AZ-Ram Posted September 28, 2012 Report Share Posted September 28, 2012 First question, and I think I mention this before. My tires tend to wear out quickly, this is because i need an alignment badly. However I cannot get an alignment because a part needs to be replaced. I cannot remember the exact name, but it is something like rod bearings... any help? Second question I was pulling up the old nasty carpet the other day and I got to a point where there was a black gooey substance, my dad said that it was the factory glue to hold the carpet, does anyone know how to get it up? Can one replace the entire steering column of a 1982 Datsun 720 KC with a steering column out of another vehicle? Preferibly a steering column that raises and/or telescopes? Any help would be apreciated. Quote Link to comment
I'm BLUE Posted September 28, 2012 Report Share Posted September 28, 2012 (1) Tie rods( replace any and all that might be bad ). Measure and count the threads if you change them your-self. Then have alignment performed ASAP after. (2) Dry Ice , Torch (lol) , or scrapper ... wear a mask or gloves as needed (3) I no no No Thank you sir ! Quote Link to comment
DREWSDIME Posted September 28, 2012 Report Share Posted September 28, 2012 Well later 720's have tilt wheel on there columns, not sure if you can swap though maybe someone else does. Quote Link to comment
Ratwagon1600 Posted September 28, 2012 Report Share Posted September 28, 2012 I'm currently a self styled expert on black gooey stuff. If you have a look in my build thread, you'll see the fun I've been having recently. Whilst I've found dry ice works well with the factory body deadener sheeting on the 510's, best method I've found for this stuff is hot air gun (a hair dryer will do), a scraper, and lots of patience. Once you get the worst of it off, some petrol and rags to clean up the residue. Have fun, it's a shit of a job" Quote Link to comment
fourfiveten Posted September 29, 2012 Report Share Posted September 29, 2012 check the "how to section regarding the steering column. Someone had a good how to thread on that, not sure that ti was a 720 but it'd be a good start for research. http://community.ratsun.net/topic/46635-steering-column-modifications-mklotz70/page__hl__steering this is the thread I was thinking of, won't answer your question but lots of good info, hope it helps Quote Link to comment
Dat Lurka Posted September 29, 2012 Report Share Posted September 29, 2012 Once you get the worst of it off, some petrol and rags to clean up the residue. That's gas in case you're wondering :poke: Tie rod ends http://www.rockauto.com/catalog/x,carcode,1210239,parttype,7428 Like guy above said. Some 720s had tilt column and they might interchange. Quote Link to comment
datzenmike Posted September 29, 2012 Report Share Posted September 29, 2012 Tilt steering was an option from Jan '83 on. Probably won't 'drop in' but likely can easily be made to fit an earlier truck. Quote Link to comment
Ratwagon1600 Posted September 29, 2012 Report Share Posted September 29, 2012 That's gas in case you're wondering :poke: :) I'm working on improving my (American) English. Quote Link to comment
AZ-Ram Posted September 29, 2012 Author Report Share Posted September 29, 2012 Thank for all the info everybody. :thumbup: Quote Link to comment
schassisowner Posted September 30, 2012 Report Share Posted September 30, 2012 i counted 3 questions..... Quote Link to comment
wayno Posted September 30, 2012 Report Share Posted September 30, 2012 720 tilt steering columns will bolt into any 720 year. Funny thing is that the 81-82 datsun diesel wiring harnesses have the early plugs, yet you can get tilt wheel hardware(turn signal/headlight/wiper/4 way assemblies) with the early plugs also, yet the column shaft is bigger on the tilt column, so the tilt column stuff has a larger hole for the larger column, so they had to have the tilt column before 1983. I do have one 1985 diesel harness(canadian spec.), but it has some weird diesel related electrical hardware that I am unsure I will be able to find in this country(USA). Quote Link to comment
