LZ 22 ( Stock bottom end and / U67 Head)
Doctoraudio
  • Replies 66
As Mike mentioned earlier.
Reverse for larger ports and carbs.  You will 'bog' out in the lower RPMs but get you power up high.
That is why all the race guys have larger ports and carbs, they are mostly staying in the higher RPM range, not so fun for a daily
This would be correct.
Okay, I found a few double set of parts.
One of the things I like to do when I am building stuff.
Is to find the lightest and the strongest parts.
I have a timing chain spocket that weighs 600 grams.
And another that prances in at 510 grams.
That seems to be more than a different batch or lot.
They look a little different!
One the numbers are stamped and easy to see the other is stamped but much small.
you can barely see the numbers on the second one on the right
