67_1600 Posted May 28, 2014 Report Share Posted May 28, 2014 So I've been having issues with my ignition switch having to press in with the key to get it to crank. Today I stopped by the Arlington PnP and now I can't get it to crank at all. Battery is good; it's just the switch. What do I need to do so o can get back home? By push in, I mean really push in pretty hard when I turn the key to the start position. Thanks in advance. Quote Link to comment
67_1600 Posted May 28, 2014 Author Report Share Posted May 28, 2014 And just like that the Flippin thing decided to work. Any suggestions for future reference? New switch will be found, but in case someone else had the same issue... Quote Link to comment
ggzilla Posted May 28, 2014 Report Share Posted May 28, 2014 Yes get a new switch. Quote Link to comment
Tristin Posted May 28, 2014 Report Share Posted May 28, 2014 Oh, I was getting in the car to come snag you... glad you got it fixed up. Hate being stuck somewhere. 1 Quote Link to comment
datsunaholic Posted May 28, 2014 Report Share Posted May 28, 2014 I had that issue about 2 months ago. One other symptom was the ACC would cut in and out on bumps. I took the switch out to replace it and found that the back of the switch (the part with the electrical prongs) was pushing its way out the back of the lock can. So, I shoved it back in and rebent the holding tabs (which were loose) and the switch has worked fine ever since. 1 Quote Link to comment
dr.feltersnatch Posted May 28, 2014 Report Share Posted May 28, 2014 just fyi all you need is power to the positive side of your coil. so find a piece of wire long enough to go from batt + to the coil+. the car wont turn off until that wire is removed. once thats connected grab a wrench and put it across the 2 terminals on the starter. it will spark. dont be a pussy andjust go for it. this will make your starter turn. MAKE SURE ITS OUT OF GEAR! this will make your car run but not your accessories so no radio. ps i pmed you my number in case you need help/ i work right there at the airport Quote Link to comment
ggzilla Posted May 29, 2014 Report Share Posted May 29, 2014 1967 has the ignition switch built into the key lock doesn't it? Later Datsuns have ignition switch bolted to the back of the key lock. Quote Link to comment
dr.feltersnatch Posted May 29, 2014 Report Share Posted May 29, 2014 name is kinda misleading, he drives a 71(?) goon. Quote Link to comment
Tristin Posted May 29, 2014 Report Share Posted May 29, 2014 name is kinda misleading, he drives a 71(?) goon. Its for a 1967 1600 Roadster. Quote Link to comment
67_1600 Posted May 29, 2014 Author Report Share Posted May 29, 2014 Thanks for the info, guys. I probably should have specified but my username doesn't reflect my car any more - I sold my Roadster a few years ago. Roy was right, it's my 71 goon that was having the issue. I'd tried and tried but could only get it to click. After I more or less gave up fiddling with it and made the thread I tried again and it started. The wagon is here in the garage now waiting on a new switch.Thanks again. 2 Quote Link to comment
dr.feltersnatch Posted May 29, 2014 Report Share Posted May 29, 2014 i have one out of a 620. its not a locking one, but if you can use it temporarily its yours Quote Link to comment
ggzilla Posted May 29, 2014 Report Share Posted May 29, 2014 Easy then. Unbolt the switch and turn it by hand. 2 Quote Link to comment
bananahamuck Posted May 29, 2014 Report Share Posted May 29, 2014 If the dash lights and all work , try banging on the starter next time. Quote Link to comment
dr.feltersnatch Posted May 29, 2014 Report Share Posted May 29, 2014 Easy then. Unbolt the switch and turn it by hand. unless its the switch thats going bad. Quote Link to comment
banzai510(hainz) Posted May 29, 2014 Report Share Posted May 29, 2014 Put the key to ON and push start 2 Quote Link to comment
q-tip Posted May 29, 2014 Report Share Posted May 29, 2014 I would put my money on the switch being bad or not in all the way Quote Link to comment
67_1600 Posted May 29, 2014 Author Report Share Posted May 29, 2014 I would put my money on the switch being bad or not in all the way I'm going to play around with it more today - after looking at the image above and the symptoms, this might very well be the case. Either way, I've got a new whole unit coming - mine is pretty worn and there is at least one broken part inside. 1 Quote Link to comment
q-tip Posted May 29, 2014 Report Share Posted May 29, 2014 Only one....lucky.... Quote Link to comment
67_1600 Posted May 29, 2014 Author Report Share Posted May 29, 2014 Only one....lucky.... at least one... I'll have to take a look at a new unit to see how bad it really is. I know for sure there is 43 years or so of key shavings in there and I can't imagine that helps. With regards to the switch, it looks like that might be the problem - I tried it on it's own and had to push in pretty hard with a screwdriver while turning to get it to crank and then it only worked once. I did have to jump my car because my battery went dead overnight (brake light switch) but it sure seems like the switch. Quote Link to comment
]2eDeYe Posted May 29, 2014 Report Share Posted May 29, 2014 How is the assy? Can you tighten up the housing like Datsunaholic mentioned? Quote Link to comment
ggzilla Posted May 29, 2014 Report Share Posted May 29, 2014 With the switch unbolted from the lock, the switch is normally very easy to turn with a screwdriver. Quote Link to comment
67_1600 Posted May 30, 2014 Author Report Share Posted May 30, 2014 I'm not really seeing what Datsunaholic was referring to - my switch doesn't look like it should come apart at all. Here are a couple pics of my switch. If I use a screwdriver it's easy enough to turn the switch from lock to start, but I have to push in to get it to actually crank. Showing how I have to push in with the screwdriver to get it to where it will crank: Roy is going to let me try a 620 switch which is likely the same. That will tell me for sure whether it's that or something else. Thanks again for the advice and suggestions. Quote Link to comment
q-tip Posted May 30, 2014 Report Share Posted May 30, 2014 I have one out of my 510 that should still work. 1 Quote Link to comment
dr.feltersnatch Posted May 30, 2014 Report Share Posted May 30, 2014 the one i have is all 1 piece like this. http://www.rockauto.com/getimage/getimage.php?imagekey=940143&imageurl=http%3A//www.rockauto.com/info/Airtex/1S6173.jpg if you can use it your welcome to it. if anyone else needs a new one rockauto sells just the switch for $18 Quote Link to comment
ggzilla Posted May 30, 2014 Report Share Posted May 30, 2014 Having to push it in means it is broken inside. Quote Link to comment
