Another 510 KA24DE-T
  • Replies 352
So while I was under the car I figured, fuk it, I'll just smash the inner step up inside the rear fender. The one that LOWWWW people dislike. If you do it CAREFULLY, it will not damage the outer fender. Looks rough on the inside but that's mostly from the sander. Smashed, sanded, carb cleaner'd and spray painted. I will post pics if how low we can get it without rubbing tomorrow :)
Before where I was rubbing
85CC329E-C79F-4C55-AE1B-7619B44E4EDB_zps
After hulksmashthorhammer and a little sanding it was nice and flattened out.
197662D7-E639-4A04-949C-6D13BCBBCCAF_zps
PERFECTLY fine on the outside
3929038E-5564-426E-8BC6-AE2F65D13E9D_zps
D5DE4361-4835-4A96-8E1E-4C1302829975_zps
  • 1 month later...
Just threw on the weathered 1980's Nardi and Boss hub adapter. Theres a little bit of a gap between the plastic 'shroud' and the adapter but aside from that, everything fit nicely.
47AFCB87-876B-4E95-B4E5-A275186D2EDB_zps
6E344DF6-9914-4DB3-8306-98206BEB1518_zps
Cut a slice of black ABS pipe from hardware store. Bet it would clean that gap up well.
