Justin Berni Posted April 30, 2015 Report Share Posted April 30, 2015 So on my 720 I've got an electric fan on the back of the radiator, and it works just fine but I was wondering if there would be any problems if I turned it around, and mounted it on the front of the radiator? I just think it'd look cleaner in the front where you can't see it, I'm doing a wore tuck soon and want my engine bay as clean as possible. 1 Quote Link to comment
datzenmike Posted April 30, 2015 Report Share Posted April 30, 2015 It would be trying to blow air forward againsrt the flow. Unless it can be mounted facing the direction it is now. 1 Quote Link to comment
heretic Posted April 30, 2015 Report Share Posted April 30, 2015 yes big problem..... your current fan is what is known as a puller fan. It pulls the air thru the radiator...... so if you were to put it in front it would be blowing the air away from the front of the truck. In theory you could reverse the polarity of the motor but then your fan blades would be pitched the wrong direction. 1 Quote Link to comment
jrock4224 Posted April 30, 2015 Report Share Posted April 30, 2015 i took pullers and flipped the blades and wired in reverse they have worked fine for two years.... there dual 8" fans ... heretics theory proved ,.... ui bench tested it to make sure i was moving the most air by this method too ...workls good .. not all fan blades can be flipped though ... 1 Quote Link to comment
jrock4224 Posted April 30, 2015 Report Share Posted April 30, 2015 http://vid694.photobucket.com/albums/vv310/jrock42242009/Videos%20of%20Indecision/VID_20130929_113020_zps3070cfff.mp4 1 Quote Link to comment
Lockleaf Posted April 30, 2015 Report Share Posted April 30, 2015 If the fan blades can be reversed, then go for it. Almost all universal aftermarket electric fans are made to work as push or pull fans by following the instructions these guys posted above. Flip blades and reverse polarity. 1 Quote Link to comment
Doctor510 Posted April 30, 2015 Report Share Posted April 30, 2015 "Most" after market electric fans do not require blade flip, just reverse the wiring. 1 Quote Link to comment
jrock4224 Posted April 30, 2015 Report Share Posted April 30, 2015 mine did .. but hes right .... mine blew with out flipped blades but blew harder then q tip at a dicks location on friday night, with the blades reversed 1 Quote Link to comment
jrock4224 Posted April 30, 2015 Report Share Posted April 30, 2015 dicks is a burger place..... q tip is gluten free... hence why him blowing has two connotations 3 Quote Link to comment
EastBay521 Posted May 1, 2015 Report Share Posted May 1, 2015 According to sir mixalot "Dicks is a place where the cool hang out" 1 Quote Link to comment
datzenmike Posted May 1, 2015 Report Share Posted May 1, 2015 dicks is a burger place..... q tip is gluten free... hence why him blowing has two connotations Actually a double entendre. Just like Ricks old title 'Likes the Richard'. 1 Quote Link to comment
Lockleaf Posted May 1, 2015 Report Share Posted May 1, 2015 "Most" after market electric fans do not require blade flip, just reverse the wiring. Ok fine. GOOD aftermarket fans allow for blade flip. Simple engineering fact, optimized fan blades aren't going to move the same amount forward as in reverse. They are biased to increase the air flow they push. And since push fans are not as efficient for cooling purposes across a radiator as a pull fan, just reversing a fan motor will count against your cooling efficiency twice. I'm all for doing whatever works, but if it takes the same effort to do it better, why not? 2 Quote Link to comment
Charlie69 Posted May 1, 2015 Report Share Posted May 1, 2015 Curious as to what affect a 40 mile an hour wind has on both the puller and the pusher fans as far as the volume of air they push or pull through a radiator? Quote Link to comment
jrock4224 Posted May 1, 2015 Report Share Posted May 1, 2015 According to sir mixalot "Dicks is a place where the cool hang out" not true at all .... used to be ... but now it is over run by fans boys and the burgers arent what they were in the 80's but still a good time .. 1 Quote Link to comment
jrock4224 Posted May 1, 2015 Report Share Posted May 1, 2015 Ok fine. GOOD aftermarket fans allow for blade flip. Simple engineering fact, optimized fan blades aren't going to move the same amount forward as in reverse. They are biased to increase the air flow they push. And since push fans are not as efficient for cooling purposes across a radiator as a pull fan, just reversing a fan motor will count against your cooling efficiency twice. I'm all for doing whatever works, but if it takes the same effort to do it better, why not? not to mention putting cooling fans over the leading side of your radiator decreases its ability to cool when not on ... but i like not seeing them .... if i had a temp issue i would reconsider.... but my temp issue now is a tiored l16 and a heavy right foot to go with 388 and a 5sp... 1 Quote Link to comment
jrock4224 Posted May 1, 2015 Report Share Posted May 1, 2015 Actually a double entendre. Just like Ricks old title 'Likes the Richard'. wait my title is not even original ???? 1 Quote Link to comment
