hobospyder Posted March 28, 2016 Report Share Posted March 28, 2016 I removed mine by holding the backing plate and banging on the floor. Mechanic directed even, he was standing there when I got the first one off 1 Quote Link to comment
hobospyder Posted March 28, 2016 Report Share Posted March 28, 2016 Either that or a press 1 Quote Link to comment
finney Posted March 28, 2016 Report Share Posted March 28, 2016 I also banged my axel on the floor whilst holding the backing plate. Was a absolute mission. 1 Quote Link to comment
hobospyder Posted March 28, 2016 Report Share Posted March 28, 2016 You might want some padding if going that route though, can be somewhat painful after 15 minutes 1 Quote Link to comment
datson4life Posted March 28, 2016 Author Report Share Posted March 28, 2016 Oh ok. So the backing plate comes out towards studs? 2 Quote Link to comment
datson4life Posted March 28, 2016 Author Report Share Posted March 28, 2016 Or towards axle splines? 1 Quote Link to comment
hobospyder Posted March 28, 2016 Report Share Posted March 28, 2016 Towards splines. Bang spline end on ground, sorry wasn't clear 2 Quote Link to comment
]2eDeYe Posted March 28, 2016 Report Share Posted March 28, 2016 You need to press the bearing off the shaft and the rest of the stuff will come with it. You can cut up the backing plate to use as a spacer to maintain the shim/backing plate/bearing housing thickness which sets the axles depth into the housing. Basically the bearing is holding everything on. 2 Quote Link to comment
datson4life Posted March 28, 2016 Author Report Share Posted March 28, 2016 Ok. Thanks fellas. Ill take it with me to work and have at it today 1 Quote Link to comment
datson4life Posted April 2, 2016 Author Report Share Posted April 2, 2016 TA-DA!!! Life is easy with heat and a press, also to make life easier the company i work at stocks all these seals and bearings (except front inner, im still researching) 3 Quote Link to comment
flatcat19 Posted April 2, 2016 Report Share Posted April 2, 2016 Front inner...get the Klotz adapter to run 620 bearings. 2 Quote Link to comment
datson4life Posted April 2, 2016 Author Report Share Posted April 2, 2016 Front inner...get the Klotz adapter to run 620 bearings. I have all those goodies already Just taking the challenge of finding those inner ones 1 Quote Link to comment
datson4life Posted April 2, 2016 Author Report Share Posted April 2, 2016 Well it got boring driving my old work truck to work. So i got this. Wanted to be like skyblue but they painted it in 79 4 Quote Link to comment
datson4life Posted April 2, 2016 Author Report Share Posted April 2, 2016 They had record of everything, down to each time they put gas [/url] 1 Quote Link to comment
datson4life Posted April 2, 2016 Author Report Share Posted April 2, 2016 But then halfway home i broke down. This is where im at. Chowchilla, ca . Blew the heater hose, feels good to brake down. Its been a while, u get used to this 2 Quote Link to comment
flatcat19 Posted April 2, 2016 Report Share Posted April 2, 2016 You don't need those bumperettes. You want to give them to el gato. 2 Quote Link to comment
flatcat19 Posted April 2, 2016 Report Share Posted April 2, 2016 Did the Jedi mind trick work? 1 Quote Link to comment
datson4life Posted April 2, 2016 Author Report Share Posted April 2, 2016 Jedi mind? Lol 2 Quote Link to comment
datson4life Posted April 3, 2016 Author Report Share Posted April 3, 2016 Wont start anymore. Engine rattle when pipe burst. Might of drove it hot to get to gas station. Hopefully just head gasket or valve adjustment 4 Quote Link to comment
mrbigtanker Posted April 4, 2016 Report Share Posted April 4, 2016 Is this your new truck? If so very nice. 2 Quote Link to comment
datson4life Posted April 4, 2016 Author Report Share Posted April 4, 2016 Is this your new truck? If so very nice. Yes and thank u My desire is to just daily it to work (4 miles) 2 Quote Link to comment
mrbigtanker Posted April 4, 2016 Report Share Posted April 4, 2016 Yes and thank u My desire is to just daily it to work (4 miles) Right, make sure no one eggs it.lol 1 Quote Link to comment
Ed-datsun521 Posted April 4, 2016 Report Share Posted April 4, 2016 Hey hook me up with those bumpperetsss 2 Quote Link to comment
datson4life Posted April 4, 2016 Author Report Share Posted April 4, 2016 I only bought it cause it had bumperrettes! Lol 2 Quote Link to comment
skyblue Posted April 4, 2016 Report Share Posted April 4, 2016 I like it. It will make a fine DD once you iron out the wrinkles. 2 Quote Link to comment
