Fuelrags Posted July 31, 2008 Report Share Posted July 31, 2008 Hey Guy's, I just noticed today that My Head Gasket is seeping oil after driving from the Drivers Side front corner(behind the T-Stat housing). My Cylinder Head was just Rebuilt,did they screw something up?! HELP! Quote Link to comment
banzai510(hainz) Posted July 31, 2008 Report Share Posted July 31, 2008 maybe they should have put some sealant in the corners of the front cover meets the head. This is common I wouoldnt worry about it just looks like shit Quote Link to comment
banzai510(hainz) Posted July 31, 2008 Report Share Posted July 31, 2008 http://www.guba.com/general/search?query=datsun&set=5 I explain how to do the front cover Quote Link to comment
Fuelrags Posted July 31, 2008 Author Report Share Posted July 31, 2008 maybe they should have put some sealant in the corners of the front cover meets the head. This is common I wouoldnt worry about it just looks like shit Cool,thanks Bro!...It freaked me out when I saw that!:eek: Quote Link to comment
]2eDeYe Posted July 31, 2008 Report Share Posted July 31, 2008 Make sure you retorque that head 500-1000 miles after the rebuild. Quote Link to comment
Fuelrags Posted August 1, 2008 Author Report Share Posted August 1, 2008 Cool,thanks Bro!...It freaked me out when I saw that!:eek: Well problem #2 Guys, I also noticed that I'm loosing Anti-freeze from the same area as my Oil Leak! Is this thing 'Toast'????!!!:blink: Quote Link to comment
banzai510(hainz) Posted August 1, 2008 Report Share Posted August 1, 2008 if you tried to remove the temp sender from the housing the housing could crack.Did you do this previosly? I assume there is a new gasket to the head and housing and on top of the Thermostat. dont over tighten aluminum. its not much. The old V8 guys would overtorq the bolts and strip them out or crack stuff. or is the radiator hose slight loose and water is running backwards to the motor making it look like the state housing is leaky? Quote Link to comment
Fuelrags Posted August 1, 2008 Author Report Share Posted August 1, 2008 if you tried to remove the temp sender from the housing the housing could crack.Did you do this previosly? I assume there is a new gasket to the head and housing and on top of the Thermostat. dont over tighten aluminum. its not much. The old V8 guys would overtorq the bolts and strip them out or crack stuff. or is the radiator hose slight loose and water is running backwards to the motor making it look like the state housing is leaky? Naaa....it's coming from underneath the front portion of the manifold:mad: Quote Link to comment
banzai510(hainz) Posted August 1, 2008 Report Share Posted August 1, 2008 If you have a water heated intake.(a water line going to the intake) your intake is not tight enough. Tighten the intake upper and esp the lower bolts. Maybe tighten up the exhaust ones also. Make sure the thick washers are there so they apply pressure to bothe the intake and exhaust manifold. YOull see it .like to halves and th washer is in the middle holding both together. I assume there is a NEW intake/exhaust gasket. If tighten dont work I would replace the intake/Ex gasket with another. Quote Link to comment
hang_510 Posted August 1, 2008 Report Share Posted August 1, 2008 maybe they should have put some sealant in the corners of the front cover meets the head. This is common I wouoldnt worry about it just looks like shit ive had the 2 bolts that attach to the timing cover strip out before. fixed that and the seeping went away. Quote Link to comment
Fuelrags Posted August 3, 2008 Author Report Share Posted August 3, 2008 ive had the 2 bolts that attach to the timing cover strip out before. fixed that and the seeping went away. Well I found the problem causing the leak! while I was torquing the Cylinder Head Bolts,I found the last bolt in the sequence of the 10 stripped,which happens to be from the area of the coolant leak I found. Is there any way I can fix this without removing the Head to fix the threads in the block? HELP! Quote Link to comment
datzenmike Posted August 3, 2008 Report Share Posted August 3, 2008 Would a new bolt with good threads work? Use loc-tight and prey. Quote Link to comment
Fuelrags Posted August 3, 2008 Author Report Share Posted August 3, 2008 Would a new bolt with good threads work? Use loc-tight and prey. Yeah.....Does anybody have one to spare???? Thanks,Martin Quote Link to comment
Pacific coast Datsun Posted August 3, 2008 Report Share Posted August 3, 2008 Martin try a few yards. Im sure youll find it & it'll fit in your pocket :cool: Quote Link to comment
Fuelrags Posted August 3, 2008 Author Report Share Posted August 3, 2008 Martin try a few yards. Im sure youll find it & it'll fit in your pocket :cool: Your too funny,.....wouldn't one of our trucks be like trying to find a "needle in a haystack" at a local yard????? Quote Link to comment
Bugeye Posted August 4, 2008 Report Share Posted August 4, 2008 not at mine here in nor cal, im just not allowed in there for another month or so Quote Link to comment
datsun dreamer Posted August 4, 2008 Report Share Posted August 4, 2008 not at mine here in nor cal, im just not allowed in there for another month or so Thats not good:eek:! Quote Link to comment
Bugeye Posted August 4, 2008 Report Share Posted August 4, 2008 Thats not good:eek:! they tried to charge me 40 for a set of tail light lenses, I let them know how I felt about their price, they kindly had a security guard escort me out:lol: Quote Link to comment
motavated Posted August 4, 2008 Report Share Posted August 4, 2008 Some guy had some chrome 720 side mirrors and I was seriously jealous... I went too pay for some stuff and they were left there on the counter. I asked the cashier how much and she said 30 bucks!!!!! I wanted to give her a piece of my mind, but I too left them there with out saying a word.... They laughed at me, but I did not wanted to get kicked out for saying something stupid... BUGEYE!!!! You got balls my friend!!!! 1 Quote Link to comment
banzai510(hainz) Posted August 4, 2008 Report Share Posted August 4, 2008 I cant figure how those bolts strip out????????maybe break!!!!!!!!! IF you lived closer I would give you some extra head bolts I have to admit those bolts are pretty strong& coarse thread. I cant figure how they strip out. Rusty Block? Quote Link to comment
