Picked up a Pathy
That thing is bad ass Skib you gonna change the wheels or keep em? Oh and how much did you get it for?
Ill eventually change the wheels, but its nowhere near a priority atm.
Ill prob pick up some Rota Grid X's or something
I only picked it up for $1700 lol
  • Replies 66
Just shoot the current wheels a satin black and call them done.
Bet it has a nice heater and defrost that work.
Ill get new wheels when I have to get new tires.
the ones in it now are like 80% still
lol Im not used to having that stuff, heat, defrost, A/C, cruise control,
auto adjustable suspension, 4x4, .... and other random electric things I still dont use lol
picked up a vac gauge to help monitor fuel consumption ect.
mounting it to the lower dash plastic
hit the hardware store and found a piece of PVC pipe with the correct ID and cut a spacer to angle it up more.
nice and functional without looking messy or out of place.
22Hg, you baller. Looks like the perfect location.
I was glad to see confirmation the motors in good shape.
did a few tests using vac gauge readings and all checks out.
Have you checked the knock sensor harness? It's probably just cracked.. Hope it's in a good location. If not, I'd get a knock sensor relocation kit cause you're not going to like where that is located.
literally posted from inside the car :rofl:
there not to terribly high on my prioritys list.
Ya its its in the valley. Its common to be bad or corroded, just relocate it is my advice. Dont really need a kit your more then capable to solder 2 plugs together. You can also just eliminate it with a resistor.  On my X its funny, I can reach it because of the 3" bod lift. So if you plan to lift in the future maybe worth a try...
I say kit because on the Z's there is a harness, sensor, and long bolt to relocate.
http://www.yugobernie.com/det_sensor.html
Elimination is always an option, but I personally wouldn't go that route.  Lets just hope for corrosion, lol.
  • 4 weeks later...
I love the old 2 doors but they came with the vg30i which blows. The vge in the 4 doors is much better.
2 doors were 86-89 then its was all 4 doors.
Just had to mention. There was a 1990 two door. With the vg30e. Its a rarer find. And really cool. :-)
There's one on portland or Seattle Craigslist right now.
Nice pathy skib. I has jelly. :-(
http://portland.craigslist.org/clc/cto/3577568149.html
