Quick release steering wheel hub
Data session
  • Replies 47
A quick release and a hub are two different pieces. You need a hub the specifically matches the vehicle youre installing it in. Then you buy a universal quick release ti match the pattern of the wheel you want to run.
Link to post
  • 1 month later...
NRG 140h hub and quick release will work on 620. And for your safety please don't cheap out on a steering wheel either I know NRG is a bit high but I haven't found a hub and quick release just that's as good
I order a 140h and now it's not fitting on my 79 kc...
Link to post
NRG Short Steering Wheel Hub Adapter 140h is for Datsun510 (All), 610 (All), 810 (All); Nissan 200SX (All), 240SX* 89-97, 260Z/280Z (All), 300ZX* 90+, Altima93+, Maxima 89-98, Pulsar 87-90, Sentra 91-96, Hardbody Pickup (All), Trucks 86+
Link to post
Yes, I've already read that. but another member said it would work so I assumed it would...
He also had a 79 620...
Link to post
In general, hubs for 510s fit the 620. There's probably a reason NRG doesn't list the 620. Maybe it won't fit with the column covers on or something.
Before I return it, I'll try to get this one to fit if there's some way.
I messaged blackbird so hopefully he can explain to me how to work it.
It doesn't seem to get past the threads...
Link to post
I took mine off to check on the reg cab before I headed to work wouldn't clear the threads at all on my 79 wonder if someone swapped out the columns in the Kc with an older one I'll go check on my buddies 72.5 620 this weekend
I'm pretty sure I'll just have to buy a boss hub or something.
Link to post
  • 8 months later...
  • 1 month later...
  • 1 year later...
