Gold valve cover at Ratsun price?
  • Replies 76
after i saw how pretty our radiators are in their bare (brass) finish,
i wondered if i could get my valve cover the same color.
and you can, you can get it plated brass. which is very close to gold in color.
any place that does chrome plating does brass plating.
the shops i called actually said that before things are chrome plated, they are first brass plated
because it acts as a sacrificial anode.
quote i got was $120
^ that is def not spraypaint though, indy510.
i used rustoleums "chrome" color spray on my grill and it looked pretty good, but it does fade.
okay, well then why did you suggest it? lol.  I do appreciate the help, it's just I assumed maybe this dude had some kind of tricks or could do something else to make it shiny.
because i figured id give you a hand, then i sent jrock a txt and found out it wont work so i spoke up. ;)
more like rattle can yellow,ha.. most gold spray look's the same. and why would this thread get locked exactly? it's legit,done nothing wrong here.
It's probably due to the fact that half your threads get closed for stupidity.
Well it looks like you have plenty of options... Now just follow through.
dude im tellin you i already looked into this. like you said, yellow paint looks hideous.
"Gold" anodizing is also ugly (seen that too.)
brass plating is the way to go.
or dont do it so i can be the only ratsun'er that i know of thats doin it :)
This topic is now closed to further replies.
