mcmlxxxv Posted September 11, 2012 Author Report Share Posted September 11, 2012 Thx guys :) I bought my weight jacks for the rear coils today . Still need to rebuild the rear floor section to install them on a solid base . I hope I ll be able to finish the floors this weekend even if my nibbler cutter broke .. Still thinking about what I will do with the passenger side quarter panel too ... If i cant find one in decent shape I might have to make one.... Anyone can post me pictures of the front seatbelts bolt location? :) Also if you have advice on rear spring rates that would be apreciated. Thx Quote Link to comment
mcmlxxxv Posted September 12, 2012 Author Report Share Posted September 12, 2012 got the rotisserie tonight :) Quote Link to comment
mcmlxxxv Posted September 12, 2012 Author Report Share Posted September 12, 2012 bought my rear weight jacks apparatus :P plus some rod ends for the front control arm then my girlfriend gave me a early birthday gift :P a nice toolbox hehe Quote Link to comment
Eagle_Adam Posted September 12, 2012 Report Share Posted September 12, 2012 love this build! keep up the hard work man! Quote Link to comment
mcmlxxxv Posted September 13, 2012 Author Report Share Posted September 13, 2012 thx :) more from tonight !!! Quote Link to comment
djfootball Posted September 13, 2012 Report Share Posted September 13, 2012 Impressing stuff! Following for sure. Keep up the updates! Quote Link to comment
mcmlxxxv Posted September 14, 2012 Author Report Share Posted September 14, 2012 going sideway?? 1 Quote Link to comment
djfootball Posted September 14, 2012 Report Share Posted September 14, 2012 Noob question. Just curious. Is there a reason the "X" is stamped in the floor boards that you bought? Are they structural? Also, what gauge is the steel your using for the floor boards? Thanks in advance. 1 Quote Link to comment
mcmlxxxv Posted September 14, 2012 Author Report Share Posted September 14, 2012 floor boards are 22g , and the X is to avoid the BOING BOING when you put weight on them :) Quote Link to comment
djfootball Posted September 14, 2012 Report Share Posted September 14, 2012 ahh.. IC. I have a lot to learn. Quote Link to comment
mcmlxxxv Posted September 16, 2012 Author Report Share Posted September 16, 2012 getting the front frame repaired coated a part of the rear , just to see how the stuff work's pretty happy with the results , I also cut the spare hole out since it was rusted out... I will weld a flat plate there 1 Quote Link to comment
djfootball Posted September 16, 2012 Report Share Posted September 16, 2012 So far are all of your patches still 22g? Will you still use 22g on your spare hole patch? Lookn' good man.. keep it rolling.! Quote Link to comment
mcmlxxxv Posted September 16, 2012 Author Report Share Posted September 16, 2012 yep all floors are 22g , frame parts are 16g :) Quote Link to comment
mcmlxxxv Posted September 22, 2012 Author Report Share Posted September 22, 2012 did a bit of polish on the wheels today ... did't had the stuff I needed to continue working on the tub... lets start by removing the paint then polish !! I know, still have a couple hour to put on those ... but im pretty happy with the look they will have :) Quote Link to comment
Z chopper Posted September 22, 2012 Report Share Posted September 22, 2012 hmmm drag radials?? Quote Link to comment
mcmlxxxv Posted September 22, 2012 Author Report Share Posted September 22, 2012 hehe those are advan a032r, semi slick for time attack :) Quote Link to comment
mcmlxxxv Posted September 23, 2012 Author Report Share Posted September 23, 2012 I took the rear end apart and the front subframe too... there will be some work on them (straighten the brackets and repair a couple of dents... I will go pull a diff from a forester next weekend because the one on the car is welded and the side bearings are dead the floor is getting complete too, still have a couple of holes to patche on the front frame rails ... then I will start moding the rear parts that hold the spring and the rear underseat floor . Picture tonight 1 Quote Link to comment
mcmlxxxv Posted September 24, 2012 Author Report Share Posted September 24, 2012 here goes the pictures today's progress , I enlarged the wheel house to fit the lower offset wheels and obviously patched the hole that was there here is how the floor look like now, : next step the trunk .. cant wait to put it back on it's wheels :D Quote Link to comment
mcmlxxxv Posted September 24, 2012 Author Report Share Posted September 24, 2012 polished a little more... Quote Link to comment
djfootball Posted September 27, 2012 Report Share Posted September 27, 2012 I'd like to see what you end up doing with the trunk hole or how you repair it. I'm going to have to cut mine out as well. Quote Link to comment
mcmlxxxv Posted September 27, 2012 Author Report Share Posted September 27, 2012 I will patch it with a sheet metal that i'll get grooved , much like the X in the floor pans or something like that , but I must repair the floor aroud it before and repair the rear frame rails holding the bumpers. dont worry , I will post pics :D Quote Link to comment
mcmlxxxv Posted November 14, 2012 Author Report Share Posted November 14, 2012 ok , the project was on hold for last month ... been quite busy changing the daily drive for winter . I brought the subframes and control arms to the sandblast tonight . will paint them this week end . then I will finish the floors . Quote Link to comment
mcmlxxxv Posted November 15, 2012 Author Report Share Posted November 15, 2012 subframes painted Quote Link to comment
mcmlxxxv Posted November 19, 2012 Author Report Share Posted November 19, 2012 more works on the floors : more to come this week end :) Quote Link to comment
jinx3 Posted November 20, 2012 Report Share Posted November 20, 2012 Looking good - nice progress. I am currently doing floor repair also.... Quote Link to comment
