erichwaslike Posted May 24, 2013 Report Share Posted May 24, 2013 Choke only richens the mixture, you have to have lots of air getting in for it to rev up. Does the 32/36 have mechanical secondary? How is the secondary closed when letting off the gas? im gonna have to disagree on this to some extent. i had a manual choke on mine and the lil clip holding the linkage popped off, it sent my motor to 5600 and bounced off my rev limiter... i removed my choke butterflys and shaft and i havent had the issue since. it was definitly the choke causeing my hig rpm and it did have power casue it sent me accelerating towards a red light and alot of traffic. Quote Link to comment
H5WAGON Posted May 25, 2013 Report Share Posted May 25, 2013 Advance weights in Dist, stuck advanced? Quote Link to comment
Farmer Joe Posted May 25, 2013 Report Share Posted May 25, 2013 and heres how it looks when connected/normal not sure if you got this licked or not... make sure that the lever from the primary shaft (the one that accuatates the secondary) has the vertial spring, like the picture shows. also, the little stopper that the secondary lever bottoms out on is adjustable. take the carb off, and make sure that the secondary closes all the way at idle. should fix it.. Quote Link to comment
Eagle_Adam Posted May 25, 2013 Author Report Share Posted May 25, 2013 Decided I'm done with the the weber, Im having a custom air box made to fit the 78 booster and 38 mm SU's Quote Link to comment
wayno Posted May 25, 2013 Report Share Posted May 25, 2013 Maybe when you floored it you bent something, as you did not mention of it happening before, personally I don't like downdrafts myself, but I would figure it out before changing over to the SUs myself, I just can't let something like that get the best of me. One time when I hit the gas really hard, I flipped a linkage arm past where it was supposed to travel, when it did that, it held the throttle 3/4ers open full time, and it was pinned, I had to physically force the arm backwards after I turned off the engine and reset the cable back on its pulley, the whole thing just failed. It did not fall apart, as I was able to just put everything back where it was supposed to be, and it has worked fine since, I just don't slap the throttle like that anymore. BTW, the failure above was on a set of dual SUs, the issue might be that I made half the linkage myself, as it was incomplete when I bought it. Quote Link to comment
Eagle_Adam Posted May 25, 2013 Author Report Share Posted May 25, 2013 Ill get it sorted, but not before canby... Quote Link to comment
datzenmike Posted May 26, 2013 Report Share Posted May 26, 2013 im gonna have to disagree on this to some extent. i had a manual choke on mine and the lil clip holding the linkage popped off, it sent my motor to 5600 and bounced off my rev limiter... i removed my choke butterflys and shaft and i havent had the issue since. it was definitly the choke causeing my hig rpm and it did have power casue it sent me accelerating towards a red light and alot of traffic. . Just saying that choke alone won't rev it up. It cuts the air and forces an over rich condition. Advance weights in Dist, stuck advanced? Again advance alone won't rev it up you need gas and air for that. Quote Link to comment
Stoffregen Motorsports Posted May 26, 2013 Report Share Posted May 26, 2013 This would be a lot easier to help if you posted up detailed pics. There's obviously something you're missing. Quote Link to comment
Eagle_Adam Posted May 27, 2013 Author Report Share Posted May 27, 2013 I've posted a. Idea and responded to everything that's been asked this far...... So, what would you like detailed pics of? Cus I'm all for fixing the issue Quote Link to comment
Stoffregen Motorsports Posted May 27, 2013 Report Share Posted May 27, 2013 I don't know, A lot of pics of the carb, linkage, pedal, etc. I'm a touchy, feely guy. If I can see a pic I might be able to pinpoint something. As far as verbal communication goes, there are a lot of things I find myself assuming, because if I didn't I'd have to ask silly questions like: does the throttle return all the way closed? Does the pedal return all the way? Is there slack in the cable at idle? Did this happen all of a sudden? Was there something that happened right before hand? See where I'm going? This is like an automotive crime scene and forensics is the only way to catch the killer. Assume nothing. Quote Link to comment
Eagle_Adam Posted May 27, 2013 Author Report Share Posted May 27, 2013 Fair nuff, I just got it Home so ill get pics when I dig into it tomorrow Quote Link to comment
