spdcrazy Posted March 4, 2015 Report Share Posted March 4, 2015 thinking of picking up these as they seem to be of better quality than a lot of the eBay and amazon types.. thoughts? http://www.genssi.com/index.php/automotive-lighting/headlights/5-3-4-inch-round-euro-style-premium-headlights-upgrade-4000-4040-5506-h5006.html anyone have personal experience with this company? Quote Link to comment
datzenmike Posted March 4, 2015 Report Share Posted March 4, 2015 Yeah they'll be fine plus you can get the bulb size you want. Quote Link to comment
flatcat19 Posted March 4, 2015 Report Share Posted March 4, 2015 They look pretty legit. Thanks for finding those. Quote Link to comment
spdcrazy Posted March 4, 2015 Author Report Share Posted March 4, 2015 that was my thought.. amazon has a kit i'm liking the idea of.. http://www.amazon.com/Genssi-Round-Clear-Crystal-Headlights/dp/B00DLJ6FXI/ref=sr_1_12?s=automotive&ie=UTF8&qid=1425443842&sr=1-12&keywords=5.75+headlight Quote Link to comment
Dolomite Posted March 4, 2015 Report Share Posted March 4, 2015 I've been wanting the hellas, Damn expensive though. If you get them, let us know how they are. Quote Link to comment
Laecaon Posted March 4, 2015 Report Share Posted March 4, 2015 Those are just Autopal brand lights. Please don't put HIDs in them. Quote Link to comment
flatcat19 Posted March 4, 2015 Report Share Posted March 4, 2015 that was my thought.. amazon has a kit i'm liking the idea of.. http://www.amazon.com/Genssi-Round-Clear-Crystal-Headlights/dp/B00DLJ6FXI/ref=sr_1_12?s=automotive&ie=UTF8&qid=1425443842&sr=1-12&keywords=5.75+headlight Those are just Autopal brand lights. Please don't put HIDs in them. That. Don't be that guy. Quote Link to comment
spdcrazy Posted March 4, 2015 Author Report Share Posted March 4, 2015 I assume because it won't focus the light correctly? Quote Link to comment
banzai510(hainz) Posted March 4, 2015 Report Share Posted March 4, 2015 Those are Indian clones but will be fine. I have Hella and Cibies But you need a H4 harness for the added power and not melt your wires!!!!!!!!!! Deltalights have some also ck out this site. http://www.deltalights.com/?q=store#!/LED-5-3-4-HIGH-BEAM-HEADLIGHT-SYSTEM-(Pair)/p/29120228/category=2078037 1 Quote Link to comment
spdcrazy Posted April 29, 2015 Author Report Share Posted April 29, 2015 Those are just Autopal brand lights. exactly right, i posted to my build thread, but guess i forgot to do so here.. i bought the genessi brand headlights from amazon, and i received autopal's. but damn i'm happy. no HID kit by the way, Quote Link to comment
banzai510(hainz) Posted April 29, 2015 Report Share Posted April 29, 2015 hope you have a H4 harness for those lamps. stock wiring might not take it long. http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#OnLineOrdering 1 Quote Link to comment
spdcrazy Posted April 30, 2015 Author Report Share Posted April 30, 2015 I don't as of yet. Read up on it a bit. And tested it during the day. So far so good. But I will upgrade soon. Rather not have a meltdown. Exp while driving. However that link is out of stock. I could make my own, but I'm not crazy about electrical. Quote Link to comment
DanielC Posted April 30, 2015 Report Share Posted April 30, 2015 521 trucks are really easy to upgrade the headlight wiring. The original 521 headlight relay gets power on a red with a yellow stripe wire. If you take that red w/yellow wire off the original relay, you can use it to trigger an added relay in the engine compartment, by the original headlight relay. This added relay gets fused power directly from the battery, or starter, or battery side of the fuse block. This bypasses headlight electrical power from the fuse box, cab harness to engine harness connectors, headlight switch, and its connector, and all the wires between that stuff. Put a new relay by the original headlight relay. Pull the red w/yellow wire off the original relay, plug in on pin 86 of the new relay. Ground pin 85 of the new relay. Turning the headlight switch should cause the new relay to click. Run a short 12 gauge jumper wire from pin 87 of the new relay to the empty pin on the original relay. Run a 12 or even 10 gauge fused wire to the battery positive, battery side of the fuse box, or the starter lug, from pin 30 of the new relay. If you have a 521 with only three hot fuses, with the ignition off, the headlights and all the other lights use only one fuse. A short in the tail lights, or added trailer light wiring can blow this fuse. If that happens, taking the added power wire off pin 30 of the new relay, and plugging it on the pin on the old relay where the red w/yellow wire was, causes the headlight to come on, without needing the fuse in the original 521 fuse box good. Quote Link to comment
banzai510(hainz) Posted April 30, 2015 Report Share Posted April 30, 2015 ebay and other palces have the, victoria British sells kits also. Most made in China hella has them and others but expensive. My chinese ones are Ok I got from 4 crawlers Quote Link to comment
