well she finally gave up the goat
well guys she finally gave it up
like to thank you folks
for the heads up and tips
here some pics
chained up
one good shake and tug and she popped!
checking making sure nothing is going to hang up
trusty pit crew
here she come's
couple more wiggles something is hanging on
there is the culprit
ahh come to Daddy
had to reset the chain hoist would not go higher
there it is she gave it up nice and easy
getting it on the stand
now to get to the dirty work,she looks all empty in side
once again thx guys for the insight on my first Datsun motor pull
it took me less than 25min no joke! to pull it
would not have been that easy with out your help
one thing i would say if you are pulling a motor is support the tranny as you pull it
that what was causing the hang up, as i was hoisting up the tranny was wanting to sag
but other that that it was pretty easy
thx again guys
farmer
  • Like 6
  • Replies 29
What failed?? Just kinda curious.
I borrowed an awesome electric motor hoist from my buddy, His brother built it as a prototype for a race team in the early 90's. It made quick work of it.
To 'give up the ghost' means to die. Usually after a prolonged and lengthy illness. In the case of an object, to cease working after a prolonged and troublesome failing period where it's almost a relief.
To 'give up the goat' means to give away or sell your Pontiac. Specifically your GTO.
nothing failed!
the engine ran good 150 across the board
but it had a leak somewhere and it coated all the steering linkage and
crossmember and such and the engine bay has lost some paint so
i pulled it to clean up all the grease and road grim and to repaint the engine bay
also to fix the seal's on the motor also change the timing chain and water pump
paint the motor
just freshen it up
the car is to clean to have a junk looking motor and engine bay
and grease
pride!
thx farmer
