tubbedbaggedstockfloored65 Posted October 29, 2014 Author Report Share Posted October 29, 2014 I changed no wiring except regulator plug jumpers, my trucks always been wired like this since I got it Quote Link to comment
tubbedbaggedstockfloored65 Posted October 29, 2014 Author Report Share Posted October 29, 2014 Im moving ground s and replacing red wire with black wire like you guys say so no more confusion Quote Link to comment
tubbedbaggedstockfloored65 Posted October 30, 2014 Author Report Share Posted October 30, 2014 I'm askin for your guys advice and oppinion so I can make it eight, as of today I made the red wire into black wire and put it in the threaded pole on alternator and moved negative cable end ground to bolt spot right behind fuel pumo on passenger side adter I cleanedthe rusty end real well and cleaned the ground wire that's on the passenger side radiator bolt on top, does anyone have this bolt or ground here to ? Is that normal Quote Link to comment
banzai510(hainz) Posted October 30, 2014 Report Share Posted October 30, 2014 What I see attached from the - batt cable is a ground wire. ,why use it if the big batt cable is already to ground, unless it goes to a specific powered unit. (Lights, electri motor ect...) Hainz the battery cable to ground on the block is good but for things grounded to the body sheet metal how does it get to the battery ground??? engine/trans/differentia, exhaust, shocks... are all rubber isolated from the body making it difficult. A seperate ground strap from battery to the body is a good idea. Quote Link to comment
Scgreen620 Posted October 31, 2014 Report Share Posted October 31, 2014 Took apart and cleaned winshield wiper switch How did you take the knob off ? I want to take mine off but I don't wanna break anything Quote Link to comment
tubbedbaggedstockfloored65 Posted October 31, 2014 Author Report Share Posted October 31, 2014 Pull knob out use pliers on metal part and just push in and twist knob and it will pop out 1 Quote Link to comment
Scgreen620 Posted October 31, 2014 Report Share Posted October 31, 2014 Pull knob out use pliers on metal part and just push in and twist knob and it will pop out Thanks 1 Quote Link to comment
tubbedbaggedstockfloored65 Posted November 17, 2014 Author Report Share Posted November 17, 2014 Well I only had 1 of 2 bolts holding trans to cross member and it was stripped so had to take bolts of trans itself and drop crossmember and mounts n all and took me some doin to get it out, so I rethreaded holes added 2 bolts snugged em down put crossmember back ip bolted mount to tranny and connected driveline bolted carrier bearing which is brand new down and hooked speedo cable back up and 2 reverse wires I had to steal back up neutral safety switch from other tranny I had, took off shifter plater on transmission tunnel filled trans with gear ol put plug back in and put interior back together, tightened front center link added cotter pin 1 Quote Link to comment
tubbedbaggedstockfloored65 Posted November 17, 2014 Author Report Share Posted November 17, 2014 I did move negative cable to ground hole right behind fuel pump where you guys designated and I made it a new big gauge black wire so no ones confused , and moved it to top of alternator bolt like you guys mentioned as well, hooked up my battery lights seem to work, Got bored when it got dark so made a datsun 620 hot wheels shift knob for shits n giggles Made new ground for lights made it was a good one and have yet to put another fuse in link under glovebox evey time I did last time it popped as soon as it touches, so tomorrow got to figure that out worked great 3 months ago I still only have high heater fan and no low fan Quote Link to comment
tubbedbaggedstockfloored65 Posted November 17, 2014 Author Report Share Posted November 17, 2014 Ordered full rebuold kit for one of my l20s so that will be my winter project tinkering and gf ordered me a set of h4 halo lights , anyone know if I should put them in brights or low beams ? It says has both high and low beam dual fillament bulbs so not sure what that means, any clue? Quote Link to comment
tubbedbaggedstockfloored65 Posted November 17, 2014 Author Report Share Posted November 17, 2014 Needed a battery scored free one from buddy for my b day so I had to get side post adapter plugs and cut out battery tray ever so slightly for my huge battery I put in with bungees so it don't slide around Quote Link to comment
