SteezySkreez Posted January 23, 2014 Report Share Posted January 23, 2014 So my motor was in fact blown up. And this is the thread to see the progress for the new L20. Let me know what you all think! Also big help to Eagle_Adam... The mastermind behind it all.. mmmmmmmmm Six and a half hours later... 1 Quote Link to comment
wayno Posted January 23, 2014 Report Share Posted January 23, 2014 Was that engine pinging before it started knocking? Quote Link to comment
ggzilla Posted January 23, 2014 Report Share Posted January 23, 2014 Looks like severe pinging caused a broken ring land. So not blown up? Quote Link to comment
Eagle_Adam Posted January 23, 2014 Report Share Posted January 23, 2014 Six and a half hours later... that included dinner and a trip to my storage unit :P Quote Link to comment
Eagle_Adam Posted January 23, 2014 Report Share Posted January 23, 2014 Was that engine pinging before it started knocking? Looks like severe pinging caused a broken ring land. weird thing is i test drove this truck when it was FS on CL and it diddn't ping then, Jessi met him at PCC and it diddn't ping then.......... but when he brought it over it was knocking like a son of a bitch! Quote Link to comment
Eagle_Adam Posted January 23, 2014 Report Share Posted January 23, 2014 So not blown up? if this isnt blown up, im not sure what it..... Quote Link to comment
DanielC Posted January 23, 2014 Report Share Posted January 23, 2014 "if this isnt blown up, im not sure what it....." A broken con rod through the side of the crankcase. 2 Quote Link to comment
wayno Posted January 23, 2014 Report Share Posted January 23, 2014 You cannot drive them when they are pinging(another word for it is knocking), otherwise it will end up with a knock of another type which is terminal. :( Quote Link to comment
ggzilla Posted January 23, 2014 Report Share Posted January 23, 2014 It was sill running so not blown up. 1 Quote Link to comment
Jayden71 Posted January 23, 2014 Report Share Posted January 23, 2014 That'll buff out... Quote Link to comment
Eagle_Adam Posted January 23, 2014 Report Share Posted January 23, 2014 It was sill running so not blown up. ok, im done with this dick measuring contest....... you win 1 Quote Link to comment
Eagle_Adam Posted January 23, 2014 Report Share Posted January 23, 2014 That'll buff out... my first thought was JB weld! 1 Quote Link to comment
datzenmike Posted January 24, 2014 Report Share Posted January 24, 2014 That there is some fine lookin detonation, right thar. 1 Quote Link to comment
tr8er Posted January 24, 2014 Report Share Posted January 24, 2014 Holy crap, any excuse to pull out an L16 these days... And I'd like to be in the dick measuring contest if I can. 1 Quote Link to comment
Eagle_Adam Posted January 24, 2014 Report Share Posted January 24, 2014 That there is some fine lookin detonation, right thar. so what causes this? just pinging? Quote Link to comment
Eagle_Adam Posted January 24, 2014 Report Share Posted January 24, 2014 Holy crap, any excuse to pull out an L16 these days... And I'd like to be in the dick measuring contest if I can. lulz, i dont need an excuse to pull a motor, look at my last L motor i was running tits and i still pulled it for a KA swap....... 1 Quote Link to comment
datzenmike Posted January 25, 2014 Report Share Posted January 25, 2014 so what causes this? just pinging? Detonation is the abnormal burning of the fuel air after the spark plug has fired. The flame should travel across the combustion chamber from the plug to all points at a set rate until it is all burned and the pressure increasing with it. Unfortunately with detonation, as the temp and pressures begin to increase, the remaining gas and air can reach a point where it will combust by itself, producing an intense pressure spike of short duration. Think of someone giving you a very a hard push or shove and then condensing that same energy into a hard hammer blow. Yeah the hammer will kill you. This spike can break spark plug electrodes and ring lands and will pit the piston tops. Passenger car pistons are roughly 12-15% silicon content making them brittle and basically closer to glass. Detonation will chip pieces off them and they will appear to be eroded or sand blasted usually on the side furthest from the spark plug. On an L piston that would be the driver's side. Once chewed away exhaust will begin blowing past the rings and will over heat them, scuffing the piston and cylinder walls. Too much ignition advance at high RPMs and heavy throttle can do this. Poor octane gas for the compression you are running. Overheated motor run at high RPMs and throttle can cause detonation.. 1 Quote Link to comment
ggzilla Posted January 25, 2014 Report Share Posted January 25, 2014 Yes, it is caused by pinging. 2 Quote Link to comment
