposed to do that or wht
Oh dear, ya stop what you are doing and take up the offer by datsunholic to come take a look, you definitely need experience to track this down, it'll also help you learn basics ;)
Tendril... I do not own a dvom at the moment but i will do that when I buy one
You don't necessarily need a DVM. You know it's 12 volts.
Get a simple to use test lamp for under $5.
Clip the alligator end to any ground and if you touch the probe to 12 volts the handle lights.
When jumpered to steal, likely a wire got hot and melted touching the start solenoid wire. At worst you can run a new wire from the starter to the ignition switch and join around the old one.
No no I want him too I'm lost but I think I may have it figured out now I'll let you guys know
.................................................................. and?
Lmao it was stupid but I can't directly pin point what it was I just rewired all of the wires (I found no open bare wires) I also reinstalled the starter twice basically redid every wire and I put the starter wire on and hooked up the battery and nothing happened I was worried that I did something wrong but I decided to check just in case and I turned it over and it started up but now my lights are giving me issues
Both outer lights work then when I turn my beams on the far right headlight goes out but the center right light comes on and also the little circle the blinker sits at moves a lot and makes my blinkers act up?
I know this is very much off topic but if anyone knows someone selling a 1st gen celica I'd like to buy it
Didn't you just say you were broke like hours ago?
Keep you Honda until you have a dependable car.
1st gen celica and your busted 620 ain't gonna get you to work consistently.
I just sold my Honda. Hated the thing.
315k miles of reliable service. Never left me stranded.
