72240z Posted January 22, 2013 Report Share Posted January 22, 2013 I wouldnt call that a zero scheme/theme it just has the meatball. It also has bre stripes lol, not a bre theme either though. Yuta seemed to be going with a zero theme but who the hell knows. Looks lazy like everything else he does to that poor z... Quote Link to comment
datsunfreak Posted January 23, 2013 Report Share Posted January 23, 2013 Yuta seemed to be going with a zero theme but who the hell knows. His would be the closest I've ever seen. And with the stencil lettering it's certainly military in theme, if not actual Japanese military. Quote Link to comment
spitznoz Posted January 23, 2013 Report Share Posted January 23, 2013 My photo shop hehe i think the bigger the shark teeth the better Quote Link to comment
datsunfreak Posted January 23, 2013 Report Share Posted January 23, 2013 Wouldn't the exhaust pipes have trouble clearing the brake/clutch master cylinders/ strut towers, etc? Yes. Not to mention cutting a hole through the upper frame rails... :blush: Quote Link to comment
bonvo Posted January 26, 2013 Report Share Posted January 26, 2013 Yes. Not to mention cutting a hole through the upper frame rails... :blush: only if you went straight out the side you could get creative with a custom dragster style header use flat pipe and curve it under the car then up and out the fender a little over kill for a look but it can be done without going threw the structure of the car Quote Link to comment
Laecaon Posted January 26, 2013 Report Share Posted January 26, 2013 only if you went straight out the side you could get creative with a custom dragster style header use flat pipe and curve it under the car then up and out the fender a little over kill for a look but it can be done without going threw the structure of the car Not in the same position as the drawing. That high on the fender is the frame rail, and it is really close the skin of the fender. Quote Link to comment
elmerfudpucker Posted January 26, 2013 Report Share Posted January 26, 2013 Just an idea, the clutch and brakes could go internal, there is race car setups that do it all the time. Then bending the exhaust pipe around the tower could be done from 4 to 1 pipe then back to 4. Hell it wouldn't be the first time someone did something for form over function...tho I would leave it at one myself. Quote Link to comment
