The ratty/low/back to life/u.s.s/daily/ka24de 521 thread
datson4life
  • Replies 522
You need to press the bearing off the shaft and the rest of the stuff will come with it. You can cut up the backing plate to use as a spacer to maintain the shim/backing plate/bearing housing thickness which sets the axles depth into the housing.
Basically the bearing is holding everything on.
