jrock4224 Posted July 30, 2013 Report Share Posted July 30, 2013 boosters usually bleed off pressure while your sitting with brakes on .....squishy is usually master related...my wifes blazer took three m/c to find one that I didn't think was malfunctioning..it ended up being a used one off a truck I knew worked the parts store ones kept going back ... Quote Link to comment
Guest Jamee Posted July 30, 2013 Report Share Posted July 30, 2013 fluid level looks to be the same( not low and not high) dont think the master failed cus i can still stop the booster...... well i hope not :P When my master went out I could still stop but there would be times it felt like i had no brakes. my man didnt believe me when i said there was something wrong with my brakes because everytime he drove it they were fine, I refused to drive my car and so we finally got a new master and we looked in the old one and it was toast. Quote Link to comment
Eagle_Adam Posted July 30, 2013 Author Report Share Posted July 30, 2013 hmmmmmmm Quote Link to comment
Eagle_Adam Posted July 30, 2013 Author Report Share Posted July 30, 2013 i fucking loath changing MC's....... Quote Link to comment
wayno Posted July 30, 2013 Report Share Posted July 30, 2013 Do the brakes get squishy while you drive it, or after it sits overnight? Quote Link to comment
Draker Posted July 31, 2013 Report Share Posted July 31, 2013 You can check the booster by turning off the engine.. you should have one solid assisted brake with engine off. Second should feel like you are trying to stop a boat. It won't test efficiency of the booster though. soft brakes are either a bad MC or you still have some stubborn air in there.... Quote Link to comment
Eagle_Adam Posted July 31, 2013 Author Report Share Posted July 31, 2013 The break were just squishy at one point and haven't returned yet Wayno. It's like the 1st half of the pedal distance is useless. The last half does all the braking Quote Link to comment
Eagle_Adam Posted July 31, 2013 Author Report Share Posted July 31, 2013 I don't think it's air In the system, but I've been wrong before Quote Link to comment
converted_to_datsun Posted July 31, 2013 Report Share Posted July 31, 2013 It's air... I've had that same problem before Quote Link to comment
flatcat19 Posted July 31, 2013 Report Share Posted July 31, 2013 Sounds like air. Quote Link to comment
Eagle_Adam Posted July 31, 2013 Author Report Share Posted July 31, 2013 I know it sounds like it, but it's not IMO. The brakes were fine for a week or so then all of a sudden bam. How would air get into a sealed system when it wasn't tampered with? Quote Link to comment
Eagle_Adam Posted July 31, 2013 Author Report Share Posted July 31, 2013 Been talkn to Bonvo and his idea of the piston in the MC getting stuck or not returning all the way matches up with what I'm experiencing. Off to go test the theory Quote Link to comment
flatcat19 Posted July 31, 2013 Report Share Posted July 31, 2013 Masters are cheap enough. You have the load sensing valve in there too, right? Tits or tires. Nothing but problems. Quote Link to comment
wayno Posted July 31, 2013 Report Share Posted July 31, 2013 I know it sounds like it, but it's not IMO. The brakes were fine for a week or so then all of a sudden bam. How would air get into a sealed system when it wasn't tampered with? If you pump the brakes while the engine is not running, and the issue returns, it's likely the master. Quote Link to comment
Siqx20 Posted July 31, 2013 Report Share Posted July 31, 2013 mine has been acting sinilar. i think i have a rear slave leaking Quote Link to comment
Eagle_Adam Posted July 31, 2013 Author Report Share Posted July 31, 2013 So I tapped on the MC in an attempt to see if I can free up the piston but no dice yet But I took the cap off and had my dad pump the brakes. With the pedal down the fluid still rises in the reservoir which seems odd to me.... Probably going to put in a new MC, but now I have to look into what MC will be best for the rear disc brake upgrade Quote Link to comment
flatcat19 Posted July 31, 2013 Report Share Posted July 31, 2013 15/16" or 7/8" You have a booster? If so, the easier to find 7/8" will be fine. 15/16" would be best. 79-80 Z is the 15/16". Earlier are the 7/8". Quote Link to comment
jrock4224 Posted July 31, 2013 Report Share Posted July 31, 2013 Like I said I got a set up master and booster if u need Quote Link to comment
Eagle_Adam Posted July 31, 2013 Author Report Share Posted July 31, 2013 what size is the master Jrock? Quote Link to comment
Eagle_Adam Posted August 1, 2013 Author Report Share Posted August 1, 2013 Muahahhahah....... Who has two thumbs and just dropped their truck off for new exhaust? This guy :) Quote Link to comment
Eagle_Adam Posted August 1, 2013 Author Report Share Posted August 1, 2013 If you pump the brakes while the engine is not running, and the issue returns, it's likely the master. yup, ill be replacing the MC during the rear disc brake upgrade Quote Link to comment
Eagle_Adam Posted August 2, 2013 Author Report Share Posted August 2, 2013 well, after a night of drinking at a company party im at work early to prove a point to the CEO (who called me out on my drunkenness and said i wouldn't even make it to work) Which means i can get off work early to go pick up my truck from the exhaust shop!! Woot woot! cant wait to hear what she sounds like now :D thanx to Jrock for the flowmaster!! 2 Quote Link to comment
Farmer Joe Posted August 2, 2013 Report Share Posted August 2, 2013 ha! silly CEOs... you put a flowmaster on it now? what series? Quote Link to comment
Eagle_Adam Posted August 2, 2013 Author Report Share Posted August 2, 2013 ya silly CEO indeed..... and just for the record he moved our call at 8am to noon..... So now whos hungover huh? well i am but im at work! as for the flowmaster im not sure, it was used and free Quote Link to comment
Eagle_Adam Posted August 2, 2013 Author Report Share Posted August 2, 2013 spending $$ like its going out of style!!! just bought everything for the rear disc swap, just need a MC and PnP should have one for me tomorrow!!! Quote Link to comment
