Defroster Glass
Tristin
So I have a line on a couple sedan rear defroster glass pieces...
What im curious about before I decide to pull the trigger is what do I need to make the glass function? I know there is a switch to turn it on and off, but curious if there is some sort of control assembly or will it be properly powered by just connecting it to power? I looked over the wiring diagrams that I had available, but I could not see anything hinting at defroster wiring.
Any ideas?
  • Replies 18
I assumed as much, but unsure of what kind I should be picking up... There are varying relays out there and I want to make sure I can get this setup before I pickup the couple rear windshields I have available to me.
Would anyone have pictures of theirs installed?- maybe a wiring diagram from a '73 FSM.
Not very many of the older cars used a timer.
I would go to pick-n-pull and for $2 get a genuine Nissan relay like this:
Nissan relays are more reliable than generic ones
25230-C9900 is one of the most common 1980s-1990s relays and has an extra pin but will still work, just do not connect pin A
True, but if you can add a timer it would be worth it I think. Of course it will work with a regular relay.