datzenmike Posted November 17, 2014 Report Share Posted November 17, 2014 Now you're getting somewhere. High beams are two prongs on the back of the bulbs. Low beams have three. Quote Link to comment
]2eDeYe Posted November 17, 2014 Report Share Posted November 17, 2014 I still only have high heater fan and no low fan There is a resistor in the fan housing that is probably burnt. There is a thread on how to repair it in the how-to section. 1 Quote Link to comment
banzai510(hainz) Posted November 17, 2014 Report Share Posted November 17, 2014 gf ordered me a set of h4 halo lights??? sounds like Chinese junk http://www.deltalights.com/?q=store#!/LED-5-3-4-HIGH-BEAM-HEADLIGHT-SYSTEM-(Pair)/p/29120228/category=2078037 1 Quote Link to comment
tubbedbaggedstockfloored65 Posted November 17, 2014 Author Report Share Posted November 17, 2014 Banzai maybe, but my old ladynordered em so ill use em, free is free and gifts are gifts, n Heater k they have 3 prongs datzen mike , so low beams ? And I am not lookin forward to takin heater shit apart Quote Link to comment
tubbedbaggedstockfloored65 Posted November 17, 2014 Author Report Share Posted November 17, 2014 Thanks datzen mike and redeye, and thanks fo downgrading banzai :) GLAD TO SEE I HAVE HATERS Quote Link to comment
banzai510(hainz) Posted November 17, 2014 Report Share Posted November 17, 2014 when you run H4s you need a H4 harness.H4 bulbs are 55/60watts. stock is 35watts on both elements 3 pronge is High and Low no matter if H4 or stock lamp. If no H4 harness you run the risk if buring wires up. So then youll down grade your vehicle instead thinking of me How I was downgraded . Quote Link to comment
tubbedbaggedstockfloored65 Posted November 17, 2014 Author Report Share Posted November 17, 2014 :) Quote Link to comment
tubbedbaggedstockfloored65 Posted November 19, 2014 Author Report Share Posted November 19, 2014 I wasn't sure how the heater spring came out so I just pryed on it and hoped for best glad Its just plastic clips and it popped off and , yep like datsun mike and redeye said the thing wasn't touching other side so I bent it around it and made it secure, turned the key and heatd the fan turn on on the first click , yeehaw now I have low and hot and the bottom cable that closes the bottom valve is not attached and I see where it needs to be attached it justs to loose and it doesn't pull in our out on valve, cable is not brokennbut I don't no where it clips or hooks to to keep it tight Quote Link to comment
tubbedbaggedstockfloored65 Posted November 19, 2014 Author Report Share Posted November 19, 2014 Yea banzai I have a harness I'm just not sure I won't fuck itnup,, my luck Quote Link to comment
tubbedbaggedstockfloored65 Posted November 19, 2014 Author Report Share Posted November 19, 2014 Cable to bottom valve has been off ever sinceI've owned it, and its always blown out super super hot air 1 Quote Link to comment
tubbedbaggedstockfloored65 Posted November 19, 2014 Author Report Share Posted November 19, 2014 Does anyone hve a picture routin gnome it and where middle of cable clips to to hold it secure so cable inside can pull valve open and closed or hot and cold or whatever it does Quote Link to comment
tubbedbaggedstockfloored65 Posted September 24, 2015 Author Report Share Posted September 24, 2015 It's been quite some time since I've posted on here and been struggling with few things in my life.but I have done a few things to it since then,granted my truck hasn't ran in about a year and half Quote Link to comment
sebpv Posted September 24, 2015 Report Share Posted September 24, 2015 I feel you man. Im in the same boat. The truck hasnt moved in two years. Now that I have parts, laziness is my problem... Quote Link to comment
tubbedbaggedstockfloored65 Posted September 25, 2015 Author Report Share Posted September 25, 2015 Yea ,since my trucks been down and out for so long the motivation and lack of drive and enthusiasm is insane.i still look at it and day dream and remember cold lonely nights with just me and my datsun,and between the spiders green algae and pine needles it's depressing,I don't even have the parts like you, Quote Link to comment
