DatMo Posted July 6, 2013 Author Report Share Posted July 6, 2013 picked up a master cylinder off a 280z from flatcat. Quote Link to comment
q-tip Posted July 6, 2013 Report Share Posted July 6, 2013 Is that a 7/8 or 15/16 Quote Link to comment
DatMo Posted July 6, 2013 Author Report Share Posted July 6, 2013 Is that a 7/8 or 15/16 15/16 Quote Link to comment
Tristin Posted July 6, 2013 Report Share Posted July 6, 2013 That's going to be a pretty stiff pedal... Quote Link to comment
q-tip Posted July 6, 2013 Report Share Posted July 6, 2013 Its a stiff pedal for sure but the brakes will work really well. It all really depends what the driver likes Quote Link to comment
DatMo Posted July 7, 2013 Author Report Share Posted July 7, 2013 I could always resell for same value because I heard a lot of people look for these. not only that but anything can become the norm. I'll see how it goes. its funny. before i bought this, i did research awhile ago and a lot of people looked for it. now i post i got one and a lot of people say ehhh. haha Quote Link to comment
Tristin Posted July 7, 2013 Report Share Posted July 7, 2013 its funny. before i bought this, i did research awhile ago and a lot of people looked for it. now i post i got one and a lot of people say ehhh. haha Not too sure what that means. Ill explain my comment. If youre just running 280zx brakes up front you should have picked up the 7/8s MC. If you are running rear discs as well then youll want the 15/16s. The 15/16s will be pretty stiff since youre only running one set of discs. Itll all function together fine, you may just get tired when using the stiff brakes. 1 Quote Link to comment
DatMo Posted July 7, 2013 Author Report Share Posted July 7, 2013 Not too sure what that means. Ill explain my comment. If youre just running 280zx brakes up front you should have picked up the 7/8s MC. If you are running rear discs as well then youll want the 15/16s. The 15/16s will be pretty stiff since youre only running one set of discs. Itll all function together fine, you may just get tired when using the stiff brakes. Thanks. I'll test the stock mc for awhile then switch to the z mc and see how it feels. if its too stiff, then ill just resell. I'm buying it for $100. I dont think im getting ripped off. thanks for the inpuit Quote Link to comment
q-tip Posted July 7, 2013 Report Share Posted July 7, 2013 If its a 15/16 from a z it will be proportioned for rear drums ifnl its from a zx its proportioned for rear discs. I'm running a 7/8 master cylinder from a z. the pedal is pretty stiff but not really hard, don't have any experience with a 15/16 but I've heard there quite stiff. Its really up to the drivers preference 1 Quote Link to comment
DatMo Posted July 7, 2013 Author Report Share Posted July 7, 2013 If its a 15/16 from a z it will be proportioned for rear drums ifnl its from a zx its proportioned for rear discs. I'm running a 7/8 master cylinder from a z. the pedal is pretty stiff but not really hard, don't have any experience with a 15/16 but I've heard there quite stiff. Its really up to the drivers preference thats what i had also read. that the z one im buying is disc/drum. Thanks for the info. Quote Link to comment
jrock4224 Posted July 7, 2013 Report Share Posted July 7, 2013 i will take that 15/16 if u decide u wanna 7/8...i run a 210 booster and require the 15/16 m/c and need one again....my truck runs a 7/8 now but i had a 15/16 on it for a few days ... it was much harder .....but with a booster it is better to use he bigger bore..... keep me in mind if u decide to go withthe 7/8 Quote Link to comment
jrock4224 Posted July 7, 2013 Report Share Posted July 7, 2013 the size of the bore has little to do with the disc front or rears unless coming off vehicles with similar set ups .... internal residual valves are different from disc to drum......secondly if your buying from flat cat your getting ripped off....cuz u cant sell datsun parts unless u own a datsun.....lol....flat cat is good, he aint ripping u off...100 is fair for a working order z master ...like i said i am interested in it if your selling since i run a power booster/... Quote Link to comment
q-tip Posted July 7, 2013 Report Share Posted July 7, 2013 Jeeesus jrock so many periods, in all the wrong places. :lol: Quote Link to comment
jrock4224 Posted July 7, 2013 Report Share Posted July 7, 2013 is that a contribution or just a chance to act like a ass Quote Link to comment
DatMo Posted July 7, 2013 Author Report Share Posted July 7, 2013 is that a contribution or just a chance to act like a ass this made me laugh. I'll keep you in mind. im not installing until awhile because i need some 14inch rims and i wanna do all my suspension at once. so itll be a month and a half or so when i have all my coilovers and rims w/ tires. if it doesnt feel too good for me. ill be sellin it to you Quote Link to comment
jrock4224 Posted July 7, 2013 Report Share Posted July 7, 2013 u could always just add the 210 booster to your car if it feels stiff..... Quote Link to comment
q-tip Posted July 8, 2013 Report Share Posted July 8, 2013 is that a contribution or just a chance to act like a assA little bit of both maybe? :lol: And adding the booster would be a good addition if you think the pedal is too stiff Quote Link to comment
jrock4224 Posted July 8, 2013 Report Share Posted July 8, 2013 red banner hooked me up wight and tight with a b210 booster set up.... i would report back to how it works but my progress is like columbus discovering amuricah....slow and aimless... Quote Link to comment
q-tip Posted July 8, 2013 Report Share Posted July 8, 2013 ...at least youre honest Jon... ....and I could really say the same for my projects :lol: 1 Quote Link to comment
DatMo Posted July 12, 2013 Author Report Share Posted July 12, 2013 Might buy some stainless steel brake lines. I got the cylinder and the zx struts so why not redo the lines? Are they worth it? or just use the normal ones. Quote Link to comment
Tristin Posted July 12, 2013 Report Share Posted July 12, 2013 For the price, its nice to replace the old rubber. You already have everything apart so why not? 1 Quote Link to comment
DatMo Posted July 12, 2013 Author Report Share Posted July 12, 2013 For the price, its nice to replace the old rubber. You already have everything apart so why not? What's a good price? I was planning on gettin these. http://www.ebay.com/itm/Red-Stainless-steel-brake-lines-hoses-69-73-Datsun-510-/251299455966?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3A510&hash=item3a829d63de&vxp=mtr flatcat told me it was a good deal. just want some other opinions and they seem about the same price was other ones. Quote Link to comment
Tristin Posted July 12, 2013 Report Share Posted July 12, 2013 That sounds about right... its for all four corners so its not a terrible price. You might be able to find some a little cheaper if you remove your stock piece, take it into a hose shop, and they will make you brand new ones in SS braid. Those arent a horrible price though, so I wouldnt be too busted up about buying those. Quote Link to comment
jrock4224 Posted July 12, 2013 Report Share Posted July 12, 2013 i think i paid 60 bux for a set ...carter hooked me up with the right people...and izzo hooked me up with a place to get a matching clutch line, full length from slave to master...i have the info somewhere Quote Link to comment
DatMo Posted July 12, 2013 Author Report Share Posted July 12, 2013 Sweet. thanks a ton guys. I'ma see if i have enough after i pick up my rims next weekend when i get my paycheck. Quote Link to comment
