HeatBloom: Junkyard Dog S130
My first car was a 280zx, so I have had a soft spot for them since then.
I have wanted another one for years and years, so when I saw this in the junkyard I had to rescue it.
969588_10152832938470467_1637597068_n.jp
970259_10152832938610467_2130884292_n.jp
The car only has 110,000 original kms!!
So when I brought it home I noticed the brake lines were all cut.  :crying:
They are cut at every corner of the car, multiple times within the same line.
946486_10152837521935467_1873519380_n.jp
Pulled the cut lines out of the engine bay.
970385_10152837522595467_1695385241_n.jp
Picked up some parts I needed, luckily I got another set of good brake hard lines.
600583_10152837521660467_1304718065_n.jp
Ran the new hardlines through the engine bay and hooked them up to my new (to me) soft lines. Waiting for calipers now.
Pulled the factory knuckle, strut combo
992820_10152832938665467_1335640704_n.jp
1001309_10152847958590467_1913801291_n.j
Picked up some more goodies, s13 knuckles, brakes and suspension
922716_10152847958350467_1905005157_n.jp
The top spring perch is too big to fit in the 280zx strut tower so I cut the perch and spring out.
181272_10152847958115467_1829624218_n.jp
s13 stuff bolted in
946656_10152847957460467_1197554681_n.jp
  • Replies 28
1st post with tons of picks and progress to boot
I love it
welcome to Ratsun
how did you attach the s13 struts to the control arms ?
is there a conversion kit ?
Thanks guys, looks like a nice forum you have here!
I put s13 knuckles on the front lca, it bolts right on to the stock 280 lca, and so now I can use s13 coilovers and brakes.
let me know how that sweet ball joint angle and awesome positive camber works out for you
hmmmmm if s13 stuff bolts into a 280zx it should bolt into anything that zx struts are swapped into hmmmmmm
Yeah it will bolt in, but your LCA and ball joint angles will be all super fucked. They arent close to the same as any of the Datsun pieces.
that was the factor that i was wondering about lol if i can get my hands on some cheap s13 stuff i might play around with it and see if its a viable alternative to tracking down 280zx stuff plus all the brake upgrades and such
Yeah angle is horrible and the hub depth is something like .5in wider than 510 if I remember correctly. So while everyone goes to 280zx for .75 deeper dish wheels, youd have to run .5in less dish than stock 510 wheels.
  • 3 weeks later...
Decided against the rb20, going to put the L28 back in cuz I want to drive it this summer
1012419_10152946534445467_1424927090_n.j
1014020_10152946534765467_1781038834_n.j
1045255_10152947931435467_1379728427_n.j
louvers not fitted yet, just sitting on window to see how it looks
1016151_10152957449950467_184061646_n.jp
1010072_10152957449600467_1669479742_n.j
1017558_10152959296495467_1050753333_n.j
1010691_10152959296290467_1637166062_n.j
992807_10152959296115467_2021304879_n.jp
I will lower the car more when the motor is back in the car and the good wheels are on
