Draker Posted May 28, 2014 Report Share Posted May 28, 2014 How's your radiator cap? Does the coolant system hold pressure? Flow test radiator? get laser gun and spot check the radiator to make sure it's not clogged. Back flow.. check again. CLR that bitch.. Quote Link to comment
Draker Posted May 28, 2014 Report Share Posted May 28, 2014 Scratch that... I see you've already installed a new radiator. Quote Link to comment
Janksun Posted May 28, 2014 Author Report Share Posted May 28, 2014 Radiator cap came with radiator. Which was a brand new champion all aluminum radiator that I bought from Busta Nut. It holds pressure too. Im starting to think it's the temp sensor because it doesn't actually boil over when it gets hot. I'll take pics of the new stuff later when I'm not pissed off and want to work on it again. Quote Link to comment
jvb5577 Posted May 28, 2014 Report Share Posted May 28, 2014 Wait are you selling your wagon? I saw it on CL Quote Link to comment
Janksun Posted May 28, 2014 Author Report Share Posted May 28, 2014 Wait are you selling your wagon? I saw it on CL It's "for sale" don't want to sell it, but if someone's gives me my outrageous asking price, I would sell it. Quote Link to comment
jvb5577 Posted May 28, 2014 Report Share Posted May 28, 2014 It's "for sale" don't want to sell it, but if someone's gives me my outrageous asking price, I would sell it. I see what you did there... Quote Link to comment
Busta Nut Posted May 28, 2014 Report Share Posted May 28, 2014 Try a pyrometer if you have access to one....maybe a cheapy one from Harbor Freight..... It's gotta be the sensor or the gauge........it's too intermittent to be mechanical....... Hope you don't sell it........but your financial situation gets better........ Quote Link to comment
izzo Posted May 28, 2014 Report Share Posted May 28, 2014 Do a compression test, but before that... start the car cold, and pull the radiator cap.. does it push water out of the radiator? Quote Link to comment
Janksun Posted May 29, 2014 Author Report Share Posted May 29, 2014 On cold start, with cap on. Remove cap after start. Slowly pushes water out. Will do a compression test in a little bit. My friend said he would bring a pyrometer by later. Quote Link to comment
Janksun Posted May 29, 2014 Author Report Share Posted May 29, 2014 Video uploading of the what the temp gauge does. Quote Link to comment
Janksun Posted May 29, 2014 Author Report Share Posted May 29, 2014 Damn such shitty quality... http://youtu.be/ELV-OM7FZdE Quote Link to comment
Janksun Posted May 29, 2014 Author Report Share Posted May 29, 2014 So basically it idles at the end of the t on the gauge, and when I drive it, it runs at the end of the m. Quote Link to comment
TENDRIL Posted May 29, 2014 Report Share Posted May 29, 2014 video says privet 1 Quote Link to comment
AtomChurch Posted May 29, 2014 Report Share Posted May 29, 2014 End of the M is okay. After P, start thinking about why its running that way. But between M and P you are okay. Try a colder thermostat maybe to ease your nerves.. Quote Link to comment
AtomChurch Posted May 29, 2014 Report Share Posted May 29, 2014 Have you tried removing the thermostat and seeing if it just stays cold all the time? What temp is your thermostat? Do you even know? Quote Link to comment
Janksun Posted May 29, 2014 Author Report Share Posted May 29, 2014 The thermostat is a 180 degree one. I ran it without the thermostat and still did the same thing. Quote Link to comment
Janksun Posted June 9, 2014 Author Report Share Posted June 9, 2014 Sooooo finally got an aftermarket temp sensor installed, and guess what, I've been freaking out over nothing. The motor runs right around 190. The stock temp gauge is way off. Here's what it reads on the freeway The needle is past the p which I've been told is not good. Here's what the aftermarket gauge reads on the freeway. Right around 190 or so. Perfect. So I wrapped up a bunch of little things today and I feel alot more confident on this car making if to canby. Just a few more things and I'll be good to go! New valve seals Valve adjust Make new gauge bezel Make shift hole cover Lower another inch or 2 in the rear And I think that's about it... Random gas station shot The last couple days have been hectic. Ive been working on my dads 2008 dodge ram 2500. His throwout bearing went by by. So we did a clutch job. Hardest time ever getting the transmission back in place. Glad I'm not a mechanic for a living. Shitty cell pics And what's left of the throwout bearing And nice butt on the left there..... 2 Quote Link to comment
MicroMachinery Posted June 9, 2014 Report Share Posted June 9, 2014 Here's what it reads on the freeway You only go 28mph on the freeway? :poke: I keed, I keed. Glad you got this figured out :) Quote Link to comment
Janksun Posted June 9, 2014 Author Report Share Posted June 9, 2014 You only go 28mph on the freeway? :poke: I keed, I keed. Glad you got this figured out :) Haha ok so I was getting off the freeway.. but still ran that temp when at 70mph Quote Link to comment
Busta Nut Posted June 9, 2014 Report Share Posted June 9, 2014 :thumbup: See ya @ CanBy!! Quote Link to comment
Janksun Posted June 10, 2014 Author Report Share Posted June 10, 2014 :thumbup: See ya @ CanBy!! Hell yeah!! Made a block off plate for the radio hole out of some plexi glass I had laying around. Sticker slapped it. Looks kinda cool. 4 Quote Link to comment
the510keeper Posted June 10, 2014 Report Share Posted June 10, 2014 good you will room for the Big Johnson Quote Link to comment
Janksun Posted June 11, 2014 Author Report Share Posted June 11, 2014 Adjusted the valves today and holy shit it made a huge distance. Runs Sooo much better 1 Quote Link to comment
Busta Nut Posted June 11, 2014 Report Share Posted June 11, 2014 good you will room for the Big Johnson James....you ok man?? You're posts lack content........your fingers can't keep up with your brain....... ............too much paint fumes :rofl: Quote Link to comment
