That4doorKiD Posted October 25, 2015 Report Share Posted October 25, 2015 I was tightening the middle nut to my headers and the stud was loose and sure enough it came out. Does anyone have sizes/SPECS to drill and tap the next size over for a new stud or maybe use a bolt. Thanks. Quote Link to comment
banzai510(hainz) Posted October 25, 2015 Report Share Posted October 25, 2015 Told ya No headers!!!!!!!!!!!! Quote Link to comment
That4doorKiD Posted October 25, 2015 Author Report Share Posted October 25, 2015 Told ya No headers!!!!!!!!!!!! DUDE CAST IRON 1000LB HEADERS WOULD be the same they're even heavier too Quote Link to comment
Draker Posted October 25, 2015 Report Share Posted October 25, 2015 Since the torque on those bolts are so low.. I would just helicoil it. 2 Quote Link to comment
Eomund Posted October 26, 2015 Report Share Posted October 26, 2015 Buy a tap and die set. If the stock threads are too mucked up, drill to a larger size, tap it and just use a good 'ol fashioned bolt, possibly with a lock nut to keep tention. This is a nust in case you havent done a tap nob before, keep cleaning, and keep it well lubed, pecerably with machine oil while tapping it. You'll get the best possible threads that way. 1 Quote Link to comment
jesusno2 Posted October 26, 2015 Report Share Posted October 26, 2015 Heli coil or if you really wanna fix it correctly the time sert is the best way. Quote Link to comment
Draker Posted October 26, 2015 Report Share Posted October 26, 2015 Heli coil or if you really wanna fix it correctly the time sert is the best way. Agreed, but low torque application.. a helicoil will hold. Timeserts are better, but it won't matter much here and helicoils are cheap Quote Link to comment
DanielC Posted October 26, 2015 Report Share Posted October 26, 2015 The exhaust manifold studs are M8-1.25 If the headers do not fit right, you might be torquing the manifold too much, and damaging the stud. I am also a believer in using a stock exhaust manifold. They fit the head much better than headers, and Datsun uses a really good free flowing design for the stock exhaust manifold. 1 Quote Link to comment
banzai510(hainz) Posted October 26, 2015 Report Share Posted October 26, 2015 keen serts are the best. look them up never liked helicoils. They might be OK if you dont have a water passage heated type head then they dont need to be super tight but if you get a water leak youll have to tighten till it stops leaking or till the coil pulls out 1 Quote Link to comment
Stoffregen Motorsports Posted October 26, 2015 Report Share Posted October 26, 2015 I don't like helicoils either, but in this case, especially if a stud is used (not a bolt) it will be fine. The hardest part of the heli coil process is inserting the coil itself and breaking off the tang properly. It may take a coule attempts to get it right. And then once its in, use anti sieze on the threads. 2 Quote Link to comment
